All verdens nyttigste gratisprogrammer
Jonhoo
AKGBackup
Javabasert backup prg. Trenger ikke å instaleres.
http://www.akgupta.com/applications/akgbackup.htm
Features:
      This backup utility can compress data while backing up if you choose so. It compresses individual files separately. This feature is a precautionary measure. Compressed archives do get corrupted and if there is a single archive for all your files (most of the backup programs create a single archive for your files and folders), you may lose all your files in one go if something goes wrong. Remember Murphy's Law? Still not convinced? Read here what one of the users of AKGBackup said about this feature.
      The compression feature of this program can be used as a simple but effective encryption tool for backed up files.
      You can choose to mirror any deletions in your data source. If you delete any files in the original location, those files will also be deleted in the backup. In other words, you will have a mirror image like backup all the time. You can also choose not to have such a backup in which case even if a file is deleted in the source folder, it will remain in the destination folder (where you have chosen to backup your files) waiting to be restored if and when you require it.
      It is also possible to specify the total number of backups of the same data. This feature is particularly useful when some rewritable medium, such as a hard disk or a tape, is used as backup medium. For example, if you choose to have seven number of backups, then you will have seven most recent sets of data.
      Once you create a backup using this utility, subsequent backups are very fast. This program looks for any new or modified files and backs them up saving a lot of time ensuring that you have a most current backup all the time.
Hei igjen, i Frankrike naa :p
Inf3rn090, takk for alle programmene, du kan ikke komme med linker og en kort beskrivelse av hver av programmene saa jeg ikke maa prove alle sammen selv?
Til dere andre, skal oppdatere forste traad saa fort jeg kommer hjem og faar orden paa maskinen igjen...
Til da, staa paa :p
PS: Hyggelig at folk ikke synes traaden er unyttig :D
Lastet ned DLL archive og kjørte det. Nod32 rapporterte to tilfeller av Elite tollbar (spyware) som fulgte med. Bør kanskje fjernes fra listen? Eller noen vil verifisere dette slik at vi har det fra to kilder ihvertfall?
Endret av gwh
Til da, staa paa :p
Jeg gidder ikke finne fram listen min med programmer og slikt, men jeg skal legge ut linker på hjemmesiden min :D . Du kan laste dem ned der. http://www.inf3rn0.tk/ , eller hvis du er "redd" for .tk http://www.home.no/inf3rn0/ :D
Vet noen om et bra dvd brenner program? (gratis selfølgelig)
De jeg har prøvd kan ikke spilles av, av vanlige dvd spillere, for de var mer som cd'er. Slik at jeg åpnet det som en mappe.
Jeg hadde et knall program som het MAGIX CD & DVD BURNER, men jeg finner ikke cd'en :( (jeg har netopp formatert....)
Prøv DeepBurner (som du finner link til i første post i denne tråden).
Noen som har et forslag på en bra dvd-avspiller for data?
Windows Mediaplayer?
