Grindingguide level 35-60?
De fleste vet vel hvilke soner som passer for hvilke lvls, det er ikke akkurat no grinding guide.
Kommer litt an på hvilken klasse du er, men her en en thread på et annet forum du bør sjekke ut: http://www.nurfed.com/phpBB2/viewtopic.php?t=751
Skulle ikke tro horde/alliance hadde no særlig å si 35+, men denne er hvertfall fra en horde rogue:
32-37 Kurzen camp in North Stranglethorn Vale (outside cave) 26,000 -32,000 exp per hour. This actually got better as I went up in level as long as no one else was at the camp. At level 36, I tested about 1/4 of the level and my experience rate was 32,640 per hour when I had to stop and go sell.
37-42 Kurzen camp in North Stranglethorn (inside cave) 29,000 - 34,000 exp per hour; 5-7 gold per hour. Go in past the Kurzen Commandos and Kurzen Headhunters to the Elites and Witchdoctors. The Commandos have armor, and stun you when they are low on life, so they are poor experience, but the Elites and Witchdoctors inside are the same old no-armor experience givers. I told my guild this area is just a leveling field with juicy experiene berries waiting to be plucked. I'm currently 39 here, and still doing full levels in just about 2 hours of grinding.
I didn't grind as exclusively from here on out, so I'm going to shotgun a few spots and level ranges that felt "Good". I still measured exp per hour, but this was just after the last patch where they upgraded armor and HP on most monsters I grind on, so exp definitely slowed down.
42 - 45 Woodpaw Gnolls in Feralas, south of Camp Mojache. Stay away from the Trappers and Brutes IMO, and head further south to the Mystics and Reavers. I liked the area that was still on flat land with a couple of Alpha camps on raised mounds. I usually avoided the alphas as they tended to be bugged/grouped in a cluster of 3. Spell disruption is a must for the Mystics. I cleared about 24k exp per hour here typically.
42-44 Ogres in Feralas. Due north of camp Mojache in the mountains. The Mages are best if you have spell disruption, but I worked through all of them and they were all good experience. The Brutes will throw you, so make sure they don't throw you into an add. 20-24k exp per hour.
44 - 47/48 Dustbelcher Ogres in the Badlands. Now here is a good spot, and it may be good on PvP as well. I camped this cave for 3 hours one Saturday without seeing another player. The cave is in the Southwest corner of the bladlands past a bunch of Ogres. The reason why I say the cave, is that it's about 75% Ogre Mages, and if you have spell disruption, they go down easy. Very low hp and low armor even after the patch. The only reason I left at 48 is I could clear the spawn too quickly, and I wanted to do Tanaris quests.
48-52 Dunemaul Ogres in Tanaris (great Mageweave drops). I like the NE ruins for the early levels, as I could move around it in a circle. Once I got to 50, I liked the higher density in the actual Dunemaul Compound area.
52-56 Western Plaugelands. The field with the Skeletal Slayers right by the Bulwark. Great Runecloth drops, and actually I prefered to kill the melees here over the casters (casters seemed to have the same HP and armor as melees). I've been pulling 26k exp per hour or better here.
Shadow priest(også horde tror jeg):
Lvl 35-39 - Alterac Mountains, east or north from Ruins of Alterac
Ogres, good % cloth drop
Lvl 37-39 - Dustwallow Marsh, north from Brackenwall Village, near the entrance to a spider cave
Spiders lvl 35-36, 5.5%-6.3% Shadow Silk drop
Just stand in the center of a round spawn and nuke everything that moves, surprisingly good exp. Moderate chances of adds and web, so probably harder on lower lvls.
If you feel uber, try to get in the cave at lvl 38/priest (lvl 37-39 spiders, half are invisible, some wander, they chaincast web, fast respawn time... grinding is practically impossible), on a lvl 39 it's good in a cave, easy on lvl 40.
Lvl 42-44 - Feralas - Grimtotem Compound, north spawn (NW from Camp Mojache)
Humanoids lvl 41-44, 2/3 melee, 1/4 healers, 1/12 casters (naturalsts not in bear form) Healers heal for 1/2 health
11,5% running time, a little too small spawn, but south one is worse IMHO (bad spawn form, pulls of 2 monsters in some places etc.)
No adds if it's cleared properly
Lvl 44 - Azshara - north from Shadowsong Shrine
Undead lvl 44-45, 1/2 casters 1/2 melee, good shadow resists, but good exp anyways.
20% running time, good % cloth drop.
Mobs wander in a small area around their location, no adds if a site is cleared properly.
29k exp/hour (?)
Lvl 45-48 - Searing Gorge - The Cauldron, east entrance - a room with unconscious elemental and an altar in the center
Humanoids lvl 45-47, good % cloth drop
~11,5% running time (for ranged char)
3/4 stationary mobs, 1/4 wander in a small area, one mob wanders around a room, no adds if a site is cleared properly and that one wandering mob is taken care of
32k exp/hour
Lvl 45-48 - Tanaris - Southmoon Ruins (Dunemaul Compound is too crowded)
Ogres lvl 45-48, good % cloth drop
2/3 melee, 1/3 mages, 20% running time, stationary mobs
29,5k exp/hour
Lvl 49-51 - Feralas - Ruins of Ravenwind
Humanoids (Northspring ***) lvl 48-50, good % cloth drop, low HPs
2/3 melee, 1/3 mages, 20% running time, mobs wander (some only in a small area), moderate chances of adds in some parts of the spawn
34k exp/hour (?)
