Orjanp Skrevet 31. mars 2005 Del Skrevet 31. mars 2005 Når jeg prøver å scanne etter tilgjengelige nettverk, får jeg følgende: # iwlist eth1 scanning eth1 Interface doesn't support scanning : Operation not supported Trådløstkortet fungerer fint ellers. Så det er ikke noe feil med det. Bruker orinoco driverene. Er ikke sikker på hvilken versjon. Hvordan finner jeg det ut i s[ fall? Noen som har noen tips om det er noe som kan gjøres for å få dette til å virke. Her er iwconfig [root@ArchThinkpad orjanp]# iwconfig lo no wireless extensions. sit0 no wireless extensions. eth0 no wireless extensions. eth1 IEEE 802.11-DS ESSID:"" Nickname:"Prism I" Mode:Managed Access Point: 00:00:00:00:00:00 Bit Rate:11 Mb/s Tx-Power=15 dBm Sensitivity:1/3 Retry min limit:8 RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality=0/92 Signal level=-68 dBm Noise level=-122 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 Her er lspci [root@ArchThinkpad orjanp]# lspci 00:00.0 Host bridge: Intel Corp. 82845 845 (Brookdale) Chipset Host Bridge (rev 04) 00:01.0 PCI bridge: Intel Corp. 82845 845 (Brookdale) Chipset AGP Bridge (rev 04) 00:1d.0 USB Controller: Intel Corp. 82801CA/CAM USB (Hub #1) (rev 02) 00:1d.1 USB Controller: Intel Corp. 82801CA/CAM USB (Hub #2) (rev 02) 00:1d.2 USB Controller: Intel Corp. 82801CA/CAM USB (Hub #3) (rev 02) 00:1e.0 PCI bridge: Intel Corp. 82801BAM/CAM PCI Bridge (rev 42) 00:1f.0 ISA bridge: Intel Corp. 82801CAM ISA Bridge (LPC) (rev 02) 00:1f.1 IDE interface: Intel Corp. 82801CAM IDE U100 (rev 02) 00:1f.3 SMBus: Intel Corp. 82801CA/CAM SMBus (rev 02) 00:1f.5 Multimedia audio controller: Intel Corp. 82801CA/CAM AC'97 Audio (rev 02) 00:1f.6 Modem: Intel Corp. 82801CA/CAM AC'97 Modem (rev 02) 01:00.0 VGA compatible controller: ATI Technologies Inc Radeon Mobility M7 LW [Radeon Mobility 7500] 02:00.0 CardBus bridge: Texas Instruments PCI1250 PC card Cardbus Controller (rev 01) 02:00.1 CardBus bridge: Texas Instruments PCI1250 PC card Cardbus Controller (rev 01) 02:02.0 Network controller: Harris Semiconductor Prism 2.5 Wavelan chipset (rev 01) 02:08.0 Ethernet controller: Intel Corp. 82801CAM (ICH3) PRO/100 VE (LOM) Ethernet Controller (rev 42) Her er lsmod [root@ArchThinkpad orjanp]# lsmod Module Size Used by radeon 78336 1 ohci_hcd 23048 0 ehci_hcd 36488 0 irtty_sir 7552 0 sir_dev 18636 1 irtty_sir irda 144184 1 sir_dev crc_ccitt 2432 1 irda parport_pc 29252 0 parport 38600 1 parport_pc rtc 13260 0 pcspkr 4044 0 eepro100 32528 0 orinoco_pci 7552 0 orinoco 44172 1 orinoco_pci hermes 9472 2 orinoco_pci,orinoco yenta_socket 23560 0 rsrc_nonstatic 11648 1 yenta_socket pcmcia_core 51488 2 yenta_socket,rsrc_nonstatic snd_intel8x0m 19396 0 snd_intel8x0 34624 0 snd_ac97_codec 79224 2 snd_intel8x0m,snd_intel8x0 snd_pcm_oss 56224 0 snd_mixer_oss 21120 1 snd_pcm_oss snd_pcm 98564 4 snd_intel8x0m,snd_intel8x0,snd_ac97_codec,snd_pcm_oss snd_timer 27268 1 snd_pcm snd 59492 7 snd_intel8x0m,snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer soundcore 10848 1 snd snd_page_alloc 10244 3 snd_intel8x0m,snd_intel8x0,snd_pcm i2c_i801 8972 0 i2c_core 23296 1 i2c_i801 usbhid 47744 0 uhci_hcd 33424 0 usbcore 125560 5 ohci_hcd,ehci_hcd,usbhid,uhci_hcd shpchp 100996 0 pci_hotplug 34760 1 shpchp tsdev 8256 0 joydev 10560 0 evdev 9984 0 cpufreq_powersave 2176 0 cpufreq_userspace 5680 0 p4_clockmod 6164 0 speedstep_lib 4868 1 p4_clockmod freq_table 5008 1 p4_clockmod e100 37760 0 mii 5760 2 eepro100,e100 nls_cp437 6144 1 vfat 14976 1 fat 41884 1 vfat Lenke til kommentar
olear Skrevet 31. mars 2005 Del Skrevet 31. mars 2005 Driveren støtter ikke scanning. Last ned nyeste versjon og se om det fungerer. Se her for mer info: http://www.hpl.hp.com/personal/Jean_Tourri...ux/Orinoco.html Lenke til kommentar
Orjanp Skrevet 31. mars 2005 Forfatter Del Skrevet 31. mars 2005 (endret) Kan se ut som om det løser seg ved å bruke siste versjon av orinoco driverene. Denne er på tysk, så jeg skjønner egentlig ikke hva som sies, men [solved] skjønner jeg. http://lists.debian.org/debian-user-german...2/msg01628.html EDIT: En reload av siden kan lønne seg før jeg svarer på min egen tråd ja. Takk for tipset. Endret 31. mars 2005 av Orjanp Lenke til kommentar
