Orjanp Skrevet 19. mars 2005 Del Skrevet 19. mars 2005 Hei! Hvordan kan jeg fikse errorene jeg faar naar jeg starter X (xorg)? (WW) RADEON(0): Failed to set up write-combining range (0xe8000000,0x1000000) (EE) RADEON(0): Static buffer allocation failed. Disabling DRI. (EE) RADEON(0): At least 17325 KB of video memory needed at this resolution and depth. The XKEYBOARD keymap compiler (xkbcomp) reports: > Error: bad length in CompatMap > Output file "/var/tmp/server-0.xkm" removed Errors from xkbcomp are not fatal to the X server (EE) Couldn't load XKB keymap, falling back to pre-XKB keymap Har funnet ut at RADEON problemene kan vaere relatert til MTRR. Har ikke funnet noen loesning paa problemet. Grafikkortet mitt er Radeon mobile 7500, with 16MB ram. Lenke til kommentar
Gronz Skrevet 19. mars 2005 Del Skrevet 19. mars 2005 Kan du poste xorg.conf'en din? Lenke til kommentar
Orjanp Skrevet 19. mars 2005 Forfatter Del Skrevet 19. mars 2005 (endret) ********************************************************************** # Module section -- this section is used to specify # which dynamically loadable modules to load. # ********************************************************************** # Section "Module" # This loads the DBE extension module. Load "dbe" # Double buffer extension # This loads the miscellaneous extensions module, and disables # initialisation of the XFree86-DGA extension within that module. SubSection "extmod" Option "omit xfree86-dga" # don't initialise the DGA extension EndSubSection # This loads the font modules Load "type1" # Load "speedo" Load "freetype" # Load "xtt" # This loads the GLX module Load "glx" # This loads the DRI module Load "dri" EndSection # ********************************************************************** # Files section. This allows default font and rgb paths to be set # ********************************************************************** Section "Files" # The location of the RGB database. Note, this is the name of the # file minus the extension (like ".txt" or ".db"). There is normally # no need to change the default. RgbPath "/usr/X11R6/lib/X11/rgb" # Multiple FontPath entries are allowed (which are concatenated together), # as well as specifying multiple comma-separated entries in one FontPath # command (or a combination of both methods) # # FontPath "/usr/X11R6/lib/X11/fonts/TTF/" FontPath "/usr/X11R6/lib/X11/fonts/misc/" FontPath "/usr/X11R6/lib/X11/fonts/Type1/" # FontPath "/usr/X11R6/lib/X11/fonts/CID/" FontPath "/usr/X11R6/lib/X11/fonts/75dpi/" FontPath "/usr/X11R6/lib/X11/fonts/100dpi/" # FontPath "/usr/X11R6/lib/X11/fonts/local/" # FontPath "/usr/X11R6/lib/X11/fonts/Speedo/" # FontPath "/usr/X11R6/lib/X11/fonts/TrueType/" # FontPath "/usr/X11R6/lib/X11/fonts/freefont/" # The module search path. The default path is shown here. # ModulePath "/usr/X11R6/lib/modules" EndSection # ********************************************************************** # Server flags section. # ********************************************************************** Section "ServerFlags" # Uncomment this to cause a core dump at the spot where a signal is # received. This may leave the console in an unusable state, but may # provide a better stack trace in the core dump to aid in debugging # Option "NoTrapSignals" # Uncomment this to disable the <Crtl><Alt><Fn> VT switch sequence # (where n is 1 through 12). This allows clients to receive these key # events. # Option "DontVTSwitch" # Uncomment this to disable the <Crtl><Alt><BS> server abort sequence # This allows clients to receive this key event. # Option "DontZap" # Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching # sequences. This allows clients to receive these key events. # Option "Dont Zoom" # Uncomment this to disable tuning with the xvidtune client. With # it the client can still run and fetch card and monitor attributes, # but it will not be allowed to change them. If it tries it will # receive a protocol error. # Option "DisableVidModeExtension" # Uncomment this to enable the use of a non-local xvidtune client. # Option "AllowNonLocalXvidtune" # Uncomment this to disable dynamically modifying the input device # (mouse and keyboard) settings. # Option "DisableModInDev" # Uncomment this to enable the use of a non-local client to # change the keyboard or mouse settings (currently only xset). # Option "AllowNonLocalModInDev" EndSection # ********************************************************************** # Input devices # ********************************************************************** # ********************************************************************** # Core keyboard's InputDevice section # ********************************************************************** Section "InputDevice" Identifier "Keyboard1" Driver "kbd" # For most OSs the protocol can be omitted (it defaults to "Standard"). # When using XQUEUE (only for SVR3 and SVR4, but not Solaris), # uncomment the following line. # Option "Protocol" "Xqueue" Option "AutoRepeat" "500 30" Option "XkbRules" "xorg" Option "XkbModel" "pc101" Option "XkbLayout" "us" EndSection # ********************************************************************** # Core Pointer's InputDevice section # ********************************************************************** Section "InputDevice" # Identifier and driver Identifier "Mouse1" Driver "mouse" Option "Protocol" "ExplorerPS/2" Option "Device" "/dev/input/mice" Option "ButtonsNumber" "7" Option "Buttons" "7" Option "ZAxisMapping" "6 7" EndSection Section "Inputdevice" # IBM Thinkpad Touchpad Identifier "Mouse2" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/psaux" EndSection # ********************************************************************** # Monitor section # ********************************************************************** # Any number of monitor sections may be present Section "Monitor" Identifier "IBM Thinkpad T30 LCD" HorizSync 30-90 VertRefresh 50-100 EndSection # ********************************************************************** # Graphics device section # ********************************************************************** # Any number of graphics device sections may be present # Standard VGA Device: Section "Device" Identifier "Standard VGA" VendorName "Unknown" BoardName "Unknown" # The chipset line is optional in most cases. It can be used to override # the driver's chipset detection, and should not normally be specified. # Chipset "generic" # The Driver line must be present. When using run-time loadable driver # modules, this line instructs the server to load the specified driver # module. Even when not using loadable driver modules, this line # indicates which driver should interpret the information in this section. Driver "vga" # The BusID line is used to specify which of possibly multiple devices # this section is intended for. When this line isn't present, a device # section can only match up with the primary video device. For PCI # devices a line like the following could be used. This line should not # normally be included unless there is more than one video device # intalled. # BusID "PCI:0:10:0" # VideoRam 256 # Clocks 25.2 28.3 EndSection # Device configured by xorgconfig: Section "Device" Identifier "ATI Mobility Radeon 7500" Driver "radeon" # unsupported card #VideoRam 16384 # Insert Clocks lines here if appropriate EndSection # ********************************************************************** # Screen sections # ********************************************************************** # Any number of screen sections may be present. Each describes # the configuration of a single screen. A single specific screen section # may be specified from the X server command line with the "-screen" # option. Section "Screen" Identifier "Screen 1" Device "ATI Mobility Radeon 7500" Monitor "IBM Thinkpad T30 LCD" DefaultDepth 24 Subsection "Display" Depth 8 Modes "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" ViewPort 0 0 EndSubsection Subsection "Display" Depth 16 Modes "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" ViewPort 0 0 EndSubsection Subsection "Display" Depth 24 Modes "1400x1050" "1280x1024" "1024x768" "800x600" "640x480" ViewPort 0 0 EndSubsection EndSection # ********************************************************************** # ServerLayout sections. # ********************************************************************** # Any number of ServerLayout sections may be present. Each describes # the way multiple screens are organised. A specific ServerLayout # section may be specified from the X server command line with the # "-layout" option. In the absence of this, the first section is used. # When now ServerLayout section is present, the first Screen section # is used alone. Section "ServerLayout" # The Identifier line must be present Identifier "Simple Layout" # Each Screen line specifies a Screen section name, and optionally # the relative position of other screens. The four names after # primary screen name are the screens to the top, bottom, left and right # of the primary screen. In this example, screen 2 is located to the # right of screen 1. Screen "Screen 1" # Each InputDevice line specifies an InputDevice section name and # optionally some options to specify the way the device is to be # used. Those options include "CorePointer", "CoreKeyboard" and # "SendCoreEvents". InputDevice "Mouse1" "CorePointer" InputDevice "Mouse2" "SendCoreEvents" InputDevice "Keyboard1" "CoreKeyboard" EndSection # Section "DRI" # Mode 0666 # EndSection xkeyboard feilmeldingen kommer kun naar jeg starter x som bruker, ikke som root. Endret 19. mars 2005 av Orjanp Lenke til kommentar
olear Skrevet 19. mars 2005 Del Skrevet 19. mars 2005 (endret) (EE) RADEON(0): At least 17325 KB of video memory needed at this resolution and depth. Denne sier seg selv, du har for lite minne på skjermkort for den oppløsning. Med så lite minne ville jeg nok ha gått ned til 1024x768. Endret 19. mars 2005 av olear Lenke til kommentar
Orjanp Skrevet 19. mars 2005 Forfatter Del Skrevet 19. mars 2005 Det er en laptop. Altsaa en lcd skjerm, saa det er ikke aktuellt. Uansett saa hoeres det merkelig all den tid windows kjoerer uten problemer med 32bits fargedybde i samme opploesning. Lenke til kommentar
drall Skrevet 19. mars 2005 Del Skrevet 19. mars 2005 1400x1050x32/8=5880000B; 5880000/1024=5742.1875kB Lenke til kommentar
Gronz Skrevet 19. mars 2005 Del Skrevet 19. mars 2005 Prøv å ta #'en vekk fra #VideoRam 16384 og sette den til en fornuftig verdi, for eksempel: VideoRam 65536 Lenke til kommentar
olear Skrevet 19. mars 2005 Del Skrevet 19. mars 2005 Uansett saa hoeres det merkelig all den tid windows kjoerer uten problemer med 32bits fargedybde i samme opploesning. Delt minne? Se om du finner noe i BIOS. Lenke til kommentar
Orjanp Skrevet 20. mars 2005 Forfatter Del Skrevet 20. mars 2005 (endret) Fikset to av delene ved aa sette ned fargedybden til 16bit. Da gjenstaar det: (WW) RADEON(0): Failed to set up write-combining range (0xe8000000,0x1000000) The XKEYBOARD keymap compiler (xkbcomp) reports: > Error: bad length in CompatMap > Output file "/var/tmp/server-0.xkm" removed Errors from xkbcomp are not fatal to the X server (EE) Couldn't load XKB keymap, falling back to pre-XKB keymap Det viktigste aa faa ordnet er xkeyboard feilen, siden den gjoer at jeg ikke kan bruke setxkbmap til aa bytte spraak mellom norsk og engelsk. Erroren kom etter aa ha oppdatert foelgende programmer. Som tidligere nevnt, er det kun users som har problemet, ikke root. [03/17/05 09:26] upgraded arts (1.3.2-1 -> 1.4.0-4) [03/17/05 09:26] upgraded atk (1.9.0-1 -> 1.9.1-1) [03/17/05 09:26] upgraded db (4.2.52.2-2 -> 4.3.27-2) [03/17/05 09:26] upgraded evolution (2.0.3-2 -> 2.2.0-1) [03/17/05 09:26] upgraded evolution-data-server (1.0.3-2 -> 1.2.0-1) [03/17/05 09:26] upgraded gal (2.2.4-1 -> 2.4.0-1) [03/17/05 09:26] upgraded gconf (2.8.1-1 -> 2.10.0-1) [03/17/05 09:26] upgraded gecko-sharp (0.6-2 -> 0.6-3) [03/17/05 09:26] upgraded gnome-common (2.8.0-8 -> 2.8.0-9) [03/17/05 09:26] upgraded gnome-keyring (0.4.1-1 -> 0.4.2-1) [03/17/05 09:26] upgraded gnome-vfs (2.8.3-4 -> 2.10.0-1) [03/17/05 09:26] upgraded gthumb (2.6.3-1 -> 2.6.4-2) [03/17/05 09:26] upgraded gtkhtml (3.2.4-1 -> 3.6.0-1) [03/17/05 09:26] upgraded gtk-sharp (1.0.6-1 -> 1.0.8-1) [03/17/05 09:26] upgraded gtksourceview (1.1.1-1 -> 1.2.0-1) [03/17/05 09:26] upgraded heimdal (0.6.3-2 -> 0.6.3-3) [03/17/05 09:26] upgraded k3b (0.11.20-1 -> 0.11.21-1) [03/17/05 09:26] installed jasper (1.701.0-1) [03/17/05 09:26] warning: /opt/kde/share/config/kdm/kdmrc saved as /opt/kde/share/config/kdm/kdmrc.pacorig [03/17/05 09:26] warning: /opt/kde/share/config/kdm/backgroundrc saved as /opt/kde/share/config/kdm/backgroundrc.pacorig [03/17/05 09:26] installed kde-common (3.4.0-6) [03/17/05 09:27] upgraded kdelibs (3.3.2-5 -> 3.4.0-5) [03/17/05 09:27] installed gstreamer (0.8.9-1) [03/17/05 09:27] upgraded kdeaccessibility (3.3.2-1 -> 3.4.0-4) [03/17/05 09:27] installed cyrus-sasl (2.1.20-2) [03/17/05 09:27] installed sysfsutils (1.2.0-1) [03/17/05 09:27] installed pmount (0.6-1) [03/17/05 09:27] upgraded kdebase (3.3.2-4 -> 3.4.0-5) [03/17/05 09:27] upgraded kdepim (3.3.2-2 -> 3.4.0-5) [03/17/05 09:27] installed gst-plugins (0.8.8-1) [03/17/05 09:27] upgraded kdemultimedia (3.3.2-1 -> 3.4.0-4) [03/17/05 09:27] upgraded kdegames (3.3.2-1 -> 3.4.0-4) [03/17/05 09:27] upgraded kdeaddons (3.3.2-3 -> 3.4.0-5) [03/17/05 09:27] upgraded kdeadmin (3.3.2-1 -> 3.4.0-5) [03/17/05 09:28] upgraded kdeartwork (3.3.2-1 -> 3.4.0-4) [03/17/05 09:28] upgraded kdebindings (3.3.2-3 -> 3.4.0-5) [03/17/05 09:28] upgraded kdeedu (3.3.2-1 -> 3.4.0-4) [03/17/05 09:28] upgraded kdegraphics (3.3.2-3 -> 3.4.0-4) [03/17/05 09:28] installed qca (1.0-1) [03/17/05 09:28] installed qca-tls (1.0-1) [03/17/05 09:28] installed perl-net-ssleay (1.25-1) [03/17/05 09:28] installed perl-io-socket-ssl (0.95-1) [03/17/05 09:28] upgraded kdenetwork (3.3.2-1 -> 3.4.0-5) [03/17/05 09:28] upgraded kdesdk (3.3.2-2 -> 3.4.0-5) [03/17/05 09:28] upgraded kdetoys (3.3.2-1 -> 3.4.0-4) [03/17/05 09:28] installed net-snmp (5.2.1-1) [03/17/05 09:28] installed dosfstools (2.10-1) [03/17/05 09:28] upgraded kdeutils (3.3.2-1 -> 3.4.0-5) [03/17/05 09:29] upgraded kernel26 (2.6.10-3 -> 2.6.11.3-1) [03/17/05 09:29] upgraded libbonoboui (2.8.1-1 -> 2.8.1-2) [03/17/05 09:29] upgraded libgda (1.2.0-1 -> 1.2.0-2) [03/17/05 09:29] upgraded libgnome (2.8.0-1 -> 2.10.0-1) [03/17/05 09:29] upgraded libgnomecanvas (2.8.0-1 -> 2.10.0-1) [03/17/05 09:29] upgraded libgnomeprint (2.8.2-1 -> 2.10.1-1) [03/17/05 09:29] upgraded libgnomeprintui (2.8.2-1 -> 2.10.1-1) [03/17/05 09:29] upgraded libgnomeui (2.8.0-2 -> 2.10.0-1) [03/17/05 09:29] upgraded librsvg (2.8.1-3 -> 2.9.5-1) [03/17/05 09:29] upgraded liferea (0.9.0b-2 -> 0.9.1-1) [03/17/05 09:29] upgraded openldap (2.2.23-1 -> 2.2.23-2) [03/17/05 09:29] upgraded pam (0.78-3 -> 0.78-4) [03/17/05 09:29] upgraded pango (1.8.0-1 -> 1.8.1-1) [03/17/05 09:29] upgraded perl (5.8.6-1 -> 5.8.6-2) [03/17/05 09:29] upgraded python (2.4-2 -> 2.4-3) [03/17/05 09:30] upgraded qt (3.3.4-3 -> 3.3.4-5) [03/17/05 09:30] upgraded ruby (1.8.2-3 -> 1.8.2-4) [03/17/05 09:30] upgraded startup-notification (0.7-1 -> 0.8-1) [03/17/05 15:37] synchronizing package lists [03/17/05 15:38] starting full system upgrade [03/17/05 15:38] upgraded gal (2.4.0-1 -> 2.4.1-1) [03/17/05 15:38] upgraded gtkhtml (3.6.0-1 -> 3.6.1-1) [03/17/05 15:38] upgraded libsoup (2.2.2-1 -> 2.2.3-1) Endret 20. mars 2005 av Orjanp Lenke til kommentar
drall Skrevet 20. mars 2005 Del Skrevet 20. mars 2005 Hvorfor har du valgt "us" XkbLayout? Videre, har du virkelig bare 101 taster? 105 er normalt på europeisk tastatur, mulig laptoper har noe ferre. Om du kjører framebuffer som bruker mtrr kan det skape konflikt med X. Jeg prøvde også å poengtere at 1400x1050x32 ikke burde ta mer enn 5,7MB vram under normale omstendigheter. Så vidt jeg veit er 16MB>5,7MB. Snålt at X hisser seg opp mht dette. Lenke til kommentar
Orjanp Skrevet 20. mars 2005 Forfatter Del Skrevet 20. mars 2005 Synes ogsaa det virker merkelig at X trenger saa mye minne. Jeg starter med us fordi jeg foretrekker us layout naar jeg programmerer og driver paa i terminal. Det fungerer foroevrig ikke aa velge no p.g.a. xkeyboard erroren. Lenke til kommentar
