Nettverket på TG
Kva er det dei gjer feil år etter år etter år?
Tek dei ikkje lærdom av feilene dei gjorde året før?
Eg synes dei burde leige inn proffisjonell hjelp.
Dei som driv og konfigurerer det nettet kan umulig ha peiling.
Di får inn 3380000 kroner på bilettene.
[00:08] * Quits: denethor_ ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: GoD[bah] ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: Aciid ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: FornaTG ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: ahmuma ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: F|0e\aw ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: ZaiRoX ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: smutt ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: ZiZe ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: Desection ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: Golder_ ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: razer\ ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: pop^TG05 ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: Darkey|TG ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: ken_a ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: bfx ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: fiskeN- ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: bOMB\TG\ ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: Protac ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: Furui_v2 ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: huleboar ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: LeadbacK ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: Shibby ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: M4d_D4d ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: dustwave ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: SuprSlask ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: Zipp0^TG ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: Ragdoll ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: [sab] ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: Llandari ([email protected]) (Ping timeout: 492 seconds)
[00:08] * Quits: Dogagon ([email protected]) (Ping timeout: 492 seconds)
Dette her kan ikkje kalles stabilt nett. Og tenk på alle dei som ikkje er på IRC.
Eller skal man ikkje forvente at nettverket skal fungere på TG?
slutt og syt.. de HAR profesjonell hjelp..
det er bare det at det er så inni helvete vanskelig å teste om et nettverket virker med 5000 mennnesker før vi er her.
Dessuten har de i år en del nytt, som f.eks gigabit fra bordsvitsjene til core, og en hel del nytt og bedre utstyr enn det de har hatt tidligere.
Hvis de skulle ha fulgt "oppskriften din" (if it aint broke, dont fix it) ville vi ha sittet her med 10mbit coax nettverk, og kunne heller tatt det via adsl linjen vi har hjemme...
Skjønner godt at det er veldig vanskelig for tech:net å sette opp et såpass avansert nettverk, men det er veldig kjedelig for oss deltagere å sitte her med såpass ustabilt nett.
Og ja, jeg var her i fjor også, hvis noen skulle si noe om det ;)
TG crew er bra!
I giganettverk er alle pcr og alle switcher helt identiske + drivere + software for at alt skal gå i ett. Tenk deg tg, ingen som har helt lik pc omtrent, og ihvertfall ikke ligt nettverskort. Du får det kansje ikke mer ustabilt.
TG crew er bra!
Ustabiliteten har da ingen tiln med hva slags nettverkskort maskinene som er ute på nettverket har :dontgetit:
Det er nok DNS-serveren, og Coreswitchene det er noe rart med..
De som ikke skjønner at det blir litt trøbbel når 5000 stk skal koble seg til et LAN bør lese litt grunnleggende om data/nettverk. Hva er poenget ditt med billettinntektene? Det koster en del å ha 5 gbit til rådighet, ekstremt med strøm, leige av hall osv. Det kan også nevnes at det drives på frivillig basis, uten lønn.
Du spør om de ikke tar lærdom av tidligere år, men hva med deg? Har ikke du lært at nettet på TG hvert år har litt problem?
jonasdaman nedenfor: Ok, da sier det litt om ekspertisen som gjør sitt ytterste for at nettverket skal fungere optimalt :)
Endret av kim
Crew for 12 000 spenn men bortsett fra det er det frivilig
GO ARNE!!!
Ja, di slepper til og med lønnskostanene, like vel går det ikkje?
Så di har proff hjelp? Vel... så proffe var dei.
Hey, en rosa elefant. Den var ikke der for litt siden.
Lurer på om den kjenner den lilla giraffen som prater med Bård.
Det er da ganske mye som kan gå galt i et så stort nettverk. Hvor mange switcher og kabler er det ikke snakk om? Jeg har vært gjennom en del døde/crasha switcher/hubber, dårlige kabler, jordingsproblem mm som kan messe ting opp. Selv om de har peiling betyr det ikke at det ikke vil oppstå problemer, men problemene blir fikset relativt fort.
Endret av hanigjen
er det ikke lettere å holde kontroll og kjøre alt trådløst?
hmmm 5000 brukere der... tja skal vi være snill å si 5 brukere på hver basestasjon... 54 mbit/s : 5 brukere = 10 Mbit/s pr bruker... Teoretisk
1000 basestasjoner å holde kontroll på....
Alle som kommer med stasjonære PC'er uten trådløst nettkort...
Jau det hadde vel blitt tilnærma kaos..
Syns det er ganske slemt å kritisere de som jobber med nettverket. Det er en rimelig vanskelig jobb da. Det er ikke som med en bedrift som bruker mange hundretusen på planlegging og oppsett og dyre konsulenter. Her er det jo (sikkert dyktige) folk som stiller opp gratis og mer eller mindre gratis. Dere får heller gi dem et klapp på ryggen for at de sliter som faen for at dere skal ha det gøy ;)
