MindTooth Skrevet 10. mars 2005 Del Skrevet 10. mars 2005 (endret) Logitech® MX™518 Gaming-Grade™ Optical Mouse. If you´re going to play at the highest level, you need a mouse that gives you an edge. The Logitech® MX™ 518 Gaming-Grade™ Optical Mouse does exactly that with its ultra-high resolution, 1600-dpi MX™ Optical Engine that delivers lightning-fast response and mirror-smooth tracking. The MX™ 518´s advantages don´t stop there. You get instant, on-the-fly sensitivity adjustment that lets you switch effortlessly from pixel-precise targeting to fast-twitch acceleration, without any software. And the contoured grip ensures peak performance and comfort, even during the most intense gaming sessions. Litt info: Sensitivity Adjustment Dedicated controls to switch “on-the-fly” from pixel-precise targeting to fast-twitch evasive moves. Advanced software Battle-tune your MX™ 518 with up to five custom sensitivity settings. Superior grasp Sculpted thumb support and contoured grip for incredible comfort during even the longest gaming sessions. 1,600-dpi resolution Ultra-high resolution, 1600-dpi MX™ Optical Engine delivers pixel precise tracking. (Info hentet ifra Logitech.com) --------------------------------------------------------------- Pris: Den billigste i prisguiden nå, ligger hos Komplett.no. De selger den for 395,- (Pluss porto) Linker: Produktside: (link) Review by ExtremeTech: (link) Prisguide: (link) Endret 28. mars 2005 av Birger_Nord Lenke til kommentar
MindTooth Skrevet 10. mars 2005 Forfatter Del Skrevet 10. mars 2005 Denne virker gill... Denne må i innkjøp av Lenke til kommentar
ttt Skrevet 10. mars 2005 Del Skrevet 10. mars 2005 den virker absolutt spennende. veit ikkje om eg kjem til å bytte ut min kjære mx500, men vi får sjå. håper at gamer kjem til å teste den. Lenke til kommentar
Der Kommissar Skrevet 10. mars 2005 Del Skrevet 10. mars 2005 ttt skrev: den virker absolutt spennende. veit ikkje om eg kjem til å bytte ut min kjære mx500, men vi får sjå. håper at gamer kjem til å teste den. Yay, har en mx500 her og! Men den derre musa skal jeg nok ikke kjøpe med det første Lenke til kommentar
MindTooth Skrevet 10. mars 2005 Forfatter Del Skrevet 10. mars 2005 Har Logotech MX510™ ifra før. Så det er liten nytte å bytte... Bare det instillingsprogrammet hadde kommet til MX510™ også! Lenke til kommentar
Archangel Skrevet 10. mars 2005 Del Skrevet 10. mars 2005 Er veldig nysgjerrig på denne har lenge tenkt å skaffe meg Razor Diamondback, men nå venter jeg til det kommer review av denne og en sammenlikning. Lenke til kommentar
Heimen Skrevet 10. mars 2005 Del Skrevet 10. mars 2005 Jeg som nettopp kjøpte meg en MX510..... Lenke til kommentar
Hr. Jenssen Skrevet 10. mars 2005 Del Skrevet 10. mars 2005 Så dette er altså RaZer's konkurrent... Jeg har RaZer Diamondback Magma. Likte den ikke, den var alt for sensitiv. Oj så dum jeg hadde vært! Jeg hadde jo glemt å installere driveren! Oj så dum jeg var! Jeg installerte driveren! Tror muligens MX518 kan bli litt smashy. (liker 510 godt, så hvorfor ikke?) Lenke til kommentar
Flyndresnik Skrevet 12. mars 2005 Del Skrevet 12. mars 2005 Hmmm.. hvorfor har de ikke brukt sensoren i MX1000? Var en trådmus med lasersensor jeg hadde forventet som den neste spillemusen fra Logitech. Lenke til kommentar
fenris1911 Skrevet 12. mars 2005 Del Skrevet 12. mars 2005 Sitat [iC' date=11/03/2005 : 00:04] Jeg har RaZer Diamondback Magma. Likte den ikke, den var alt for sensitiv. Du veit du kan stilla ned sensitiviten i windows? Eg har ikkje drivarane installert, men bruker allikevel 30 cm for å snu meg 360 grader. Lenke til kommentar
fenris1911 Skrevet 12. mars 2005 Del Skrevet 12. mars 2005 Det som nesten er det viktigaste for min del: Er overflata ru slik som på MX500, eller glatt slik som på MX510? Lenke til kommentar
MindTooth Skrevet 12. mars 2005 Forfatter Del Skrevet 12. mars 2005 Tenker den er glatt.. Lenke til kommentar
MindTooth Skrevet 12. mars 2005 Forfatter Del Skrevet 12. mars 2005 (endret) Edit1: Dobbel post... Endret 12. mars 2005 av Birger_Nord Lenke til kommentar
Tahiro Skrevet 12. mars 2005 Del Skrevet 12. mars 2005 Digger Razer Diamondback men jeg blir sliten av den siden du ikke kan hvile hånden på den. MX500 var jo en kongemus og tror jeg kommer til å bestille denne gitt. Lenke til kommentar
.tomf Skrevet 12. mars 2005 Del Skrevet 12. mars 2005 (endret) Damn! Jeg som kjøpte meg mx510 for noen uker siden. Edit: Btw, det instillings-programmet så jævlig snedig ut, håper de slipper det til mx510 i en nær fremtid(lite trolig). Endret 12. mars 2005 av TomFu Lenke til kommentar
thomassit0 Skrevet 12. mars 2005 Del Skrevet 12. mars 2005 digger min trofaste 2 år gamle MX700 jeg Lenke til kommentar
anon12234 Skrevet 12. mars 2005 Del Skrevet 12. mars 2005 Microsoft Intelli Explorer 3.0, ingen over. ingen ved siden!. R.I.P produksjon av den. må min aldri dø Lenke til kommentar
Solid Skrevet 13. mars 2005 Del Skrevet 13. mars 2005 Archangel skrev: Er veldig nysgjerrig på denne har lenge tenkt å skaffe meg Razor Diamondback, men nå venter jeg til det kommer review av denne og en sammenlikning. Ditto, ser fristende ut begge to. :yes:a Lenke til kommentar
Elendil Skrevet 13. mars 2005 Del Skrevet 13. mars 2005 http://www.dinside.no/php/art.php?id=210600 Lenke til kommentar
