kyrsjo Skrevet 4. april 2005 Del Skrevet 4. april 2005 (endret) Når jeg kompilerer gravitasjons-kart programmet mitt, får jeg følgende feilmelding: main.c: In function `grav_calc': main.c:91: warning: left-hand operand of comma expression has no effect Dette peker på denne lille funksjonen: double grav_calc (double dx, double dy, double mass) { return ((GAMMA * mass) / (dy*dy + dx*dx)); <- gir feil } Forøvrig har det ikke noe å si om jeg skriver slik: double result; result = (GAMMA * mass ... <- gir samme feil return result; Et annet problem, er at det gir litt feil resultat når jeg regner: bash-3.00$ ./GravityMap esd: Failed to fix owner of /tmp/.esd. Try -trust to force esd to start. esd: Esound sound daemon unable to create unix domain socket: /tmp/.esd/socket The socket is not accessible by esd. Exiting... Testing with the radius of the earth: 64612199945301.320312 QUIT!! bash-3.00$ Nå er vel tyngdeakserelasjonen ved jordas overflate 9,81 da - noe denne gir: //testprog.c #include <stdlib.h> #include <stdio.h> #define GAMMA 0.0000000000667 int main () { double dy = 0; double dx = 6371000; double mass = 5974000000000000000000000.0; printf ("%d\n", (int)sizeof (double)); double result; result = (GAMMA * mass) / (dy*dy + dx*dx); printf ("%f\n", result); return 0; } Kjøring: bash-3.00$ ./test 8 9.816933 bash-3.00$ Tilsist: den fulle og hele koden: #include <stdlib.h> #include "SDL.h" //Resolution. Shold be autodetected... #define ROWS 640 #define COLS 480 //Plotting stuff. Should eventually become dynamical... // 6*10^8 / 640 #define METERPRPIXEL 937500 // 10^8 / 640 #define Xcenter 156250 // 480 / 2 #define Ycenter 240 //Input values. MUST get dynamical ASAP, those here are just for testing! //Object 1 (Earth) - 5,974*10^24 #define MASS1 5974000000000000000000000 //Natural constants //Gravitational constant, 6,67*10^-11 #define GAMMA 0,0000000000667 //Functions double grav_calc (double dx, double dy, double mass); void lock(); void unlock(); void drawrect(int x1, int y1, int x2, int y2, Uint8 r, Uint8 g, Uint8 b); void setpixel(int x, int y, Uint8 r, Uint8 g, Uint8 b); //Arrays to keep the info double gravDepth1 [ROWS] [COLS]; double gravDepth2 [ROWS] [COLS]; double gravDepthSum [ROWS] [COLS]; //SDL stuff SDL_Surface *screen; SDL_Event event; int main(int argc, char *argv[]) { //Initialize SDL if ( SDL_Init(SDL_INIT_AUDIO|SDL_INIT_VIDEO) < 0 ) { fprintf(stderr, "Unable to init SDL: %s\n", SDL_GetError()); exit(1); } atexit(SDL_Quit); screen = SDL_SetVideoMode(ROWS, COLS, 16, SDL_SWSURFACE); if ( screen == NULL ) { fprintf(stderr, "Unable to set 640x480 video: %s\n", SDL_GetError()); exit(1); } //Create some data! printf ("Testing with the radius of the earth: %f \n", grav_calc (6371000,0,5974000000000000000000000.0)); //Wait for input while(SDL_WaitEvent(&event)) { switch(event.type) { case SDL_QUIT: printf ("QUIT!!\n"); return (0); break; /* case SDL_KEYDOWN: switch (event.key.keysym.sym) case SDLK_SPACE: //drawrect (50,50,200,200,255,255,255); printf ("SPACE!!\n"); break; //Why isn't this working? (i get a whole lot of error //messages at compile time) //I do not want to handle every key i don't use... default: printf ("DEFAULT!!\n"); break; */ } SDL_Flip(screen); } return (0); } double grav_calc (double dx, double dy, double mass) { return ((GAMMA * mass) / (dy*dy + dx*dx)); } //************************************************************************** //********************** SDL DRAWING FUNCTIONS ***************************** //************************************************************************** void lock() { /* Lock the screen, if needed */ if(SDL_MUSTLOCK(screen)) { if(SDL_LockSurface(screen) < 0) return; } } void unlock() { /* Unlock the screen if needed */ if(SDL_MUSTLOCK(screen)) { SDL_UnlockSurface(screen); } } void drawrect(int x1, int y1, int x2, int y2, Uint8 r, Uint8 g, Uint8 b) { Uint32 color; color = SDL_MapRGB (screen->format, r, g, b); SDL_Rect rect; rect.w = x2; rect.h = y2; rect.x = x1; rect.y = y1; lock(); SDL_FillRect (screen, &rect, color); unlock(); } void setpixel(int x, int y, Uint8 r, Uint8 g, Uint8 b) { Uint8 *ubuff8; Uint16 *ubuff16; Uint32 *ubuff32; Uint32 color; char c1, c2, c3; lock(); /* Get the color */ color = SDL_MapRGB( screen->format, r, g, b ); /* How we draw the pixel depends on the bitdepth */ switch(screen->format->BytesPerPixel) { case 1: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y * screen->pitch) + x; *ubuff8 = (Uint8) color; break; case 2: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y * screen->pitch) + (x*2); ubuff16 = (Uint16*) ubuff8; *ubuff16 = (Uint16) color; break; case 3: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y * screen->pitch) + (x*3); if(SDL_BYTEORDER == SDL_LIL_ENDIAN) { c1 = (color & 0xFF0000) >> 16; c2 = (color & 0x00FF00) >> 8; c3 = (color & 0x0000FF); } else { c3 = (color & 0xFF0000) >> 16; c2 = (color & 0x00FF00) >> 8; c1 = (color & 0x0000FF); } ubuff8[0] = c3; ubuff8[1] = c2; ubuff8[2] = c1; break; case 4: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y*screen->pitch) + (x*4); ubuff32 = (Uint32*)ubuff8; *ubuff32 = color; break; default: fprintf(stderr, "Error: Unknown bitdepth!\n"); } unlock(); } Hva kan forårsake dette? Sterkt undrende... Endret 4. april 2005 av kyrsjo Lenke til kommentar
A_N_K Skrevet 4. april 2005 Del Skrevet 4. april 2005 Når jeg kompilerer gravitasjons-kart programmet mitt, får jeg følgende feilmelding: main.c: In function `grav_calc': main.c:91: warning: left-hand operand of comma expression has no effect Du bør undersøke definisjonen av GAMMA . Lenke til kommentar
Feynman Skrevet 4. april 2005 Del Skrevet 4. april 2005 //Natural constants //Gravitational constant, 6,67*10^-11 #define GAMMA 0,0000000000667 Du bør i hvert fall erstatte kommaet med et punktum. Lenke til kommentar
kyrsjo Skrevet 4. april 2005 Forfatter Del Skrevet 4. april 2005 D'oh. Hadde retta det opp i "test.c"... Takker! Nå fiksa det seg Da var det over til å begynne å fylle matrisen, og tegne ut... Lenke til kommentar
☀ ❄ Skrevet 4. april 2005 Del Skrevet 4. april 2005 Moralen er: Bruk C++. Unngå #defines. Lenke til kommentar
hishadow Skrevet 4. april 2005 Del Skrevet 4. april 2005 Moralen er: Bruk C++. Unngå #defines. Hør! Hør! Og jeg vil også minne om const, som mange overser nytten av. Lenke til kommentar
kyrsjo Skrevet 4. april 2005 Forfatter Del Skrevet 4. april 2005 Bah... C! C! Ikke at forskjellen er kjeeempestor... Har uansett ingen anelse om hva jeg skal bytte ut defines'ene med... Ender vel med at jeg lager en variabel, og endrer define - definisjonen til å peke til variabelen Kommet opp i et nytt problem: gcc -Wall `sdl-config --cflags --libs` main.c -o gravitymap main.c: In function `main': main.c:60: error: `for' loop initial declaration used outside C99 mode main.c:61: error: `for' loop initial declaration used outside C99 mode WFT? Noen som vet om en liste over GCC-feilmelinger og deres løsning? Aktuelle kode: for (int x = 0; x <= ROWS; x++) { for (int y = 0; y <= COLS; y++) { printf("x = %d, y = %d\n", x, y); } } Forøvrig lar programmet seg fin-fint kompilere og kjøre som C++ (om jeg bytter ut gcc med g++ altså). Men det var ikke det jeg ville... Lenke til kommentar
Feynman Skrevet 4. april 2005 Del Skrevet 4. april 2005 Siste rad (kolonne) har verdien ROWS-1 (COLS-1). Løkken må derfor stoppe ved x < ROWS (y < COLS). Lenke til kommentar
☀ ❄ Skrevet 4. april 2005 Del Skrevet 4. april 2005 Jeg er ikke enig i at forskjellen mellom C og C++ ikke er kjempestor. Jeg synes den er det, bare ikke syntaksmessig. Men det er en annen diskusjon Feilen du gjør er at du deklarerer variabler i første del av en for-løkke. Det har du ikke lov til i C (med unntak av C99), for deklarasjoner skal dukke opp i begynnelsen av en blokk. Riktig: void f() { int i; for (i = 0; i < 5; ++i) { /* ... */ } } Galt: void f() { for (int i = 0; i < 5; ++i) { /* ... */ } } Lenke til kommentar
hishadow Skrevet 4. april 2005 Del Skrevet 4. april 2005 for (int x = 0; x <= ROWS; x++) { for (int y = 0; y <= COLS; y++) { printf("x = %d, y = %d\n", x, y); } } Hvorfor teller du fra 0 til og med ROWS/COLS? Lenke til kommentar
kyrsjo Skrevet 4. april 2005 Forfatter Del Skrevet 4. april 2005 Ahh.. Gjorde vist et par feil der - er ikke helt stø på c(++) ennå. Men da får vi deklarere dem. Forøvrig teller jeg til rows/cols fordi jeg skal bruke dem til å fylle array'et etterpå... Noe som medfører at jeg glemte at array's i C(++) går fra null og har cols-1 som maks... Ups. Hadde vel funnet ut av det etter en "uforklarlig" segfault eller femten... const var kansje en idé. Lenke til kommentar
kyrsjo Skrevet 4. april 2005 Forfatter Del Skrevet 4. april 2005 Har putta inn en del mer (denne tråden blir rene CVS'en ) - nå regner den faktisk ut gravitasjons-verdiene, og putter dem inn. Den tegner til og med! Men tegningen har et ørlite problem (nevermind the speed - men der er vel "printf" en av de større synderene...) - den er for svak. Programmet genererer et veldig lite tall som stort sett ligger under 0,001 -> må forsterkes. Med nåværende algoritme (ønsker ikke å sprenge Uint8 heller! - maks 255...) får jeg i beste fall "2,0,0" som fargeverdi, og det er rimelig svart. Regner med at jeg trenger noe logaritme-greier... - eller i alle fall x^value. Men hvordan man utrykker "^" i C (samt log etc) er meg ukjent. Pluss at en enkel "x^value" vil være motsatt av det jeg trenger - jeg vil forsterke de svake mye, de sterke lite, og få dem til å fylle skalaen 0-255 ganske bra. Noen idé'er? Takk for all hjelp hitil! Foreløpig kode: #include <stdlib.h> #include "SDL.h" //Resolution. Shold be autodetected... #define ROWS 640 #define COLS 480 //Plotting stuff. Should eventually become dynamical... // 6*10^8 / 640 #define METERPRPIXEL 937500 // 640 / 5 #define Xcenter 128 // 480 / 2 #define Ycenter 240 //Input values. MUST get dynamical ASAP, those here are just for testing! //Object 1 (Earth) - 5,974*10^24 #define MASS1 5974000000000000000000000.0 //Natural constants //Gravitational constant, 6,67*10^-11 #define GAMMA 0.0000000000667 //Functions double grav_calc (double dx, double dy, double mass); double grav_UnitConv (int grav_PixelValue); Uint8 grav_colorConvR (double value); Uint8 grav_colorConvG (double value); Uint8 grav_colorConvB (double value); void lock(); void unlock(); void drawrect(int x1, int y1, int x2, int y2, Uint8 r, Uint8 g, Uint8 b); void setpixel(int x, int y, Uint8 r, Uint8 g, Uint8 b); //Arrays to keep the info double gravDepth1 [ROWS] [COLS]; double gravDepth2 [ROWS] [COLS]; double gravDepthSum [ROWS] [COLS]; //SDL stuff SDL_Surface *screen; SDL_Event event; int main(int argc, char *argv[]) { //Initialize SDL if ( SDL_Init(SDL_INIT_AUDIO|SDL_INIT_VIDEO) < 0 ) { fprintf(stderr, "Unable to init SDL: %s\n", SDL_GetError()); exit(1); } atexit(SDL_Quit); screen = SDL_SetVideoMode(ROWS, COLS, 16, SDL_SWSURFACE); if ( screen == NULL ) { fprintf(stderr, "Unable to set 640x480 video: %s\n", SDL_GetError()); exit(1); } //Create some data! printf ("Testing with the radius of the earth: %f \n", grav_calc (6371000,0,5974000000000000000000000.0)); int x; int y; for (x = 0; x < ROWS; x++) { for (y = 0; y < COLS; y++) { gravDepth1 [x] [y] = grav_calc (grav_UnitConv(x - Xcenter), grav_UnitConv(y - Ycenter), MASS1); printf ("Depth in (%d,%d):%f - colour: %d\n",x,y,gravDepth1 [x] [y], grav_colorConvR(gravDepth1 [x] [y])); setpixel (x , y, grav_colorConvR(gravDepth1 [x] [y]),0, 0); //setpixel (x, y, 255, 255, 255); //drawrect (x,y,x+10,y+10,255,255,255); //break; } SDL_Flip(screen); //break; } //Draw the data! //Wait for input while(SDL_WaitEvent(&event)) { switch(event.type) { case SDL_QUIT: printf ("QUIT!!\n"); return (0); break; /* case SDL_KEYDOWN: switch (event.key.keysym.sym) case SDLK_SPACE: //drawrect (50,50,200,200,255,255,255); printf ("SPACE!!\n"); break; //Why isn't this working? (i get a whole lot of error //messages at compile time) //I do not want to handle every key i don't use... default: printf ("DEFAULT!!\n"); break; */ } SDL_Flip(screen); } return (0); } double grav_calc (double dx, double dy, double mass) { return ((GAMMA * mass) / (dy*dy + dx*dx)); } double grav_UnitConv (int grav_PixelValue) { return (METERPRPIXEL * grav_PixelValue); } //Convert gravity depth value to a sane colour value Uint8 grav_colorConvR (double value) { return ((value / 20) * 255); } Uint8 grav_colorConvG (double value) { return 0; } Uint8 grav_colorConvB (double value) { return 0; } //************************************************************************** //********************** SDL DRAWING FUNCTIONS ***************************** //************************************************************************** void lock() { /* Lock the screen, if needed */ if(SDL_MUSTLOCK(screen)) { if(SDL_LockSurface(screen) < 0) return; } } void unlock() { /* Unlock the screen if needed */ if(SDL_MUSTLOCK(screen)) { SDL_UnlockSurface(screen); } } void drawrect(int x1, int y1, int x2, int y2, Uint8 r, Uint8 g, Uint8 b) { Uint32 color; color = SDL_MapRGB (screen->format, r, g, b); SDL_Rect rect; rect.w = x2; rect.h = y2; rect.x = x1; rect.y = y1; lock(); SDL_FillRect (screen, &rect, color); unlock(); } void setpixel(int x, int y, Uint8 r, Uint8 g, Uint8 b) { Uint8 *ubuff8; Uint16 *ubuff16; Uint32 *ubuff32; Uint32 color; char c1, c2, c3; lock(); /* Get the color */ color = SDL_MapRGB( screen->format, r, g, b ); /* How we draw the pixel depends on the bitdepth */ switch(screen->format->BytesPerPixel) { case 1: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y * screen->pitch) + x; *ubuff8 = (Uint8) color; break; case 2: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y * screen->pitch) + (x*2); ubuff16 = (Uint16*) ubuff8; *ubuff16 = (Uint16) color; break; case 3: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y * screen->pitch) + (x*3); if(SDL_BYTEORDER == SDL_LIL_ENDIAN) { c1 = (color & 0xFF0000) >> 16; c2 = (color & 0x00FF00) >> 8; c3 = (color & 0x0000FF); } else { c3 = (color & 0xFF0000) >> 16; c2 = (color & 0x00FF00) >> 8; c1 = (color & 0x0000FF); } ubuff8[0] = c3; ubuff8[1] = c2; ubuff8[2] = c1; break; case 4: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y*screen->pitch) + (x*4); ubuff32 = (Uint32*)ubuff8; *ubuff32 = color; break; default: fprintf(stderr, "Error: Unknown bitdepth!\n"); } unlock(); } Lenke til kommentar
kyrsjo Skrevet 5. april 2005 Forfatter Del Skrevet 5. april 2005 Peker forøvrig på http://forum.hardware.no/index.php?showtopic=400842 som er den matematiske siden av saken. Lenke til kommentar
Klette Skrevet 5. april 2005 Del Skrevet 5. april 2005 er det ikke en liten feil i kalkuleringen din? eller er det jeg som tenker feil? Formelen for feltstyrke er vel g = (y*M)/r^2 y=6.67*10^11 M = massen til jorda = 5.974*10^24 og r= avstand fra jorda/radius fra jorda. Og i og med at vi jobber med et radielt felt, så er vel x avstanden og y avstanden den samme? Blir det da ikke float grav_calc (float dist, float mass) { return ((GAMMA * mass) / (dist*dist)); } Mulig jeg surrer veldig da... Lenke til kommentar
kyrsjo Skrevet 5. april 2005 Forfatter Del Skrevet 5. april 2005 Vel: F = ma F = GAMMA * M * m / r^2 ma = GAMMA * M * m / r^2 a = GAMMA * M / r^2 r = sqrt (dx^2 + dy^2) a = GAMMA * M / (sqrt (dx^2 + dy^2))^2 a = GAMMA * M / (dx^2 + dy^2) som er det vi har. Om du fortsatt tviler, så kan du titte på denne kodestumpen: //testprog.c #include <stdlib.h> #include <stdio.h> #define GAMMA 0.0000000000667 int main () { double dy = 0; double dx = 6371000; double mass = 5974000000000000000000000.0; printf ("%d\n", (int)sizeof (double)); double result; result = (GAMMA * mass) / (dy*dy + dx*dx); printf ("%f\n", result); return 0; } (kompileres ganske enkelt med "gcc -Wall test.c .o test") Brukte den til å teste formelen min - den har hardkodet radius og masse til jorda, og gir ganske riktig 9,81. Den var forøvrig nesten-skyldig i komma-spørsmålet, ettersom jeg hadde husket å fikse #define GAMMA i denne fila, men ikke i hovedprosjektet Lenke til kommentar
Klette Skrevet 5. april 2005 Del Skrevet 5. april 2005 (endret) Min funker jo like greit da Hva er dy for no egentlig? ser ikke helt poenget med den Endret 5. april 2005 av Klette Lenke til kommentar
kyrsjo Skrevet 5. april 2005 Forfatter Del Skrevet 5. april 2005 delta y og delta x nei den er ikke noe poeng i test.c, men i det "ekte" programmet så plotter jeg inn i en 2d-matrise. Det er sååå mye lettere å finne avstander i rette linjer (og så pytagoras), enn det er å gjette seg fram til den ellers gravDepth1 [x] [y] = grav_calc (grav_UnitConv(x - Xcenter), grav_UnitConv(y - Ycenter), MASS1); og double grav_calc (double dx, double dy, double mass) { return ((GAMMA * mass) / (dy*dy + dx*dx)); } er her aktuelle. Jeg regner ut delta Y og delta X (ut ifra senter som er definert vha #define's - se toppen av koden), og forer det til grav_calc. Lenke til kommentar
Klette Skrevet 5. april 2005 Del Skrevet 5. april 2005 I det formål ja.. Da ser jeg at det kan forenkle endel. du kunne ikke ha slengt opp en svn eller no på den da ? =) Hadde vært spennede å laget noen saker til denne (bergening av kreftene fra de andre planetene også i beregningene.. bare for skøy. Dog det krever å finne posisjonene til planetene på det aktuelle tidspunkt det skal utregnes for... jaja, mye morro man kan lage med dette =) 3d versjon med opengl f.eks =) Lenke til kommentar
kyrsjo Skrevet 5. april 2005 Forfatter Del Skrevet 5. april 2005 Planen er å få inn: - Månen - Input på posisjon og masse på de to legemene - Zoom Problemet er: - Skalere output-verdiene til farger så de faktisk er synlige. Se mattetråden for dette, dette er programmeringstråden. - Knuse vektorer... senere. Trodde en stund jeg kunne regne ut akserelasjonen deres *uavhengig* av hverandre, og så summere (derfor jeg har 3 arrays) - Hastighet. Dette er treigt Når det gjelder SVN/CVS, så: - jeg kan ikke cvs - Serveren min hjemme står på ca. når jeg gidder høre på bråket/noen ringer meg og ber meg skru den på (en gammel 160 mhz med 64 MB shabby RAM og Debian Sarge. Men, den virker...) - hmm.. Sourceforge? mailingliste burde la seg ordne. Forøvrig er lisensen selvsagt GPL. Nyeste kode: #include <stdlib.h> #include <SDL.h> #include <math.h> //Resolution. Shold be autodetected... #define ROWS 640 #define COLS 480 //Plotting stuff. Should eventually become dynamical... // 6*10^8 / 640 #define METERPRPIXEL 937500 // 640 / 5 #define Xcenter 128 // 480 / 2 #define Ycenter 240 //Input values. MUST get dynamical ASAP, those here are just for testing! //Object 1 (Earth) - 5,974*10^24 #define MASS1 5974000000000000000000000.0 //Natural constants //Gravitational constant, 6,67*10^-11 #define GAMMA 0.0000000000667 //Functions double grav_calc (double dx, double dy, double mass); double grav_UnitConv (int grav_PixelValue); Uint8 grav_colorConvR (double value); Uint8 grav_colorConvG (double value); Uint8 grav_colorConvB (double value); void lock(); void unlock(); void drawrect(int x1, int y1, int x2, int y2, Uint8 r, Uint8 g, Uint8 b); void setpixel(int x, int y, Uint8 r, Uint8 g, Uint8 b); //Arrays to keep the info double gravDepth1 [ROWS] [COLS]; double gravDepth2 [ROWS] [COLS]; double gravDepthSum [ROWS] [COLS]; //SDL stuff SDL_Surface *screen; SDL_Event event; int main(int argc, char *argv[]) { //Initialize SDL if ( SDL_Init(SDL_INIT_AUDIO|SDL_INIT_VIDEO) < 0 ) { fprintf(stderr, "Unable to init SDL: %s\n", SDL_GetError()); exit(1); } atexit(SDL_Quit); screen = SDL_SetVideoMode(ROWS, COLS, 16, SDL_SWSURFACE); if ( screen == NULL ) { fprintf(stderr, "Unable to set 640x480 video: %s\n", SDL_GetError()); exit(1); } //Create some data! printf ("Testing with the radius of the earth: %f \n", grav_calc (6371000,0,5974000000000000000000000.0)); int x; int y; for (x = 0; x < ROWS; x++) { for (y = 0; y < COLS; y++) { gravDepth1 [x] [y] = grav_calc (grav_UnitConv(x - Xcenter), grav_UnitConv(y - Ycenter), MASS1); printf ("Depth in (%d,%d):%f - colour: %d\n",x,y,gravDepth1 [x] [y], grav_colorConvR(gravDepth1 [x] [y])); setpixel (x , y, grav_colorConvR(gravDepth1 [x] [y]),0, 0); //setpixel (x, y, 255, 255, 255); //drawrect (x,y,x+10,y+10,255,255,255); //break; } SDL_Flip(screen); //break; } //Wait for input while(SDL_WaitEvent(&event)) { switch(event.type) { case SDL_QUIT: printf ("QUIT!!\n"); return (0); break; /* case SDL_KEYDOWN: switch (event.key.keysym.sym) case SDLK_SPACE: //drawrect (50,50,200,200,255,255,255); printf ("SPACE!!\n"); break; //Why isn't this working? (i get a whole lot of error //messages at compile time) //I do not want to handle every key i don't use... default: printf ("DEFAULT!!\n"); break; */ } SDL_Flip(screen); } return (0); } double grav_calc (double dx, double dy, double mass) { return ((GAMMA * mass) / (dy*dy + dx*dx)); } double grav_UnitConv (int grav_PixelValue) { return (METERPRPIXEL * grav_PixelValue); } //Convert gravity depth value to a sane colour value Uint8 grav_colorConvR (double value) { //return (value * 255); return (log(value+1) * 1024); //return (pow (value + 1, 0.5)); } Uint8 grav_colorConvG (double value) { return 0; } Uint8 grav_colorConvB (double value) { return 0; } //************************************************************************** //********************** SDL DRAWING FUNCTIONS ***************************** //************************************************************************** void lock() { /* Lock the screen, if needed */ if(SDL_MUSTLOCK(screen)) { if(SDL_LockSurface(screen) < 0) return; } } void unlock() { /* Unlock the screen if needed */ if(SDL_MUSTLOCK(screen)) { SDL_UnlockSurface(screen); } } void drawrect(int x1, int y1, int x2, int y2, Uint8 r, Uint8 g, Uint8 b) { Uint32 color; color = SDL_MapRGB (screen->format, r, g, b); SDL_Rect rect; rect.w = x2; rect.h = y2; rect.x = x1; rect.y = y1; lock(); SDL_FillRect (screen, &rect, color); unlock(); } void setpixel(int x, int y, Uint8 r, Uint8 g, Uint8 b) { Uint8 *ubuff8; Uint16 *ubuff16; Uint32 *ubuff32; Uint32 color; char c1, c2, c3; lock(); /* Get the color */ color = SDL_MapRGB( screen->format, r, g, b ); /* How we draw the pixel depends on the bitdepth */ switch(screen->format->BytesPerPixel) { case 1: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y * screen->pitch) + x; *ubuff8 = (Uint8) color; break; case 2: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y * screen->pitch) + (x*2); ubuff16 = (Uint16*) ubuff8; *ubuff16 = (Uint16) color; break; case 3: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y * screen->pitch) + (x*3); if(SDL_BYTEORDER == SDL_LIL_ENDIAN) { c1 = (color & 0xFF0000) >> 16; c2 = (color & 0x00FF00) >> 8; c3 = (color & 0x0000FF); } else { c3 = (color & 0xFF0000) >> 16; c2 = (color & 0x00FF00) >> 8; c1 = (color & 0x0000FF); } ubuff8[0] = c3; ubuff8[1] = c2; ubuff8[2] = c1; break; case 4: ubuff8 = (Uint8*) screen->pixels; ubuff8 += (y*screen->pitch) + (x*4); ubuff32 = (Uint32*)ubuff8; *ubuff32 = color; break; default: fprintf(stderr, "Error: Unknown bitdepth!\n"); } unlock(); } Om du ønsker å hacke på den, så vær så god. Kommer ikke til å gjøre noe mer i kveld uansett, historieprøve... Bare vær snill å kommentere skikkelig (det burde jeg også gjøre...) OpenGL kan jeg ikke. Kompilere: gcc -Wall `sdl-config --cflags --libs` main.c -o gravitymap Blir litt Einstein gravitasjonsteori vist grafisk over det hele... Lenke til kommentar
