Fedora Core 3 and Debian 3.0 r4 dual-boot problem
Jeg håper noen kan hjelpe meg med dette. Har crossposted på linuxquestions.org og fedoraforum.org, men ingen svar så langt.
Hi.
I have currently one harddisk and 3 operating systems on it (Windows XP, Fedora Core 3 & Debian 3.0 r4). It has 6 partitions and it looks like this:
/dev/hda1 * 1 2547 20458746 7 HPFS/NTFS
/dev/hda2 2548 9729 57689415 f W95 Ext'd (LBA)
/dev/hda5 2548 4506 15735636 7 HPFS/NTFS
/dev/hda6 4507 8423 31463271 83 Linux
/dev/hda7 8424 8547 995998+ 82 Linux swap
/dev/hda8 8548 9729 9494383+ 83 Linux
I have first installed Windows XP. Then I've installed Fedora Core 3 on /dev/hda6 with only "/" (no /boot & swap). I've also installed grub in Fedora as my boot loader and I can load both Windows and Fedora. This is how my menu.lst looks:
title Fedora Core (2.6.10-1.770)
root (hd0,5)
kernel /boot/vmlinuz-2.6.10-1.770_FC3 ro root=LABEL=/ rhgb quiet
initrd /boot/initrd-2.6.10-1.770_FC3.img
title Fedora Core (2.6.9-1.667)
root (hd0,5)
kernel /boot/vmlinuz-2.6.9-1.667 ro root=LABEL=/ rhgb quiet
initrd /boot/initrd-2.6.9-1.667.img
title Windows XP
rootnoverify (hd0,0)
chainloader +1
Finally, I've installed Debian 3.0 r4 with swap on /dev/hda7 and "/" on /dev/hda8. I have NOT installed lilo. Now I wanted to modify my menu.lst or grub.conf as described here:
enterprise.linux.com/enterprise/04/12/23/2033238.shtml?tid=129&tid=47
It says there that I should copy 3 files from /boot on my Debian partition (/dev/hda8) to /boot on my current, Fedora partition (/dev/hda6). However, I could not locate all those 3 files. The required files are:
initrd-xxx.img
System.map-xxx
vmlinuz-xxx
And here is what I have in /boot on Debian root:
lrwxrwxrwx 1 root root 11 Mar 17 20:03 boot.b -> boot-menu.b
-rw-r--r-- 1 root root 7988 Apr 13 2002 boot-bmp.b
-rw-r--r-- 1 root root 6204 Apr 13 2002 boot-compat.b
-rw-r--r-- 1 root root 7964 Apr 13 2002 boot-menu.b
-rw-r--r-- 1 root root 6204 Apr 13 2002 boot-text.b
-rw-r--r-- 1 root root 728 Apr 13 2002 chain.b
-rw-r--r-- 1 root root 3888 Mar 17 20:00 config-2.2.20-idepci
-rw-r--r-- 1 root root 656 Apr 13 2002 os2_d.b
-rw-r--r-- 1 root root 224124 Mar 17 20:00 System.map-2.2.20-idepci
-rw-r--r-- 1 root root 665509 Mar 17 20:00 vmlinuz-2.2.20-idepci
Although, I am missing initrd-xxx.img file.
Thank you for your help.
Kan du ikke bare sette opp debians bootloader på hda8 og "chainloade" som du gjør med xp da?
edit: eller er woodys lilo for gammel til å støtte booting langt inne på disken?
Endret av drall
Jeg er ny i linux, så kunne dere forklare med eksempler hva jeg skal gjøre? Hvordan skal man "chainloade"?
For å chainloade velger du i Debian-installasjon å installer LILO på partisjonen hvor Debian er installert (f.eks. /dev/hda3) i stedet for selve MBR'en på disken (f.eks. /dev/hda). Når du har gjort det, åpner du filen /boot/grub/menu.lst eller /boot/grub/grub.conf og legger til dette på bunnen:
title Debian Woody
root (hd0,7)
chainloader +1
