Den store Warrior tråden..
med nuke regner jeg med at du mener at mager nuker ham? Hvor mange mager bør man ha? Og sier du at vi bør drepe raptor først? Mens MT tanker boss? Og når raptor dør....er det all out dps mot bossen da? Elelr bør alle andre enn MT bruke range mot ham?
Mini me : 20 Agility gir + 1 critt.
Gamer 73:
Slik tar vi han :
Bloodlord Mandokir
Bloodlord Mandokir is accompanied by a Speaker. As soon as you kill it, Mandokir will ride down the stairs on his Raptor, Ohgan, dismount, and engages you.
As soon as he dismounts, Ohgan will engage you as well.
Mandokir has the following features:
- Enrage. Will cause extra damage for ~25 seconds after Ohgan dies.
- Threatening Gaze. If he's watching you, you need to stop all action immediately.
- Mortal Strike.
- Whirlwind.
- Charges the person furthest away from him.
- Level up after killing someone who's being watched.
Tactics:
After the melee dps has killed the Speaker, Mandokir rides down, and dismounts.
Positioning as seen below:
MT will grab Mandokir, and move into killing position.
OT will grab Ohgan, and move into killing position, out of melee range of Mandokir.
Positions for the rest of the fight:
All DPS classes will first focus on killing Ohgan, and then focus all dps on Mandokir, while keeping their aggro in check.
If you are being watched (affected by Threatening Gaze), stop all activity, and wait for the debuff to wear off.
All melee DPS needs to turn around and run away whenever Mandokir begins to cast Whirlwind. It hits for ~2000 damage, and the healers might need the mana for the MT.
Det er viktig med aggro kontroll her både på raptor og Bloodlord så de ikke løper vekk fra MT 1 og 2 og slakter party members. :)
Ganske enkelt encounter når dere får litt erfaring.
Fin boss for warriors også, dropper tre bra items for deg :)
http://wow.allakhazam.com/db/item.html?witem=19867 Fint tanke sverd
http://wow.allakhazam.com/db/item.html?witem=19866 (kan være rogues får prioritet på denne )
http://wow.allakhazam.com/db/item.html?witem=19874 Helt grei Polearm
Lykke til :=)
Foresten hvordan gikk det med Batbossen?
Endret av Darkrevan
5859440[/snapback]
Nuke = alle gjør max dps. Raptoren er ikke noe stress så lenge offtank har fått inn et par sunders. Etter dette bandasjerer dps-delen seg og gjør lett dps mens MT får full fokus fra healerne. Etter et minutt eller to (er ikke helt sikker på hvor lang tid enrage varer) roer han seg, og da kan folk begynne med nuking.
Og, ytterst viktig at folk vet hva "I'm watching you!" betyr.
mini me: 21 agi = 1% crit.
Darkrevan: 25 sekunder? Jaha?
Posisjoneringen på de bildene der er vel fra før ting ble buffet opp. Nå er det ikke noe poeng i å stå på den forhøyningen med spydene.
Endret av psilocybe
5859440[/snapback]
5859665[/snapback]
Vel dette er guildtacks og vi bruker dem enda. :)
5859440[/snapback]
Raptor må ned først mens MT tanker.
Viktig at da raptor dør så må MT heales bedre, Bloodlord blir litt vill og gal da hans kjære pet og mount dør.
Får MT aggro til å sitte her så kjør på med full nuke og pass opp for im watching you. Meele dps bør hoppe unna whirlwind så de ikke blir truffet av den. De må også bruke bandage så healers kan priorietere MT. :)
til dark. Vi tok ned både bat boss og spider boss uten videre problemer når vi fikk summet oss hehe. Jeg så at raidleder brukte omtrent samme taktikk som du viste før her på disse, og da sa ikke jeg et ord og bare gjorde det jeg fikk beskjed om:)
Da har jeg tanket BRD med min lvl 56 warrior! :) Gøy ^^
Så lurte på; På kartet til wow-europe.com står det at både Stratholme og ZG er lvl 56+ instances! Er dette riktig? Isåfall, så drar jeg dit så fort sjansen byr seg ^^
Fikk tilbud om å bli med i strat scarlet på søndag, men takket nei, ettersom jeg ventet på fiskekonkurransen...! Fikk forresten Nat Pagle's boots of perfect angling :w00t:
