furier Skrevet 10. mars 2005 Del Skrevet 10. mars 2005 (endret) Hvor mye er denne pcen verd? 21000NOK ink moms ? ----------------------------------------------------------------------- Dette er en rå PC som har det meste!! Dette er innholdsfortegnelsen: Excellent wireless performance with Intel® Centrino™ Mobile Technology (select models) * Available with Microsoft® Windows® XP * Standard battery life up to 5.5 hours6 * IBM Active Protection System protects your hard drive * Most secure wireless with Embedded Security Subsystem (select models) * T42p is the thinnest and lightest Making the power of a workstation mobile. Certified for graphics-intensive applications, ThinkPad T42p, T41p and T40p mobile workstations offer high performance in a thin and light notebook. Performance features abound in highly portable ThinkPad T Series notebooks, which start at about 26.6 mm thin14 and have a travel weight starting at only 2.1 kg2. Select new ThinkPad T42 models offer larger 15.1" TFT displays that are ideal for viewing spreadsheets, presentations, Web pages and more and are still only 31-36 mm14 thin. They offer one of the latest Intel® Pentium® M processors on select models, and up to 128MB graphics. Select models also offer all-day computing (up to 9.5 hours6 with the optional ThinkPad T40 Series High Capacity Li-Ion Battery plus the optional ThinkPad Ultrabay Slim Li Polymer Battery). It's like a single tank of fuel for the entire day's journey. Flexible optical and storage solutions available in ThinkPad notebooks include an integrated, easy-loading modular bay for fast swapping of optional IBM Ultrabay™ optical and storage devices. [ultrabay optical and storage device options let you tailor your ThinkPad notebook to meet your computing needs.] The Ultrabay Slim, available on ThinkPad T42, T41, and T40 models, enhances portability by supporting lighter, thinner 9.5mm device options, including the ThinkPad Multi-Burner Ultrabay Slim Drive (standard on select models). High-performance wireless networking to help increase mobility and productivity is easy with integrated IBM 11b/g Wi-Fi® wireless technology — now available in select ThinkPad T42 notebooks10. This technology not only offers the flexibility of choice but also provides a cost effective wireless solution for customers who don't need 802.11a technology. Other ThinkPad T Series models offer a variety of integrated Wi-Fi wireless solutions. And Wi-Fi wireless upgradable32 models are also available, allowing you to experience the freedom of wireless networking when you're ready using the new optional Wi-Fi adapters. Cisco compatibility is provided on select ThinkPad T42 and T41 notebooks, which are rigorously tested by a Cisco Systems®-authorised test facility to verify they'll work with appropriate Cisco products. The Cisco Compatible Extensions (CCX) Program for wireless LAN devices provides proven compatibility with key security features of Cisco infrastructure products. Optimised for connectivity, select ThinkPad T Series notebooks feature up to five built-in communications capabilities: Wi-Fi wireless10, Bluetooth® technology, Ethernet, 56K V.923 L-designed modem and an integrated IrDA port. All models come with RJ-45 and RJ-11 ports. High-speed Gigabit Ethernet connectivity is featured on select ThinkPad T Series notebooks. The Gigabit Ethernet standard provides speeds up to 10 times faster30. than existing 10/100 Ethernet technology, helping to transfer information quickly and increase productivity. Image compatability for easier rollouts... The ThinkPad T42 and T41 preloaded software image is compatible with ThinkPad X40, X31, T40, R51, R50, and R40 models. This makes for easier rollouts and helps save time and reduce costs by simplifying deployment and image management — great for enterprises rolling out a combination of models. TheThinkPad UltraNav multipointing system was created with ease-of-use in mind. It combines the latest full-function TrackPoint® pointing device with an IBM-customised touch pad. A product of detailed research and analysis, this innovative tool lets you work the way you want. A choice of three TrackPoint cap designs allows you to further customise your ThinkPad notebook. TheIBM UltraConnect antenna — just one of the wireless performance features on ThinkPad T Series notebooks — is built into the display cover for optimal signal reception24. This combined design supports IEEE 802.11a, 802.11b and 802.11g wireless technologies to help maximise coverage and performance for improved wireless LAN connectivity around the world. TheIBM UltraConnect antenna — just one of the wireless performance features on ThinkPad T Series notebooks — is built into the display cover for optimal signal reception24. This combined design supports IEEE 802.11a, 802.11b and 802.11g wireless technologies to help maximise coverage and performance for improved wireless LAN connectivity around the world. Software Operating system provided: Microsoft Windows XP Professional Communication/networking: Access IBM, IBM Access Connections, IBM Drive Letter Access, IBM Record Now, IBM Rescue and Recovery with Rapid Restore Device drivers/utilities: Norton AntiVirus 2004, PC-Doctor Multimedia applications: InterVideo WinDVD Creator, Intervideo WinDVD Productivity applications: Other applications provided: Adobe Acrobat Reader Supported operating systems: Microsoft Windows XP Professional, Microsoft Windows 2000, Microsoft Windows 2000 Professional Architecture Bus type/architecture: PCI Bays: Ultrabay Slim Indicator light: Yes Form Factor: Notebook Display External display supported: Yes Simultaneous external display: Yes Screen type description: TFT FlexView display with wide viewing angle and high density Viewable image size (diagonal): 15inches Screen illumination: Backlit Max colors or grey shades: 16777216 Max resolution: 1400x1050 Graphics Subsystem Video RAM std/max: 64MB / 64MB Graphics chipset: ATI MOBILITY RADEON 9600 Graphics type: 2D/3D Video RAM type: DDR SDRAM Max resolution (with max video RAM): 2048x1536 16777216 colors Max colors (with max video RAM): 16777216 Graphics bus interface: AGP 8X Processor BIOS type: Flash ROM Processor manufacturer: Intel Processor (CPU): Intel Pentium M Processor 745 Processor internal clock speed2: 1.80GHz Front Side Bus: 400MHz Memory Memory (RAM) std/max: 512MB / 2GB RAM slots total: 2 SODIMM RAM slots available: 1 SODIMM RAM speed supported: 333MHz RAM type: PC2700 DDR SDRAM Hard Disk Hard disk size1: 80GB Hard disk type: ATA-100 (Enhanced IDE) Optical device Floppy diskette size: -- Optical device: CD-RW/DVD-ROM Combo Optical device speed8: 24X/24X/24X/8X Max Device interface: EIDE Audio Integrated speakers: 2 Speaker power rating: 1.0 Watts Volume control buttons: Yes Speaker Quantity: 2 (Internal Speakers) Audio chipset: SoundMAX Audio data width: n/a Communications Fax/modem: 56K V.92 designed modem Fax/modem speeds: 56Kbps data/14.4Kbps fax Infrared port: Yes Infrared port speed: 4Mbps Wireless standard: Intel 802.11b Network card: Integrated Intel PRO/1000 Gigabit Ethernet Network interface: Gigabit Ethernet- Integrated Accessories A/C adapter: 72 watt Worldwide A/C compatibility: Yes Port replicator: Optional Standard Features Pointing device type: IBM ThinkPad UltraNav Keyboard type: Keyboard light: Yes Power Management 5 Heat emissions: 72W Sound emissions: 36dB Battery life - min/max: 4.0 Hrs Battery type(s): 6 Cell Lithium-Ion Charge time - on/off: 4.0Hrs / 3.6Hrs Expansion Options Plug and play support: Yes Slots total (free) and type: PC Card Ports: AC adapter Expansion Bus port (for Dock II/Mini Dock or Port Replicator II) External microphone External Display Headphone/Line out Infrared Parallel RJ-11 RJ-45 S-Video out 2 USB 2.0 Weight & Dimensions 6 Weight: 2.7 Kg Height: 31mm Depth: 268mm Travel weight: 2.50Kg Security Security features: Supervisor password Hard disk drive password IBM Embedded Security Subsystem 2.0 IBM Security Slot Power-on password Limited warranty 3 Type of service: Customer Carry-in Repair or ThinkPad EasyServ Warranty period: Three year (system battery:one year) parts and labour --------------------------------------------------------------- Endret 10. mars 2005 av furier Lenke til kommentar
Eulogy Skrevet 10. mars 2005 Del Skrevet 10. mars 2005 Veldig forvirrende å lese dette. Lenke til kommentar
Frekkas Skrevet 11. mars 2005 Del Skrevet 11. mars 2005 Veldig forvirrende å lese dette. Jepp Foreslår at trådstarter redigerer innlegget og gir oss kortversjonen. Men for å svare, sikkert verdt opp mot 20k. Lenke til kommentar
Aetius Skrevet 11. mars 2005 Del Skrevet 11. mars 2005 Hjelpe meg! Det derre gidder ihvertfall ikke jeg å lese! Skulle nesten tro trådstarter ikke ønsket svar på posten! Lenke til kommentar
MuD Skrevet 11. mars 2005 Del Skrevet 11. mars 2005 Ganske rotete dette her, men eg trur ikkje att du kunne ha fått 21000kr for den... maks 16000-17000kr... Lenke til kommentar
