Kingnghia Skrevet 20. februar 2005 Del Skrevet 20. februar 2005 (endret) Jeg er newbie under Fedora Linux. Jeg hadde tenkt til å innstallere Winex CVS og alt gikk greit helt til kompileringen. For da får jeg denne meldingen: Compiling ... --------- Error log - file /root/temp/winex-stable/ErrorLog : --------- ts_xlib.c:1175: warning: return type defaults to `int' ts_xlib.c: In function `TSXOpenIM': ts_xlib.c:1176: error: `XIM' undeclared (first use in this function) ts_xlib.c:1176: error: syntax error before "r" ts_xlib.c:1178: error: `r' undeclared (first use in this function) ts_xlib.c:1178: warning: implicit declaration of function `XOpenIM' ts_xlib.c:1178: error: `a0' undeclared (first use in this function) ts_xlib.c:1178: error: `a1' undeclared (first use in this function) ts_xlib.c:1178: error: `a2' undeclared (first use in this function) ts_xlib.c:1178: error: `a3' undeclared (first use in this function) ts_xlib.c: At top level: ts_xlib.c:1183: error: syntax error before "TSXCheckIfEvent" ts_xlib.c:1183: error: syntax error before '*' token ts_xlib.c:1183: warning: type defaults to `int' in declaration of `TSXCheckIfEvent' ts_xlib.c:1183: error: `TSXCheckIfEvent' declared as function returning a function ts_xlib.c:1183: warning: type defaults to `int' in declaration of `XPointer' ts_xlib.c:1183: error: syntax error before "a3" ts_xlib.c:1186: warning: type defaults to `int' in declaration of `wine_tsx11_lock' ts_xlib.c:1186: error: 'wine_tsx11_lock' redeclared as different kind of symbol ../include/ts_xlib.h:18: error: previous declaration of 'wine_tsx11_lock' was here ts_xlib.c:1186: error: 'wine_tsx11_lock' redeclared as different kind of symbol ../include/ts_xlib.h:18: error: previous declaration of 'wine_tsx11_lock' was here ts_xlib.c:1186: warning: data definition has no type or storage class ts_xlib.c:1187: warning: type defaults to `int' in declaration of `r' ts_xlib.c:1187: warning: implicit declaration of function `XCheckIfEvent' ts_xlib.c:1187: error: `a0' undeclared here (not in a function) ts_xlib.c:1187: error: `a1' undeclared here (not in a function) ts_xlib.c:1187: error: `a2' undeclared here (not in a function) ts_xlib.c:1187: error: `a3' undeclared here (not in a function) ts_xlib.c:1187: error: initializer element is not constant ts_xlib.c:1187: warning: data definition has no type or storage class ts_xlib.c:1188: warning: type defaults to `int' in declaration of `wine_tsx11_unlock' ts_xlib.c:1188: error: 'wine_tsx11_unlock' redeclared as different kind of symbol ../include/ts_xlib.h:19: error: previous declaration of 'wine_tsx11_unlock' was here ts_xlib.c:1188: error: 'wine_tsx11_unlock' redeclared as different kind of symbol ../include/ts_xlib.h:19: error: previous declaration of 'wine_tsx11_unlock' was here ts_xlib.c:1188: warning: data definition has no type or storage class ts_xlib.c:1189: error: syntax error before "return" ts_xlib.c:1192: error: syntax error before '*' token ts_xlib.c:1192: error: syntax error before '*' token ts_xlib.c: In function `TSXSynchronize': ts_xlib.c:1194: error: syntax error before '*' token ts_xlib.c:1196: warning: implicit declaration of function `XSynchronize' ts_xlib.c:1196: warning: assignment makes pointer from integer without a cast ts_xlib.c: At top level: ts_xlib.c:1201: error: syntax error before '*' token ts_xlib.c:1203: error: syntax error before '*' token make[1]: *** [ts_xlib.o] Error 1 make[1]: Leaving directory `/root/temp/winex-stable/winex/tsx11' make: *** [tsx11/libwine_tsx11.so] Error 2 Error in Make Try fixing the error based on the output above, and run the script again, without paramaters (Eg: GetStableWineX) Kjerne: 2.6.9-1.667 Endret 20. februar 2005 av Kingnghia Lenke til kommentar
Gronz Skrevet 20. februar 2005 Del Skrevet 20. februar 2005 Kompilerer du WineX eller Cedega? Cedega er nyest, og det er den du bør installere. WineCVS-scriptet lar deg velge begge. Lenke til kommentar
Kingnghia Skrevet 20. februar 2005 Forfatter Del Skrevet 20. februar 2005 Jeg kompilerer Cedega Lenke til kommentar
