stoppe form når ut av skjerm
Siden det ikke finnes noe Form_Move-event, må man bruke subclassing for å mota en melding om at formen flyttes på.
Lim dette inn i formen din:
Option Explicit
Private Sub Form_Load()
SubclassForm Me
End Sub
Private Sub Form_Unload(Cancel As Integer)
EndSubclassForm Me
End Sub
Public Sub Form_Move()
If Me.Left < 0 Then Me.Left = 0
If Me.Left + Me.Width > Screen.Width Then Me.Left = Screen.Width - Me.Width
If Me.Top < 0 Then Me.Top = 0
If Me.Top + Me.Height > Screen.Height Then Me.Top = Screen.Height - Me.Height
End Sub
Og dette i en modul:
Option Explicit
Private Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long
Private Declare Function CallWindowProc Lib "user32" Alias "CallWindowProcA" (ByVal lpPrevWndFunc As Long, ByVal hwnd As Long, ByVal Msg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
Private Declare Function SetClipboardViewer Lib "user32" (ByVal hwnd As Long) As Long
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Integer, ByVal lParam As Any) As Long
Private Const WM_MOVE = &H3
Private Const WM_MOVING = &H216
Private Const GWL_WNDPROC = (-4)
Private PrevProc As Long
Private MyForm As Form
Public Sub SubclassForm(F As Form)
Set MyForm = F
PrevProc = SetWindowLong(F.hwnd, GWL_WNDPROC, AddressOf WindowProc)
End Sub
Public Sub EndSubclassForm(F As Form)
SetWindowLong F.hwnd, GWL_WNDPROC, PrevProc
End Sub
Public Function WindowProc(ByVal hwnd As Long, ByVal uMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
If uMsg = WM_MOVING Or WM_MOVE Then
   Call MyForm.Form_Move
End If
WindowProc = CallWindowProc(PrevProc, hwnd, uMsg, wParam, lParam)
End Function
Det var mye flimring med bare WM_MOVING, men straks jeg la til WM_MOVE ble det bedre, men jeg regner med at det er litt forskjellig fra maskin til maskin.
Jeg tror ikke det finnes noe flere events man kan legge til. Mulig jeg er helt på jordet, men disse kommer rett fra windows, og det finnes ikke noe bak der som leverer alt raskere.
Edit: Jo, det finnes nok andre måter, som bla. Winamp bruker, men jeg vet ikke om den/de.
Endret av Jonas
