Asetek lanserer VapoChill Micro / Heatpipe Kjølere
The VapoChill Micro™ CPU coolers are characterized by hermetically sealed gas/liquid chambers exploiting the most effective cooling principle available: phase change cooling.
The new revolutionary series of VapoChill Micro™ CPU coolers are based on an existing and well-know VapoChill® vapor phase technology launched back in 1997.
By extracting heat from the CPU, a closed sealed fluid will evaporate and reach top of the pipes – this gaseous form will then be cooled by an efficient fan and radiator and turn into a solid fluid form again where as it will hit the bottom of the CPU cooler once more. The recirculation of the coolant is based on gravity. In other words, no mechanical parts and basically unlimited reliability.
The circular process in VapoChill Micro™ will go on and on and keep the CPU temperature cool at all time – even at a low noise level.
Link til full pressrelease -
Pressrelease
  • 2 uker senere...
