|KAN| Skrevet 21. juni 2002 Del Skrevet 21. juni 2002 hvordan kan jeg tweake cs ... ting jeg ikke trenger er røyk fra skudd hull... patroner... og andre småting ... Lenke til kommentar
Ronnyb Skrevet 21. juni 2002 Del Skrevet 21. juni 2002 //MAX FPS INSTILLINGER fps_max "99" fps_modem "99" //LYD INSTILLINGER, A3D LYD AV s_a3d "0" s_eax "0.000000" //RATE INSTILLINGER FOR ISDN, IKKE BRUK PÅ ASDL rate "5500" cl_cmdrate "20" cl_updaterate "20" cl_rate "5500" cl_lw "1" cl_lc "1" cl_latency "-25.987" tracker "0" cl_dlmax "128" cl_himodels "0.000000" cl_idealpitchscale "0.8" cl_timeout "35" cl_cmdbackup "2" cl_download_ingame "1" cl_allowdownload "1" cl_allowupload "1" //DIVERSE INSTILLINGER SKRUDD AV setinfo "vgui_menus" "0" setinfo "ah" "0" setinfo "dm" "0" //TAR VEKK VÅPENET FRA SKJERMEN, GIR DEG SIRKA 10FPS r_drawviewmodel "0" //DIVERSE INSTILLINGER SOM GJØR DET LITT "BLURRY" MEN GIR MASSE FPS gl_dither "0" gl_overbright "0" gl_palette_tex "0" gl_keeptjunctions "0" gl_wateramp "0" gl_ztrick "1" gl_lightholes "0" gl_spriteblend "0" gl_polyoffset "0.1" gl_cull "1" gl_smoothmodels "0" gl_monolights "0" gl_picmip "1" gl_playermip "1" gl_max_size "64" gl_alphamin "0.5" gl_polyoffset "0.1" gl_monolights "0" gl_flipmatrix "0" max_shells "0" gl_monolights "0" max_smokepuffs "20" gl_cull "1" mp_decals "0" Lenke til kommentar
Gjest Slettet+1374861 Skrevet 30. august 2002 Del Skrevet 30. august 2002 maxsmokepuffs 0 r_decals 0 mp_decals 0 Lenke til kommentar
