Xt Pe riktig klokkefrekvens ?
gamerman
EDIT: Har et Club 3d Xt Pe kort
Når jeg brukte Ati Tool så kortsluttet hele maskinen :( Kom ikke lengere en innstaleringen tror kanskje Omega driveren har noe med dette å gjøre ....
Anyway
RivaTuner funket og dette stod min på :
$ffffffffff ---------------------------------------------------
$ffffffffff Northbridge information
$0400000000 Description : unknown
$0400000001 Vendor ID : 1106 (VIA)
$0400000002 Device ID : 3205
$0400000003 AGP bus : revision 3.0
$0400000004 AGP status : enabled
$0400000005 AGP rate : 4x 8x supported, 8x selected
$0400000006 AGP SBA : hardwired, enabled
$0400000007 AGP FW : not supported
$ffffffffff Display adapter information
$0000000000 Description : RADEON X800 XT Platinum Edition...
$0000000001 Vendor ID : 1002 (ATI)
$0000000002 Device ID : 4a50
$0000000003 Location : bus 1, device 0, function 0
$0000000004 Bus type : AGP revision 3.0
$0000000005 AGP status : enabled
$0000000006 AGP rate : 4x 8x supported, 8x selected
$0000000007 AGP SBA : hardwired, enabled
$0000000008 AGP FW : supported, disabled
$0000000009 Base address 0 : d0000000 (memory range)
$000000000a Base address 1 : 0000d000 (I/O range)
$000000000b Base address 2 : e0030000 (memory range)
$000000000c Base address 3 : none
$000000000d Base address 4 : none
$000000000e Base address 5 : none
$ffffffffff ATI specific display adapter information
$0900000000 Graphics core : R420 (16x1)
$0900000002 Memory bus : 256-bit
$0900000001 Memory type : DDR SGRAM / SDRAM
$0900000003 Memory amount : 256MB
$0900000004 Core clock : 519.750MHz
$0900000005 Memory clock : 560.250MHz (1120.500MHz effecti...
$0900000006 Reference clock : 27.000MHz
$ffffffffff Memory timings
$0900000100 WR latency : 1.5
$0900000101 CAS latency : 4
$0900000102 CMD latency : 0.0
$0900000103 STR latency : 1.5
$0900000110 TRCDRD,RAS to CAS read : 7
$0900000111 TRCDWR,RAS to CAS write : 4
$0900000112 TRP ,Row precharge : 5
$0900000113 TRAS ,Row active : 6
$0900000114 TRRD ,Row active to row active command : 6
$0900000115 TR2W ,Read to write turnaround : 6
$0900000116 TWR ,Write recovery : 7
$0900000117 TW2R ,Write to read turnaround : 1
$0900000118 TW2R ,Write to read turnaround/same bnk : 7
$0900000119 TR2R ,Read to read turnaround : 3
Stemmer dette ?
Endret av gamerman
