Club3D x800pro vivo --> xt Mulig?
Performing the Mod
1. Download modified flashrom.
2. Download Bios from here. I suggest the latest X800XT PE Bios.
A little sidenote: Many people complain that they get a "file not found" error when trying to flash the bios under DOS. The problem is that DOS does not know long filenames, so all files are truncated to some funky names like Powerco~1.bin. Either use the dir command, when in DOS, to find out the short filename or rename the file to something shorter while still in Windows.
3. Make sure the card can reliably run at the clock speeds of the new bios (with ATiTool, for example).If you know your card can't handle the XT PE speeds you can download a modified X800 Pro VIVO Bios from the Bios Collection as well (ATI X800 Pro VIVO 16P). This bios is just 16P enabled and is detected as X800 Pro by the drivers - clocks are unchanged.
4. Use the modified flashrom to flash the Bios to the card. More extensive flashing instructions can be found here. They talk about atiflash - you use the modified flashrom, usage is the same.
After bootup Windows should automatically install the X800 XT PE driver.
Verify the number of active pipelines using ATiTool. Go to Settings -> Overclocking. The list there shows the number of pipelines the card is running with.
If you want to remove all traces of previous Bios flashes (for example if you flashed the Gigabyte Bios):
5. Use modified flashrom to flash empty.bin (use "Save as..." if weird characters appear when clicking the link) to your video card, then flash the new Bios without rebooting. Be careful - if you don't flash a real Bios after flashing the empty Bios, your card will not work properly.
Hentet det fra TechPowerUp.com som var den samme plassen jeg hentet biosen til mitt R9800 SE->XT
Kunne ikke se noen xt (pe) bios til Club3d annet enn PCIe utgaven, men hvilken som helst bios fra en annen produsent burde fungere, bare minnet og gpu klarer de samme hastighetene.
Nå må dere slutte å surre her da, de siste 4 pipeline'ene er ikke mulig å hente fram når det er snakk om PCI-E kort! I motsetning til AGP kortene, er disse "hardmoddet" bort, altså laserkuttet. Klokk så det svinger, mer enn det kan du ikke gjøre. Eventuelt kan du kanskje prøve å fikse pipeline'ene ved å lodde dem sammen igjen, men da snakker vi mer avanserte løsninger...
(Basert på erfaringer, mulig det finnes visse unntak)
WTF?? Seriøst? Har et Club3D X800 Pro Vivo PCIe kort, vil det si at jeg ikke får moddet til 16 pipelines ved kun a flashe bios?
Hvem snakker om PCIe-kort? Ikke meg iallfall. Har ikke sett noen har nevnt det engang. :hmm:
Hentet fra signatur: "Asus A8N-sli"
Altså konkluderte jeg med at trådstarter har PCI-E, skyt meg om jeg tar feil :p
edit: det stemmer også bra med at alle PCI-E versjoner av X800 Pro VIVO har 2,0ns minne... (inkludert noen veldig få AGP kort)
Endret av ADT
