The Cable Guy Skrevet 28. mars 2005 Del Skrevet 28. mars 2005 Har problem med att internetten dett ut ofte i par sekund! ei fer siden kan ikkje vises eller att ei dett ut av msn! har akkurat bytta adsl modem før att ei kunne opne porta, det er egentlig etter ei fikk d nye adsl modemet problemet kom... ei fikk ordna en ICMP sjekk til min ip for å sjå ka som skjer. som du ser på loggen så e d over 1500ms på mange og fer time out ofte, denna logen e på kvar ca 10sekund og når d e så håg ms då e d ikkje kontakt med noken! detta e veldig iriterande, e d linja eller adsl modemet? [20:56:52] Reply from 81.26.4*.*: RTT = 61 ms [20:56:54] Reply from 81.26.42.*: RTT = 79 ms [20:56:56] Reply from 81.26.42.*: RTT = 67 ms [20:57:00] Reply from 81.26.42.*: RTT = 1 911 ms [20:57:02] Reply from 81.26.42.*: RTT = 62 ms [20:57:06] Reply from 81.26.42.*: RTT = 1 728 ms [20:57:17] Request timed out. [20:57:20] Reply from 81.26.42.*: RTT = 464 ms [20:57:24] Reply from 81.26.42.*: RTT = 1 891 ms [20:57:28] Reply from 81.26.42.*: RTT = 1 881 ms [20:57:30] Reply from 81.26.42.*: RTT = 68 ms [20:57:32] Reply from 81.26.42.*: RTT = 60 ms [20:57:34] Reply from 81.26.42.*: RTT = 67 ms [20:57:36] Reply from 81.26.42.*: RTT = 63 ms [20:57:38] Reply from 81.26.42.*: RTT = 62 ms [20:57:40] Reply from 81.26.42.*: RTT = 65 ms [20:57:42] Reply from 81.26.42.*: RTT = 70 ms [20:57:46] Reply from 81.26.42.*: RTT = 1 885 ms [20:57:48] Reply from 81.26.42.*: RTT = 70 ms [20:57:52] Reply from 81.26.42.*: RTT = 1 877 ms [20:57:54] Reply from 81.26.42.*: RTT = 70 ms [20:57:58] Reply from 81.26.42.*: RTT = 1 881 ms [20:58:02] Reply from 81.26.42.*: RTT = 1 881 ms [20:58:04] Reply from 81.26.42.*: RTT = 61 ms [20:58:08] Reply from 81.26.42.*: RTT = 1 875 ms [20:58:10] Reply from 81.26.42.*: RTT = 59 ms [20:58:12] Reply from 81.26.42.*: RTT = 133 ms [20:58:16] Reply from 81.26.42.*: RTT = 1 817 ms [20:58:20] Reply from 81.26.42.*: RTT = 1 892 ms [20:58:22] Reply from 81.26.42.*: RTT = 63 ms [20:58:26] Reply from 81.26.42.*: RTT = 1 707 ms [20:58:28] Reply from 81.26.42.*: RTT = 64 ms [20:58:30] Reply from 81.26.42.*: RTT = 66 ms [20:58:32] Reply from 81.26.42.*: RTT = 83 ms [20:58:34] Reply from 81.26.42.*: RTT = 83 ms [20:58:38] Reply from 81.26.42.*: RTT = 1 864 ms [20:58:42] Reply from 81.26.42.*: RTT = 820 ms [20:58:44] Reply from 81.26.42.*: RTT = 60 ms Lenke til kommentar
Moltrez Skrevet 28. mars 2005 Del Skrevet 28. mars 2005 Det som er mest irriterende er at du skriver på dialekt, ergo vanskelig og forstå for folk som ikke snakker dialekten din. Men over til saken. Hvis leverandør ikke kan finne noen feil på linjen din, så er det sannsynlig at modemet er ustabilt. Du fikk jo problemet når du fikk nytt modem, så sjansen er jo stor for at det er modemet som har skylden. Ring og snakk med leverandøren, det er det enkleste. De sender nok et nytt modem, slik at du kan teste det, og se om det blir bedre da. Lenke til kommentar
