Server-eller-patch-relatert-jamring-tråden
Dette er for dårlig *jamre*..
Og angående skole/wow, jeg holdt også på å miste plassen min sånn på ekte :p Satt oppe til klokka 3 dagen før, og skulle opp klokka 6, var dautrøtt, men det gikk da :)
6730089[/snapback]
Eneste jeg har mista pågrunn av wow er nattesøvn, sauer ser jeg annerledes på og.
on topic..gah!! jamre
Endret av vetle
i Følge de i guilden som også har konto i USA har snakka med GM der nå. de sier servrene er nede pga en STOR bugg...
hvis man kommer inn i 1 BG med folk fra annen server kan du være uheldig og komme ut av BG på den servern
6730104[/snapback]
Poster denne...
can't confirm these news, but this is what I've heard so far:
- People after finishing a BG have ended up on wrong server
- UBRS is broken - the door at Rend's room won't open after Rend dies
- If you plan on killing Razuvious, keep one of the adds alive 'till the loots are on their rightful owners - people have been having nice issue of ending up to character screen once the combat ends, and after logging back in, found 'emselves dead around alterac.
- C'Thun has been buffed - the old god will now shoot the first one to enter only once, and then start smashing the raid - so you got about couple seconds to enter the room AND spread out
- The mind flayer trashes before C'Thun now do 4 simultaneous mind flays on 4 targets
- People have been falling through floor/ground in Orgrimmar
- People have received error message "Instance cannot be found" after using Hearthstone
- 1 Alliance party and 2 Horde parties ended up to _same_ Stratholme instance
- Paladins - do NOT mount in in neutral towns with your summonable mounts - you end up in combat and the guards will aggro you
edit:
And known bugs list:
=-=-=-=-=-=-=-=-=-=GENERAL=-=-=-=-=-=-=-=-=-=
Environment
# Eating and drinking is interrupted in Eastern Plaguelands
# Silithyst dust cloud does not properly follow characters
Spells, Talents, & Abilities
# Certain effects that proc off of spells can be resisted despite having 100% chance to be applied.
Escape Artist does not always dispel crippling poison
Quests
# The mobs from the quest Dreadsteed of Xoroth do not despawn if the party wipes.
# The quest Shadows of Doom is not correctly labeled as an elite quest.
# Totems and pets killing Baron Rivendare can prevent the completion of Dead Mans Plea.
Items
# Wand damage displays white in scrolling combat text but yellow in the chatlog.
# Wristwraps of Undead Slaying are playing the wrong sound when moved in the inventory.
# Thunderfury, Blessed Blade of the Windseeker is not being rendered correctly on some clients that have Smooth Shading enabled.
# Enigma robe has no icon or model.
# Thunderfury slow effect is incorrect.
User Interface
# Playing in windowed mode and adjusting the window size to an odd amount can replace all names with .
# Logging in defaults the chat pane to the last user created pane instead of General.
# Opening items does not put a message in the combat log
Battlegrounds
# Players can get stuck in the Alterac Valley towers when warcry buffed.
# Stamina and intellect granted from random item attributes are causing players to resurrect with less than full health and mana in battlegrounds.
# It is possible to queue up for a battleground at a battlemaster yet exit the battleground at the location of the battleground portal.
=-=-=-=-=-=-=-=-=-=CLASSES=-=-=-=-=-=-=-=-=-=
Druid
# Cat form claw ability is playing an inappropriate sound.
# Barkskin is being displayed incorrectly on the druid when shapeshifted.
# The 6 Piece Blessing of the Claw effect of Dreamwalker armor set causes you to stand up.
Hunter
Spells, Talents & Abilities
# Surefooted does not give a resist message when the player resists a spell.
# Hunters will remain standing for several seconds when casting Feign Death, if the camera location is not on the character at the time of the cast.
# Revive Pet returns more than 15% life if the player has the Endurance Training talent.
# Eagle Eye is ending early when targeted far away from the caster.
# There are animation issues with Frost Trap when combined with Clever Traps.
# There is a period after casting Eyes of the Beast, before gaining control the pet, that will break the spell if players attempt to move.
# Players can interact with Battleground flags while frostrapped.
Pets
# The tooltips of pet abilities refer to the player rather than to the pet.
# Hunter pets may change color when revived, summoned, or when zoning.
# Pets do not have animations for several abilities.
# Pet icons may not update properly in the stables window after retrieving a pet. Temporary Fix:Typing in /console reloadui should provide a workaround for now.
# Lightning breath is not affected by Ferocity
Items
# The 3-piece Dragonstalker Armor set bonus remains after pieces are unequipped.
# The Field Marshal's Chain Helm appears dark in direct light and bright in shadow.
Mage
# The proper number of summoned food/water is not displayed in chat.
# Casting Polymorph on a player that is currently immune to Polymorph due to diminishing returns does not display the Immune flag over the target's head and the 15 second cool down for diminishing returns is not reset.
# Using Blink while in lava causes the player to go to the deepest end.
# The debuffs from Fireball and Pyroblast are not considered magic.
Items
Paladin
# Combat log messages generated when a player gains mana from Seal of Wisdom or Judgment of Wisdom do not attribute the mana gains to any particular source.
# The Scorpid Hunters Slowing Poison is not removed by Blessing of Freedom.
# Holy Light is reporting twice in the combat log to enemy players.
# The added armor effect from Improved Lay on Hands is appearing on the character sheet as a permanent armor value.
# Reckoning resets the auto-attack timer.
# Summoning paladin mount causes player to enter combat.
Priest
# If a Horde Priest cancels Mind Control that is on an Alliance player who was previously attacking a Horde guard, the guard will become hostile towards the Horde Priest (this works from Alliance to Horde as well).
# The graphic for Power Word: Shield does not display properly when in Shadowform.
# Casting Mind Flay consecutively can cause the second Mind Flay to cast with no spell animation.
# Mana Burn does not interrupt flag captures.
Rogue
# The full graphical effect and sound is being played on rogue finishing moves when they miss.
# Threat reduction modifiers such as Blessing of Salvation and Tranquil Air Totem are applied to Feint, making it less effective.
# You receive an improper message when attempting to stealth while under the effects of Faerie Fire.
# Gouge can proc poisons
# Frost Trap aura breaks stealth
Shaman
# Mana Tide will sometimes tick 3 or 5 times instead of consistently at 4.
# Chromaggus's Brood Afflictions will target totems.
# Fire Nova Totem is damaging players in neutral towns without drawing aggro from the guards.
Warlock
# Players can keep the Demonic Sacrifice buff along with a pet if the pet was resurrected.
# Curse of Agony does not deal damage if the caster dies.
# Rank 2 of Improved Firebolt is not consistent with its tooltip.
# Eye of Killrog does not die from falling damage
Pets
# The Succubus can despawn before it can be resurrected.
Items
# The 5-piece Felheart Raiment set bonus does not always grant the Demonic Ally buff.
# The 4 piece Plaguheart set bonus is not applying to corruption.
Warrior
# Whirlwind increases weapon skill when not attacking mobs.
# Defensive Stance is affecting environmental damage.
6730104[/snapback]
Poster denne...
6730136[/snapback]
Hehe, ikke rart de bruker litt ekstra tid.
Endret av Majestet
ROFLMAO !! akkurat som jeg forutså!! :dribble: :!:
LOLZ!!11ONEOENELEVEN1
6730170[/snapback]
Det hadde vært litt kjedelig tbh..
6730180[/snapback]
neida, gratis character transerfer :D
6730185[/snapback]
Til et sted du ikke kjenner en eneste person..
Warrior
Dette har jo vært så lenge jeg kan huske. Def.stance og teleport gadgetzan er fin f.eks.
Endret av likferd
