pc funker ei
This is what i bought:
*Athlon xp 2000+
*Abit KX7-333 RAID Hovedkort Socket A DDR
- VIAKT333, ATA/133, ATX, 266MHz
*Creative 3D Blaster 4 Ti4600 128Mb
*Aopen Big tower ATX HQ08A-P Blue (P-4)(300w)
*Sb Live Player 5.1
*NEC 19" CRT Multisync 95F TCO-99 (Flat)
*IBM Deskstar 80GB IDE 7200RPM
- ATA/100 harddisk 120GXP /IC35L080AVVA07
*2X TwinMOS PC2100 DDR-DIMM 256MB CL2.5
- Memory 184-P (for DDR-PC266MHz)
I built it myself, it doesn't work, i've checked everything 1 000 000 times , i've reset the bios, i've tried other videocards other monitors, i've returned the processor and MoBo to the company to check for errors, but they didn't find anything. When i turn on the computer all fans start up, and harddisk starts up all lights are on and it seems like everything works completly fine, but the system does not boot up, the monitor does not get signal, but videocard and agp slot works fine. (tested video card on other comp, agp slot checked by pro's). Many people have come and looked at it but they can't figure it out.
Maybe it's one of the parts thats incapable of functioning with one of the other parts i don't know.
Omar - hvordan gjestfrihet er dette? Har aldri sett noe krav om at man kun skal poste på norsk - de fleste av oss kan da engelsk!
av4 - do you get any beep from the BIOS self test? Try to pull out everything except CPU and video, and start from there (to eliminate all the other stuff).
Does the CPU get warmed up?
Quote:
hårek skrev (2002-06-23 18:12):
-snip-
Nei, der har vel aldri vært sagt, men .no i hardware.no betyr vel noe.
dessuten er det vel klart at han snakker norsk siden tittelen på emnet er på norsk......
or maybe the mobo has a fan detection function, and doesn't get a signal from the cpu fan(even though it is running). I had that problem with my cpu fan (silent Viking), but it did boot, and there was a seriously annoying alarm, so...
seriøst... jeg posta først på planethardware.com , men så sa en kompis at folk her har peil...
MoBo og CPU har blitt skjekka av komplett via retur... begge funker,og ja jeg har cpu vifte.
Folk på planethardware mener at det kanskje er 300 watt powersupply som gjør det, tror dere det?
i så tilfelle, hvor mye strøm trenger jeg? skal kjøpe ny strømboks i dag, så svar fort plz...
Her kan du laste ned AMD sin PDF med et skjema der du kan regne ut hvor mange watt du trenger:
http://www.amd.com/us-en/assets/content_ty..._docs/26003.pdf
Det kan nok være at du trenger 350/400 watt i strømforsyningen din. Dersom det er det kjøåe et bra merke some f.eks Emermax, de lager meget gode PSU'er. Ellers kan det også være en liten kortslutning på kortet ditt, sjekk denne tråden her: http://forum.hardware.no/viewtopic.php?top...=36199&forum=24
Håper det ordner seg
