Hvordan lage Winamp skins ?
RedRocK
Fra Winamp.Com:
Can I make skins?
Yes you may. The great thing about Winamp skinning is that it is open to anyone who wants to try. You will need some graphic design knowledge and if you want to make a Freeform skin you will need to learn our scripting engine (XML coders should have no problem). We have created the Nullsoft Developers Network to serve as a starting point for budding Skinners. You will also find a wealth of information in the Winamp Forums.
Programmet er Her:)
Endret av ace_ventuora
