Kleivis Skrevet 18. februar 2005 Del Skrevet 18. februar 2005 No har eg rota det fullstendig til her... får opp meldingen nedenfor når eg prøver å kjøre: apt-get upgrade You might want to run `apt-get -f install' to correct these: The following packages have unmet dependencies: gnome-panel: Depends: libecal6 (>= 1.0.3) but it is not going to be installed Depends: libedataserver3 (>= 1.0.3) but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). og så prøvde eg apt-get -f install Reading Package Lists... Done Building Dependency Tree... Done Correcting dependencies... Done The following extra packages will be installed: libecal6 libedataserver3 The following NEW packages will be installed: libecal6 libedataserver3 0 upgraded, 2 newly installed, 0 to remove and 41 not upgraded. 11 not fully installed or removed. Need to get 0B/315kB of archives. After unpacking 918kB of additional disk space will be used. Do you want to continue? [Y/n] y (Reading database ... 76040 files and directories currently installed.) Unpacking libedataserver3 (from .../libedataserver3_1.0.3-2_i386.deb) ... dpkg: error processing /var/cache/apt/archives/libedataserver3_1.0.3-2_i386.deb (--unpack): trying to overwrite `/usr/lib/libedataserver.so.3.2.2', which is also in package evolution-data-server dpkg-deb: subprocess paste killed by signal (Broken pipe) Unpacking libecal6 (from .../libecal6_1.0.3-2_i386.deb) ... dpkg: error processing /var/cache/apt/archives/libecal6_1.0.3-2_i386.deb (--unpack): trying to overwrite `/usr/lib/libecal.so.6', which is also in package evolution-data-server Errors were encountered while processing: /var/cache/apt/archives/libedataserver3_1.0.3-2_i386.deb /var/cache/apt/archives/libecal6_1.0.3-2_i386.deb E: Sub-process /usr/bin/dpkg returned an error code (1) no e alt fucka.. blant ant er det ikkje noen liste med åpne programmer på panelet. vet ikkje om dette er grunnen..? men kordan kan eg fikse dette Lenke til kommentar
LessThanJake Skrevet 18. februar 2005 Del Skrevet 18. februar 2005 Vet ikke hvorfor det har skjedd men for å få tilbake høyreklikker du bare på panelet og velger 'Add to panel' og 'Window List'. Har du lekt deg i '/etc/apt/sources.list'. Lenke til kommentar
Kleivis Skrevet 18. februar 2005 Forfatter Del Skrevet 18. februar 2005 (endret) tror eg har bæsja på leggen her.. har endra litt i sources.list ja og no ser det ut som eg plutselig har fått debian i steden for ubuntu. blir møtt av en debian logo når eg skal logge inn og splashen er også debian..i gnome var det også en debian meny Endret 18. februar 2005 av Pinguvin Lenke til kommentar
