Farlig å få kjølepasta i... ?
Mauro
er ikke sikker, men skal jeg tippe så vil jeg tippe det er noe med monteringsprosessen...
"Finally, note the little hole in the top of the Xeon's heatspreader. It's designed so that the magical pixie overlords that run the CPU core can escape when things get too hot"
en side sin forklaring på hullet...
musa
Endret av General_musa
fant forklaringen:
"The hole is for pressure relief. When the IHS is epoxied to the Organic Land Grid Array, or "OLGA" for short, it releases gas as it cures. If Intel did not provide the hole, the pressure would build up and eventually blow out the still wet epoxy. This would cause mechanical stresses due to the incomplete epoxy line around the IHS to OLGA bond line. Once the epoxy has cured (before it leaves the factory) it is not an issue. So, Intel put in a hole. If it gets plugged up with thermal grease or something it is OK. I would not suggest filling it with anything that conducts electricity though."
kilde:
http://www.hardocp.com/article.html?art=NA==
Musa
