uranus Skrevet 4. april 2005 Del Skrevet 4. april 2005 (endret) Hei! Har et script her som skal måle hastigheten på internetten din. Men den vil ikke fungere, se selv: www.ludrio.com/sider/hastighet.php Koden: <?php /*** Bandwidth Tester 0.92 ***/ /* Please wait for 1.0 patiently! */ // How many bytes to test with. Mimimum=70. 128KB=131072. 1MB=1048576 $testsize = 131072; header ("Expires: Mon, 26 Jul 1997 05:00:00 GMT"); // Date in the past header ("Last-Modified: " . gmdate("D, d M Y H:i:s") . " GMT"); // always modified header ("Cache-Control: no-cache, must-revalidate"); // HTTP/1.1 header ("Pragma: no-cache"); // HTTP/1.0 header ("X-Notice: "); header ("X-Notice: Bandwidth-Tester is freeware."); header ("X-Notice: You may use it freely on your site."); header ("X-Notice: Just don't remove this notice."); header ("X-Notice: To get the source code, run this script "); header ("X-Notice: with downloadme=1 in the query string."); /* How does it work? The script generates a variable amount of random data * sends it to the client and measures the time taken for transmission. The * bandwidth is then calculated from the time using a simple algorithm. * * WARNING: This script can bog down your server - as absolutely NO * optimization was used. * * * This script is best run on the Zend PHP Engine, with Zend Optimizer. * Any improvement in performance is not guaranteed with other * PHP Engines. * * History: * 0.9 - First public release * 0.91 - Reduced the size of the timing code * 0.92 - Reduced the size of the timing code even more * Forecast: * 0.921a - Adding a smaller test before the main to make results more accurate and to adjust test data according to first results * 1.0 - Looking to adding optimization code * 1.1 - Adding template support * 1.2 - Adding web-based administration */ if($downloadme==1){ echo "<html><body>"; show_source($SCRIPT_FILENAME); echo "</body></html>"; } else { // First, initialize the test comment // seed random srand ((double) microtime() * 1000000); if($testsize<70) {die("<script>alert('The test string size is less than 70. Cannot test.')</script>"); } $realtestsize = $testsize - 70; function GetTestString($drealtestsize){ $duhteststring = "<!"."--"; for($i=0;$i<$drealtestsize; $i++){ $duhteststring .= generatekeycode(); } $duhteststring .= "-"."->"; return $duhteststring; } function CalculateBandwidth($Ditt,$Dott){ $Datasize=$Dott; $LS=$Datasize/$Ditt; $kbps=(($LS*8)*10*1.02)/10; $mbps=$kbps/1024; if($mbps>=1){$speed=$mbps." Mbps aka ".$kbps." Kbps";} else {$speed=$kbps." Kbps aka ".$mbps." Mbps";} $speed .="<br>Time taken to test connection: ".(($Ditt*1024)/1000)." Seconds <br>A number used to determine your speed: ".$LS."<br>Another number used to determine your speed: ".$Ditt."<br>Tested your connection with ".$Datasize."Bytes/".($Datasize/1024)."KB/".($Datasize/1048576)."MB of random data<br>"; return $speed; } function generatekeycode(){ // srand ((double) microtime() * 1000000); // Made the randomizer a little more "random"! :) srand ((double) microtime() * rand(100000,1000000) / rand(1,15)); $tester = rand(33,255); if($tester==45)return generatekeycode(); return chr($tester); } ?><html> <head><title>Bandwidth Tester</title></head> <body><?php if($HTTP_SERVER_VARS["REQUEST_METHOD"]=="GET" && $HTTP_GET_VARS["execute"]!="1"){ echo('<form action="'.$HTTP_SERVER_VARS["SCRIPT_NAME"].'" method="GET"> <input type="submit" value="Click Here To Begin Testing" onClick="this.value=\'Please wait while your request is being processed, it may take a while\'"> <input type="hidden" name="execute" value="1"> <input type="hidden" name="DO.NOT.CACHE" value="'.rand(255,65536).'"> </form>');} elseif($HTTP_GET_VARS["execute"]=="1"){ $teststring=GetTestString($realtestsize);echo('<form method="POST" action="'.$HTTP_SERVER_VARS["SCRIPT_NAME"].'"> <input type="hidden" name="td" value="No Test"> <input type="button" value="Please wait while your request is being processed, it may take a while"> </form> <script language="JavaScript"> var Hi = new Date(); </script>'.$teststring.'<script language="JavaScript"> var Bye = new Date(); var NiHao = new Array(Hi.getTime(),Bye.getTime()); var Factor=1024; if(NiHao[1]==NiHao[0]) Ditt=0; else Ditt=(NiHao[1]-NiHao[0])/Factor; document.forms[0].elements[0].value=Ditt; document.forms[0].submit(); </script><p>Tested. Now processing your request....</p>');} elseif($HTTP_SERVER_VARS["REQUEST_METHOD"]=="POST"&&$HTTP_POST_VARS["td"]>0){ echo('<p>We have tested your Internet connection.<br> The speed to which you connected to us is '.CalculateBandwidth($HTTP_POST_VARS["td"],$testsize).' Thank you!<br> <a href="?downloadme=1">Would you like one of these on your site? Click here.</a> </p>');} elseif($HTTP_SERVER_VARS["REQUEST_METHOD"]=="POST"&&$HTTP_POST_VARS["td"]==0){ echo('<p>We were unable to test your connection speed.<br>It was too fast to measure.<br> <a href="'.$HTTP_SERVER_VARS["SCRIPT_NAME"].'?execute=1&DO.NOT.CACHE='.rand(255,65536).'" onClick="this.innerText=\'The system is now generating the random test data to benchmark your connection speed. It will take a while.\'">If you would like to try testing again, click here.</a></p> <p>'.CalculateBandwidth($HTTP_POST_VARS["td"],$testsize).'</p>'); } ?> </body> </html><?php } ?> Noen som vet hvorfor den viser så feil? Endret 5. april 2005 av Jankee Lenke til kommentar
Danjaco Skrevet 4. april 2005 Del Skrevet 4. april 2005 så feil er den vel ikke, litt mye unødvendig info er det men men fikk ifølge målern at jeg hadde 675 linje jeg har 700 (tiscali) fikk også at jeg lasta ned 128 kb på 1.6 sekunder noe som stemmer veldig bra tror det også er noen benevningsfeil. Lenke til kommentar
jorgis Skrevet 4. april 2005 Del Skrevet 4. april 2005 Vel, den var ikke bare litt feil. Den sier følgende: The speed to which you connected to us is 153.01109012876 Mbps aka 156683.35629185 Kbps ...og jeg sitter ikke på en 150MBit linje. Når ITavisen gir meg mellom 600kbits og 1100kbits (trøbbel med nett), tror jeg det stemmer sånn noenlunde, så det er ikke bare en benevningsfeil. Lenke til kommentar
DesertGlow Skrevet 4. april 2005 Del Skrevet 4. april 2005 Et bra emnefelt er et emnefelt som forklarer godt hva innholdet i posten din går ut på. En bruker bør kunne skaffe seg oversikt over hovedinnholdet i posten bare ut fra å lese emnefeltet. Emnefeltet i denne tråden var ikke godt nok, og har derfor blitt endret slik at det er lettere å forstå hva slags informasjon tråden inneholder. Vennligst forsøk å tenk på dette neste gang du starter en tråd. Lenke til kommentar
Danjaco Skrevet 5. april 2005 Del Skrevet 5. april 2005 156683.35629185 / 1000 = 156 * 7 = 1092 linje Lenke til kommentar
uranus Skrevet 5. april 2005 Forfatter Del Skrevet 5. april 2005 Hva må jeg gjøre med koden for at den skal gi riktig resultat? Kanke bare gjette med tall å dele på.. Lenke til kommentar
