ATis svar på SLI er her
Dette er nok det mest interesante med AMR :
Anyway ATI has its marchitecture ready and we learned that you will be able to do ATI Multiple VPU with two different cards. You will be able to plug one X800 and one X850 cards together and faster card will downscale to the slower and will work simultaiously with it.
Med Andre ord, kjøp deg et x850xt AMR i dag og oppgrader senere til et ekstra x950xt AMR i morgen, du slipper å tenke på å kjøpe nøyaktig samme kort som du må med nvidias SLI løsning.
*snip*
Med andre ord, hvis ett X950XT whatever kort, yter bedre single enn 2x X850 kort gjør i dual, så nedskalerer man kortet ved å kjøre det i dual..... :w00t: jeg legger spesielt vekt på ordene : and faster card will downscale
Kjempegreier.... :whistle:
Her er litt nytt fra CeBIT dekning... Stoler mer på dem enn The Inq.
ATI does not reveal the Multi-VPU concepts to the general public, but for its add-in card partners it has posted a brief overview of its technology in its roadmap update. At least for now there is one important update from what was previously reported – ATI wants two identical graphics cards to be installed, not two different boards as said before based on information from unofficial sources. Here is what ATI says to its partners:
- Multiple ATI RADEON X800 XT boards cooperatively rendering a single frame;
- Requires two physical x16 connectors on the mainboard;
- Load balancing and synchronization implemented entirely in software;
- No physical connector requires between devices;
- Currently assumes two identical graphics devices installed in both connectors;
- Offers several user selectable modes of multi-processing;
- Works with any PCIe north bridge.
Høres ut som om du kan koble to ATi kort på nVidia sine chipset også, og det er bra, siden ATi sine chipset ikke har noen bra south bridge
Etter hva som står på esken så kaller kanskje ATI sin løsning for ULI, hvis det er riktig så er det vel dårlig oppfinnsomhet. Spesielt siden de har kalt den noe annet en stund.
Nei, nei... ULI er navnet på de som har produsert syd bruen. De hete ALI før, hvis det lyder kjent...
De siste ATI-driverene la til ordentlig støtte for OpenGL 2.0. Vet ikke om det hjelper noe på ytelse, men de har nå gjort det. Noen som har sett noen tester kanskje?
Det har ikke noe å si på ytelsen, det er bare at de tilbyr flere OpenGL instruksjoner. Det er ingen spill som bruker OpenGL 2.0 instruksjoner enda
ja, men ikke på langtener så mye svakere som det er i doom3.
så må dere huske at ati er overlegene i d3d også
Det er bare tull, nVidia yter på nivå med ATi i flere DirectX applikasjoner, bedre i noen også
Neste generasjon konsoller blir mer og mer attraktive for meg. Alle spillene kommer jo ut som konsoll-spill uansett, og det blir for dumt å måtte legge ut 5000,- kr for å kunne spille dataspill til kr 399,- pr stykk. Som viranth sier: SLI/AMR vil føre til økte HW-krav for 3D-spill.
Godt poeng! Og hadde bare de som laget spillene giddet å optimalisere de skikkelig, hadde kravene til grafikkort også vært mye mindre.....
