ROUTER og LAN trøbbel. Hjelp!
Jeg har postet etter hjelp på tweakxp, så jeg reposter posten her. Regner med at de fleste kan engelsk :smile: Vær så snill og ta en titt
Well, we bought a router today.
Hooked it up and everything is jolly dandy. Both computers can browse, get mail, ftp, etc - Internet works.
The problem is the LAN connection. We can't see each other in "My network places".
Heres the thing:
Say, we are users A and B
User A can ping user B both by name and ip (like, "Supercomputah" and 192.168.1.164)
User B can only ping user A by ip and not by name.
User A can not find himself, can't see his own shared files or otherwise connect to himself with Putername (share) or otherwise.
User B can see his own shared files with putername
As far as we can see, we have the exact same settings in TCP/IP properties and we've run Home Network Connection Wizard (or whatever it is called) and picked the same choices. Still user B can see his own files shared and user A can not, and user A can ping both name and ip of user B, while B can only ping user A by ip.
So, the main problem is that we can't connect to eachother without going through the internet, which is a drag with 128kbit upload (shared between the two of us)
As far as I can see there is no setting that restricts LAN useage... I may be wrong, I'm not a supertechwiz :razz:
I realize this is complicated, but if you have *any* hint, tip, reminder, etc. I'd really like to hear them. ALL suggestions are most welcome.
Thanks
(Jeg postet her først http://www.tweakxp.com/idealbb/view.asp?to...0-0EEFF75BDDDF}
[ Denne Melding var redigert av: tacomodo på 2002-06-30 11:28 ]
Du må sette maskin a til "enable netbios over tcp/ip" Dette er under:
Network and Dial-up Connections -> Local Area Connection -> Properties -> Internet Protocol -> Advanced -> Wins
Du må også passe på at man har en bruker på maskinen A som kan brukes av den som bruker maskin B. Hvis du ikke vil ha en spesiell bruker, så man må logge seg på, kan du enable quest brukeren
Dette er under:
My computer -> manage -> local users and groups -> users -> quest -> "huk vekk account is disabled"
Håper dette hjalp...
  • 2 uker senere...
Du ikke enable NetBIOS.
Du må ha med "Deling av filer og printere", "Klient for Microsoft-nettverk" og "Internett Protokoll, TCP/IP".
Gå inn på TCP/IP og sjekk om det er lik subnettmask (255.255.255.0 for eksempel)
Edit: Leif besøkte.
[ endret av Jimmy Pop den 2002-07-16 11:38 ]
