Spragleknas Skrevet 8. april 2006 Rapporter Del Skrevet 8. april 2006 Linken funker ikke! Lenke til kommentar
p@ge Skrevet 8. april 2006 Rapporter Del Skrevet 8. april 2006 Linken funker ikke! 5889103[/snapback] prøv denne: http://majorgeeks.com/download.php?det=4181 lykke til Lenke til kommentar
GenericName Skrevet 9. april 2006 Rapporter Del Skrevet 9. april 2006 Legg til WinRar under komprimeringsverktøy. Lenke til kommentar
O. B. Lix Skrevet 9. april 2006 Rapporter Del Skrevet 9. april 2006 Legg til WinRar under komprimeringsverktøy. 5892960[/snapback] Tror ikke det, er ikke freeware: You may try WinRAR before buy, its trial version is available in downloads. Lenke til kommentar
Håvard Skrevet 9. april 2006 Rapporter Del Skrevet 9. april 2006 Legg til WinRar under komprimeringsverktøy. 5892960[/snapback] Tror ikke det, er ikke freeware: You may try WinRAR before buy, its trial version is available in downloads. 5893013[/snapback] Det funker etter 30 dager trial, men kommer opp sånn ting som maser litt hver gang du starter programmet Lenke til kommentar
p@ge Skrevet 9. april 2006 Rapporter Del Skrevet 9. april 2006 (endret) AVS DVD Player FREE UNIVERSAL DVD, VIDEO & AUDIO PLAYER Support for a very wide variety of video formats: apart from regular DVD (PAL, NTSC, VCD, SVCD) formats, also supported are: the entire range of MPEG4 (including DivX, XviD, etc.), MPEG1, MPEG2, AVI, Real Media video, Quick Time files, WMV files (including WMV-HD), H.263, H.264, mobile video formats (3GP, 3GP2, MP4). This strong compatibility makes AVS DVD Player a universal player; en veldig bra spiller med masse funksjoner !: COMPLETE SET OF ESSENTIAL FEATURES Traditionally available set for comfortable viewing - selection of the view angle (if available on a particular DVD), support for various video sources (HDD, portable media, LAN), automatically adjusted Aspect Ratio, one-click switch to full-screen mode, menu options available at a single mouse click, skinable interface etc. http://www.avsmedia.com/DVDPlayer/index.aspx Endret 9. april 2006 av gaggen Lenke til kommentar
BMP Skrevet 9. april 2006 Rapporter Del Skrevet 9. april 2006 Utrolig mange nyttige programmer her, skal se på noen selv når jeg får litt tid til det. Flott post! Lenke til kommentar
Spragleknas Skrevet 9. april 2006 Rapporter Del Skrevet 9. april 2006 Legg til WinRar under komprimeringsverktøy. 5892960[/snapback] Tror ikke det, er ikke freeware: You may try WinRAR before buy, its trial version is available in downloads. 5893013[/snapback] Det funker etter 30 dager trial, men kommer opp sånn ting som maser litt hver gang du starter programmet 5893475[/snapback] Drit i det... bruk IZARC IZArc is the ultimate archive utility supports many archive formats like: 7-ZIP, A, ACE, ARC, ARJ, B64, BH, BIN, BZ2, BZA, C2D, CAB, CDI, CPIO, DEB, ENC, GCA, GZ, GZA, HA, IMG, ISO, JAR, LHA, LIB, LZH, MDF, MBF, MIM, NRG, PAK, PDI, PK3, RAR, RPM, TAR, TAZ, TBZ, TGZ, TZ, UUE, WAR, XXE, YZ1, Z, ZIP, ZOO. With a modern easy-to-use interface, IZArc provides support for most compressed and encoded files, as well as access to many powerful features and tools. It allows you to drag and drop files from and to Windows Explorer, create and extract archives directly in Windows Explorer, create multiple archives spanning disks, creating self-extracting archives, repair damaged zip archives, converting from one archive type to another, view and write comments and many more. IZArc has also build-in multilanguage support. IZArc is the most complete archive utility available today. Lenke til kommentar
kvase Skrevet 9. april 2006 Rapporter Del Skrevet 9. april 2006 hvorfor ikke ordne seg en mailkonto på 30gig for lagring av det meste å som er gratis. http://www.30gigs.com/ er bare og sign inn Sign up now! It's free! Click Here! Lenke til kommentar
pessimisten Skrevet 10. april 2006 Rapporter Del Skrevet 10. april 2006 hvorfor ikke ordne seg en mailkonto på 30gigfor lagring av det meste å som er gratis. http://www.30gigs.com/ er bare og sign inn Sign up now! It's free! Click Here! 5896246[/snapback] det kan jeg anbefale....brukt det ganske lenge nå og er ganske fornøyd Lenke til kommentar
NoEvo Skrevet 10. april 2006 Rapporter Del Skrevet 10. april 2006 (endret) Hva med Vista transformation pack. At last, Vista Transformation Pack has finally come out! Despite the name Vista, you'll get whole new update and more functions. Get the awesome Vista look today! Vista Transformation Pack will give to your Windows XP system the new and cool look of Microsoft's future operating system: Windows Vista. The pack changes most of the system icons, skins and toolbars and also adds new enhancements to your desktop such as a dock bar or a different system tray clock Well, this is another very big update. In this release, you'll get bunches of stuff you've never seen before in this pack such as Windows Media Player skins, WindowBlinds skin, new stuffs, etc. And bugs I've found are all fixed with 5270 additions. Vista look Endret 10. april 2006 av Vampyr-Cola Lenke til kommentar
dib Skrevet 10. april 2006 Rapporter Del Skrevet 10. april 2006 Gratis Alternativ til Paint Paint .net http://www.eecs.wsu.edu/paint.net/ meget bra, kan minne om notpad2.. samme type forbedring Lenke til kommentar
O. B. Lix Skrevet 12. april 2006 Rapporter Del Skrevet 12. april 2006 Screamer Radio er en nettradioavspiller som i tillegg kan spill inn musikken på harddisk... Meget enkel å bruke! Lenke til kommentar
O.J Skrevet 12. april 2006 Rapporter Del Skrevet 12. april 2006 hva er den beste gratise brannmuren? vil ha en garanti for at den ikke begynner å krangle med bittorrent program når de kjører Lenke til kommentar
mikis Skrevet 12. april 2006 Rapporter Del Skrevet 12. april 2006 Safarp is a small and fast alternative to the Add or Remove Programs Control Panel applet of Windows 2000/XP: http://wistinga.online.fr/safarp/ Startup Control Panel is a nifty control panel applet that allows you to easily configure which programs run when your computer starts. It's simple to use and, like all my programs, is very small and won't burden your system. A valuable tool for system administrators: http://www.mlin.net/StartupCPL.shtml Lenke til kommentar
Evas Skrevet 13. april 2006 Rapporter Del Skrevet 13. april 2006 (endret) Touchlærer'n er gratis og norsk. Et enkelt, men bra program hvis man vil lære seg å skrive lynhurtig på tasterne med alle 10 fingre. http://www.aschehoug.no/alfa/ressurser/6.1.html Endret 13. april 2006 av Evas Lenke til kommentar
jealei Skrevet 16. april 2006 Rapporter Del Skrevet 16. april 2006 Microsoft antispyware har blitt erstartet av windows defender bare så det er sagt, beklager hvis dette er nevt tidligere. Her er en link Lenke til kommentar
whatever909 Skrevet 16. april 2006 Rapporter Del Skrevet 16. april 2006 hvor finner jeg en sie som laster ned photo shop pro GRATIS ? jeg har bare SÅ lyst på det Lenke til kommentar
El Matador Skrevet 16. april 2006 Rapporter Del Skrevet 16. april 2006 hvor finner jeg en sie som laster ned photo shop pro GRATIS ? jeg har bare SÅ lyst på det 5932109[/snapback] Finnes ikke. Her kan du se hvor du kan skaffe det billigst mulig. Lenke til kommentar
whatever909 Skrevet 16. april 2006 Rapporter Del Skrevet 16. april 2006 men..broder har lastet det ned gratis ..men han vil ikke si det til meg:( ..han tror nokk at jeg kan bli bedre enn han Lenke til kommentar
