netbeans og SavitchIn.java
Prøvar å få til å kompilere programmet mitt (prosjekt) med lenker til SavitchIn, korleis gjer eg dette, eg plasserer SavitchIn i samme mappe som main.java men får kun
init:
deps-jar:
Compiling 2 source files to /home/antikristian/javasource/prosjekt/build/classes
/home/antikristian/javasource/prosjekt/src/prosjekt/SavitchIn.java:15: duplicate class: SavitchIn
public class SavitchIn
/home/antikristian/javasource/prosjekt/src/prosjekt/Main.java:26: cannot access prosjekt.SavitchIn
bad class file: /home/antikristian/javasource/prosjekt/src/prosjekt/SavitchIn.java
file does not contain class prosjekt.SavitchIn
Please remove or make sure it appears in the correct subdirectory of the classpath.
laanebelop = SavitchIn.readLineInt( );
2 errors
BUILD FAILED (total time: 2 seconds)
E tidlig i læreprosessen, trenge litt holding i handa her :cry:
dette er savitchInIn:
import java.io.*;
import java.util.*;
Class for simple console input.
A class designed primarily for simple keyboard input of the
form one input value per line. If the user enters an improper
input, i.e., an input of the wrong type or a blank line, then
the user is prompted to reenter the input and given a brief
explanation of what is required. Also includes some additional
methods to input single numbers, words, and characters, without
going to the next line.
    Reads a line of text and returns that line as a String
    value. The end of a line must be indicated either by a
    new-line character '\n' or by a carriage return '\r'
    followed by a new-line character '\n'. (Almost all systems
    do this automatically. So you need not worry about this
    detail.) Neither the '\n', nor the '\r' if present, are
    part of the string returned. This will read the rest of a
    line if the line is already partially read.
   public static String readLine( )
       char nextChar;
       String result = "";
       boolean done = false;
       while (!done)
           nextChar = readChar( );
           if (nextChar == '\n')
              done = true;
           else if (nextChar == '\r')
               //Do nothing.
               //Next loop iteration will detect '\n'.
           else
              result = result + nextChar;
       return result;
    Reads the first string of nonwhitespace characters on
    a line and returns that string. The rest of the line
    is discarded. If the line contains only whitespace,
    the user is asked to reenter the line.
   public static String readLineWord( )
       String inputString = null,
              result = null;
       while(!done)
           inputString = readLine( );
           StringTokenizer wordSource =
                               new StringTokenizer(inputString);
           if (wordSource.hasMoreTokens( ))
               result = wordSource.nextToken( );
               done = true;
           else
               System.out.println(
                    "Your input is not correct. Your input must");
               System.out.println(
                "contain at least one nonwhitespace character.");
               System.out.println(
                                "Please try again. Enter input:");
      return result;
    Precondition: The user has entered a number of type int
    on a line by itself, except that there may be
    whitespace before and/or after the number.
    Action: Reads and returns the number as a value of type
    int. The rest of the line is discarded. If the input is
    not entered correctly, then in most cases, the user will
    be asked to reenter the input. In particular, this
    applies to incorrect number formats and blank lines.
   public static int readLineInt( )
       String inputString = null;
       int number = -9999;//To keep the compiler happy.
                          //Designed to look like a garbage value.
       while (! done)
           try
               inputString = inputString.trim( );
               number = Integer.parseInt(inputString);
               done = true;
           catch (NumberFormatException e)
               System.out.println(
                        "Your input number is not correct.");
               System.out.println(
                        "Your input number must be");
               System.out.println(
                        "a whole number written as an");
               System.out.println(
                         "ordinary numeral, such as 42");
               System.out.println("Minus signs are OK,"
                         + "but do not use a plus sign.");
               System.out.println("Please try again.");
               System.out.println("Enter a whole number:");
       return number;
    Precondition: The user has entered a number of type long
    on a line by itself, except that there may be whitespace
    long. The rest of the line is discarded. If the input is
   public static long readLineLong( )
       long number = -9999;//To keep the compiler happy.
       while (! done)
           try
               number = Long.parseLong(inputString);
               done = true;
               System.out.println(
               System.out.println(
               System.out.println(
               System.out.println(
       return number;
    double on a line by itself, except that there may be
    double. The rest of the line is discarded. If the input
    is not entered correctly, then in most cases, the user
    will be asked to reenter the input. In particular, this
   public static double readLineDouble( )
       double number = -9999;//To keep the compiler happy.
       while (! done)
           try
               number = Double.parseDouble(inputString);
               done = true;
               System.out.println(
               System.out.println(
               System.out.println(
                         "an ordinary number either with");
               System.out.println(
                          "or without a decimal point,");
               System.out.println("such as 42 or 9.99");
               System.out.println("Enter the number:");
       return number;
    Precondition: The user has entered a number of type float
    float. The rest of the line is discarded. If the input is
    this applies to incorrect number formats and blank lines.
   public static float readLineFloat( )
       float number = -9999;//To keep the compiler happy.
       while (! done)
           try
               number = Float.parseFloat(inputString);
               done = true;
               System.out.println(
               System.out.println(
               System.out.println(
               System.out.println(
       return number;
    Reads the first nonwhitespace character on a line and
    returns that character. The rest of the line is
    discarded. If the line contains only whitespace, the
   public static char readLineNonwhiteChar( )
       char nonWhite = ' ';//To keep the compiler happy.
       while (! done)
           if (inputString.length( ) == 0)
               System.out.println(
                        "Your input is not correct.");
               System.out.println(
                        "Your input must contain at");
               System.out.println(
                        "least one nonwhitespace character.");
               System.out.println("Enter input:");
           else
               nonWhite = (inputString.charAt(0));
               done = true;
       return nonWhite;
    Input should consist of a single word on a line, possibly
    surrounded by whitespace. The line is read and discarded.
    If the input word is "true" or "t", then true is returned.
    If the input word is "false" or "f", then false is
    returned. Uppercase and lowercase letters are considered
    equal. If the user enters anything else (e.g., multiple
    words or different words), the user is asked
   public static boolean readLineBoolean( )
       boolean result = false;//To keep the compiler happy.
       while (! done)
           if (inputString.equalsIgnoreCase("true")
                  || inputString.equalsIgnoreCase("t"))
               result = true;
               done = true;
           else if (inputString.equalsIgnoreCase("false")
                       || inputString.equalsIgnoreCase("f"))
               result = false;
               done = true;
           else
               System.out.println(
               System.out.println("Your input must be");
               System.out.println("one of the following:");
               System.out.println("the word true,");
               System.out.println("the word false,");
               System.out.println("the letter T,");
               System.out.println("or the letter F.");
               System.out.println(
                        "You may use either upper-");
               System.out.println("or lowercase letters.");
       return result;
    Reads the next input character and returns that character.
    The next read takes place on the same line where this
    one left off.
   public static char readChar( )
       int charAsInt = -1; //To keep the compiler happy.
       try
           charAsInt = System.in.read( );
       catch(IOException e)
           System.out.println(e.getMessage( ));
           System.out.println("Fatal error. Ending program.");
           System.exit(0);
       return (char)charAsInt;
    Reads the next nonwhitespace input character and returns
    that character. The next read takes place immediately
    after the character read.
   public static char readNonwhiteChar( )
     char next;
     next = readChar( );
     while (Character.isWhitespace(next))
         next = readChar( );
     return next;
    The following methods are not used in the text, except
    for a brief reference in Chapter 2. No program code uses
    them. However, some programmers may want to use them.
    Precondition: The next input in the stream consists of
    an int value, possibly preceded by whitespace, but
    definitely followed by whitespace.
    Action: Reads the first string of nonwhitespace characters
    and returns the int value it represents. Discards the
    first whitespace character after the word. The next read
    takes place immediately after the discarded whitespace.
    In particular, if the word is at the end of a line, the
    next read will take place starting on the next line.
    If the next word does not represent an int value,
    a NumberFormatException is thrown.
   public static int readInt( ) throws NumberFormatException
       inputString = readWord( );
       return Integer.parseInt(inputString);
    Precondition: The next input consists of a long value,
    possibly preceded by whitespace, but definitely
    and returns the long value it represents. Discards the
    first whitespace character after the string read. The
    next read takes place immediately after the discarded
    whitespace. In particular, if the string read is at the
    end of a line, the next read will take place starting on
    the next line. If the next word does not represent a long
    value, a NumberFormatException is thrown.
   public static long readLong( )
       return Long.parseLong(inputString);
    Precondition: The next input consists of a double value,
    and returns the double value it represents. Discards the
    double value, a NumberFormatException is thrown.
   public static double readDouble( )
       return Double.parseDouble(inputString);
    Precondition: The next input consists of a float value,
    and returns the float value it represents. Discards the
    a float value, a NumberFormatException is thrown.
   public static float readFloat( )
       return Float.parseFloat(inputString);
    Reads the first string of nonwhitespace characters and
    returns that string. Discards the first whitespace
    character after the string read. The next read takes
    place immediately after the discarded whitespace. In
    particular, if the string read is at the end of a line,
    the next read will take place starting on the next line.
    Note that if it receives blank lines, it will wait until
    it gets a nonwhitespace character.
   public static String readWord( )
       String result = "";
       char next;
       next = readChar( );
            next = readChar( );
       while (!(Character.isWhitespace(next)))
           result = result + next;
           next = readChar( );
       if (next == '\r')
           next = readChar( );
           if (next != '\n')
               System.out.println("Fatal error in method "
                    + "readWord of the class SavitchIn.");
               System.exit(1);
       return result;
    Precondition: The user has entered a number of type byte
    byte. The rest of the line is discarded. If the input is
    be asked to reenter the input. In particular, this applies
   public static byte readLineByte( )
       byte number = -123;//To keep the compiler happy.
       while (! done)
           try
               number = Byte.parseByte(inputString);
               done = true;
               System.out.println(
               System.out.println(
                        "Your input number must be a");
               System.out.println(
                        "whole number in the range");
               System.out.println("-128 to 127, written as");
               System.out.println(
                        "an ordinary numeral, such as 42.");
       return number;
    Precondition: The user has entered a number of type short
    short. The rest of the line is discarded. If the input is
   public static short readLineShort( )
       short number = -9999;//To keep the compiler happy.
       while (! done)
           try
               number = Short.parseShort(inputString);
               done = true;
               System.out.println(
               System.out.println(
               System.out.println(
               System.out.println(
                        "-32768 to 32767, written as");
               System.out.println(
       return number;
   public static byte readByte( ) throws NumberFormatException
       return Byte.parseByte(inputString);
   public static short readShort( ) throws NumberFormatException
       return Short.parseShort(inputString);
   //The following was intentionally not used in the code for
   //other methods so that somebody reading the code could
   //more quickly see what was being used.
    Reads the first byte in the input stream and returns that
    byte as an int. The next read takes place where this one
    left off. This read is the same as System.in.read( ),
    except that it catches IOExceptions.
   public static int read( )
       int result = -1; //To keep the compiler happy
       try
           result = System.in.read( );
           System.exit(0);
       return result;
