Gainward GeForce4 Ti4200 64MB DDR OC
Noen som har dette kortet og har prøvd å strekke grensene når det gjelder overklokking. Vurderer en liten oppgradering her:
AMD Athlon XP1800+
Asus A7V266-C
Crucial PC2700 256MB DDR
Chieftec Dragon Medium Tower med dør gul (!!!)
Gainward GeForce4 Ti4200 64MB DDR (Ultra/650TV/DVI)
+ noen regulerbare Enermax 80mm vifter.
SJEKK DETTE....
For overclocking the new Gainward card, we fired up RivaTuner, a software-based nVidia tweaker that works excellent for GeForce4-series cards. Using the stock cooling components without any extra fans, we set to see how high we could overclock this board. From it's default clock speed of 250 Core / 444 MHz DDR SDRAM, we were able to overclock to a whopping 310 MHz / 550 MHz DDR SDRAM. To put this in perspective, at 310 MHz, the core is running higher than the GeForce4 Ti4600 (300 MHz) and the memory is running at the same clock speed GeForce4 Ti4400. Quite an overclock, for such a little board!
kopiert fra
http://www.gamepc.com/labs/view_content.as...ward4200&page=3
dette gjelder både 128 og 64 mb en..
ser bra ut =)))))))))))))))
[ Denne Melding var redigert av: Ravenlord på 2002-07-02 14:56 ]
