Den store Warrior tråden..
Hvilke patchnotes tenkte du på, show
Mulig de er gamle, men har klip og limt de jeg leste:
Warriors
Cleave damage has been reduced by approximately 17%.
Execute damage has been reduced by approximately 17%.
Heroic Strike damage has been reduced by approximately 17%.
Overpower now does 125% weapon damage, down from 150%.
Rend base damage has been reduced by approximately 17% and percent of weapon damage per tick lowered to 25%, from 30%.
Shield Block now only increases block chance by 25%, but excess block that pushes avoidance plus block to over 100% is now converted to critical block chance.
Slam now costs 15 rage, down from 20, and now does 125% weapon damage, down from 150%.
Victory Rush damage has been reduced by approximately 17%.
Whirlwind now does 65% weapon damage, down from 75%.
Talent Specializations
Arms
Mortal Strike now does 150% weapon damage, down from 185%.
Second Wind now heals for 2/5% of total health, down from 5/10%.
Strikes of Opportunity now does 100% weapon damage, down from 115%.
Fury
Blood Craze now heals for 1/2/3% of total health, down from 2.5/5/7.5%.
Bloodthirst damage has been reduced by approximately 17%.
Raging Blow now does 110% weapon damage, down from 150%.
Unshackled Fury now gains approximately 50% more benefit per point of Mastery.
Protection
Critical Block now grants an equal amount of block chance and critical block chance (1.5% each per point of Mastery).
Devastate no longer provides bonus threat.
Shield Slam: Contribution of attack power reduced to 60%, down from 75%, and base damage brought up so that a level 85 warrior in Heroic dungeon gear deals the same damage with no Vengeance, but Vengeance has less impact. In addition, Shield Slam no longer generates 30% bonus threat from its damage.
Vigilance no longer provides 3% damage reduction, but still refreshes Taunt and provides Vengeance.
  • 3 uker senere...
Starter du fra level 1 igjen? Ettersom det er "flere år siden" så tror jeg du uansett vil oppleve det aller meste som nytt. Som damage warrior, dvs. Fury eller Arms warrior, vil du på høyere nivå bruke 2handere. Ting som hit-rating og expertice-rating er noe man på level 85 vil fokusere på. Talents har blitt modifisert en del, men dette er ting du forstår uansett. Av annet som er nytt har Glyphs blitt lagt til, som du kan se i talenttree-kalkulatoren. Dette er tilleggsting man har til talenter, laget av folk med professionet Inscription.
Men fra start så vil jeg bare si, spill det og lær deg det. Når du levler så er det vel bare å plukke med seg det utstyret man får. Når du til slutt kommer på høyeste nivå, si level 80 eller høyere, så kan du spørre om hjelp hvis det er noen steder du føler deg usikker på ting.
On a side note; warriors are awsome!
  • 2 uker senere...
  • 1 måned senere...
  • 3 uker senere...
Den pluss at du får 80+ stats av flask, men om det er den beste proffesion? Tror jewelcrafting har 1 stamina mere enn det alchemy får. men det er den beste proffesion før du begynner og raide.
Endret av prez
Leatherworking er den klart beste profession for Warriors. Man får +195 Stamina på bracers, som er 155 Stamina mer enn nærmeste Stamina enchant. Dette banker alle andre professions med 34/35+ Stamina.
Nest beste er antageligvis Jewelcrafting som ligger 1 Stamina foran Alchemy, Blacksmithing, Enchanting, Mining og Inscription. Engineering er vanskelig å sette verdi på med sin +1500 Armor (?) i 12sec.
Herbalism, Skinning og Tailoring er pretty much ubrukelig.
Sånn er det når du ser på random sider, kan gi deg en veldig grei noob side, altså ikke helt noob men de har grei oversikt over items og slikt...
www.maxdps.com
Da ser du i allefall hva som ligger oppe og nede og slikt, men som sagt, ikke noe for pr0s.
