Diskuter din Paladin her!
Her er guiden jeg brukte når jeg gearet opp.
Men nå er det en hel del endringer som er å anbefale:
Shield: SSO exalted
Weapon: Crystalforged Sword, SSO Mace, S2 Arena Mace
Chest: Badge chest (den med 3 sockets)
Legs: Badge legs
Head: Helm of Righteousness
Enchant: Glyph of the Defender
Neck: Strength of the Untamed
Shoulder: Spaulders of the Righteous
Enchant: Greater Inscription of the Knight
Back: Devilshark Cape
Enchant: Dodge
Chest: Jade-Skull Breastplate
Enchant: Exceptional Health
Wrist: Bracers of the Green Fortress
Enchant: Major Defense
Hands: Felsteel Gloves
Enchant: Superior Agility
(Note: this enchant can be switched for the major Spellpower one if you need the threat gen)
Waist: Girdle of the Immovable
Legs: Timewarden's Leggings
(Leatherworking) Enchant: Clefthide Leg Armor
Feet: Boots of the Colossus
Enchant: Fortitude
Ring 1: Protector's Mark of the Redemption
Ring 2: Elementium Band of the Sentry
Trinket 1: Adamantine Figurine
Trinket 2: Figurine of the Colossus
Weapon: Continuum Blade
Enchant: Major Spellpower
Shield: Crest of the Sha'tar
Enchant: Shield Block
Libram: Libram of Repentance
Gems: Solid Star of Elune (x16)
Ok now for the summary of all those stats.
Sta: 467 (from gear) + 123 (base for a BE) + 192 (16 gem slots all filled with +12sta gems) = 782 * 1.06(the talent any decent protadin will have) == 828.92 stam
Def: 345 Rating: [(345/2.4)+20]/25*4 = 26.2 avoidance from Def (block/dodge/parry/miss)
Block: 82 Rating: 82/7.9 = 10.4 Avoidance
Dodge: 118 Rating: 118/18.9 = 6.24 Avoidance
Parry: 0 = 0
SO:
That stam == 11,606 Hp
Total Block = 21.95
Total Dodge = 17.79
Total Parry = 16.55
Total miss = 11.55
Block From HS = 35%
All this together makes :
HP = 11606
Avoidance = 102.8%
So as i said 11.5k HP and Uncrushable.
Oh and if you don't want to go to heroics for the belt or boots... you can replace them with:
Flesh Beast's Metal Greaves
and
Sha'tari Vindicator's Waistguard
Now this will drop you down about 50 sta or 530 Hp's But personally i think 11k and uncrushable is fine if you don't want to deal with the heroics before Kara.
Endret av Zepticon
Jeg har funnet ut at det kan være greit med skjold + 1h på paladinen min i pvp for stunder jeg blir focused uten mulighet til å gjøre dps. Derfor har jeg noen spørsmål:
Hvilket skjold? Arena? Jeg har Bulwark of the Amani Empire og Shield of Impenetrable Darkness liggende i banken. Noen av disse? Og er det +18 stamina enchant som gjelder?
Hvilket våpen? Jeg har Gladiator's Gavel fra tidligere tanking, men har kastet den nå. Kan ta en itemrestore om det er denne jeg bør gå for. Har en +40dmg enchant på den, men kan selvfølgelig enchantes om.
Eventuelt har jeg Cudgel of Consecration med +12 stamina gem og +40dmg enchant.
Siste alternativet jeg allerede har er Amani Punisher, uten enchant.
Bør jeg gå for en av disse, eller et annet våpen? Og isåfall, hvilken tilhørende enchant?
Takk for hjelpen.
Er speccet 0/20/41.
Endret av Lycantrophe
ville tatt Bulwark + Gladiator eller Cudgel, ekker sikker, nice med mer resilience men Cudgel har jo mer stam med 18stam gem i. Jeg stemmer dog for bubble! funker i alle situasoner =D
Bubble har 5min cooldown. :)
Tingen er: Jeg har lite jeg trenger spelldamage til, enda jeg blir focused. Det er heller til en liten mulighet til å utsette døden og gjøre det lettere for druiden min når jeg har masse melee dps på meg. Enchants er derfor greit om hjelper på nettopp dette. Har fått battlemaster foreslått, men tviler på at den kommer til å hjelpe voldsomt. Mongoose for dodge hjelper vel litt mot warriors og rogues, men procsjangsen er vel ike veldig høy, nok til å gjøre den pålitelig.
Flere forslag?
Bulwark + Gladiator mace gir deg jo
5400 Armor
103 stam (om shield har 15stamina gem og 18stamina enchant)
18resilience
199SD and healing (kan jo være greit om du skal prøve å heale noe \o/
nevnte stats er jo ganske grei boost i overlevelse om feks en rouge skal prøve å pirke bortpå deg
Personlig ville jeg spart opp til http://www.wowhead.com/?item=32045 masse armor og res =)
Edit; enchant, ekke så skilla i arena men kanskje Deathfrost? http://www.wowhead.com/?item=35498
Vil tro tregere attackspeed er kjekt å ha i arena også =P kanskje problemer med at den alltid vil bli dispella...ikke vet jeg
Endret av Cosha
