Budget dvd-r 4.7gb
Jeg har kjøpt 50 stk Budget dvd-r 4.7gb,de er merket nede med (www.01ne.co uk)Er disse brukbare til noe?Får følgende info.....
** INFO : Hex Dump Of 'Control Data Zone'-Block Listed Below
** INFO : 4-Byte Header Preceding 'CDZ'-Block Discarded
** INFO : Format 10h - Format Information Of Control Data Zone
0000 : 25 0f 02 00 00 03 00 00 00 26 12 7f 00 00 00 00 %........&......
** INFO : Hex Dump Of 'Media Code'-Block Listed Below
** INFO : 4-Byte Header Preceding 'Media Code'-Block Discarded
** INFO : Format 0Eh - Pre-Recorded Information In Lead-In
0000 : 01 40 80 12 23 00 52 00 02 88 0d 13 66 78 80 00 .@..#.R.....fx..
0010 : 03 53 4b 43 20 43 6f 00 04 2e 2c 4c 74 64 2e 00 .SKC Co...,Ltd..
0020 : 05 88 80 00 00 00 01 00 06 0b 14 11 87 78 80 00 .............x..
0030 : 07 88 80 00 00 00 00 00 08 07 1c 0d 10 0a 0b 00 ................
0040 : 09 97 07 0f 0b 68 88 00 0a c0 00 00 00 00 10 00 .....h..........
0050 : 0b 06 1c 13 a8 88 65 00 0c 98 9a 88 80 00 00 00 ......e.........
0060 : 0d 00 00 d0 00 00 00 00 00 00 00 00 ............
** INFO : Drive = LITE-ON DVDRW LDW-851S [FW GS08]
** INFO : Write Capabilities = DVD+RW DVD+R
** INFO : Write Capabilities = DVD-RW DVD-R
** INFO : Disc = [DVD-R:SKC Co.,Ltd.]
** INFO : An Empty Writable Disc Is Recommended For Accurate Results
** INFO : Write Speeds (Supported By This Drive On This Disc) Listed Below
** INFO : GET PERFORMANCE Write Speed Descriptor(s)
Descriptor #1 = 5540 KBPS ( 4.00x) - [CLV/Non-Pure CAV]
Descriptor #2 = 2770 KBPS ( 2.00x) - [CLV/Non-Pure CAV]
** INFO : MODE SENSE Write Speed Descriptor(s) [Legacy Command]
** INFO : MODE SENSE Is Obsolete And Not Properly Supported By Some Drives
Er disse dvd platen ok?Har ikke brent noe enda på de.
Fikk dette etter forsøk.....
Vet ikke om det sier noe om kvalitet?
Gjest Slettet-10579
Det du har postet i post nr 2, er jo det samme som i post nr.1
Dersom du brenner en DVD, og bruker den DVD`en med Identifier, så vil du få et annet resultat, som sier hvem som er produsent.
OC, rett meg hvis jeg tar feil :)
Du sier levetid OC-freak, jeg kjøpte noen Taiyo Yuden for en stund siden, og synes å has lest at disse skulle være bra.
Hvordan er levetiden på slike plater ?
btw..detter var noen DVD+R plater...
Taiyo Yuden sier 100 år +
Taiyo Yuden gir også 100 års garanti mot feil som skyldes produksjonsfeil.
Gjest Slettet-10579
Jeg har noen Thats Write DVD+R 4x som jeg brenner på 8x/12x og som fungerer helt bra.
Er svært skeptisk til optodisc, spesielt levetid grunnet tidligere erfaringer....
Ja, men her er det egentlig ikke noe problem, de fases ut hver 7. dag.
Hvilke dvd vil dere anbefale som er rimelige,men gode,til og brenne film på? :hmm:
Jeg foreslår disse, så får dere andre hamre løs hvis det er et dårlig forslag :)
Edit: DVD-R, ja. Noen som kan uttale seg om Intenso-platene som selges her? Ser det er til dels betydelig prisforskjell på 4x og 8x, men det er ikke dermed sagt at man har med en stor kvalitetsforskjell å gjøre.
Endret av KAS
Er denne dvd brenneren brukbar til dvd plater av forskjellige merker.............[ LITE-ON DVDRW LDW-851S ]
Enhets Egenskaper:
Driver beskrivelse LITE-ON DVDRW LDW-851S
Driver dato 01.07.2001
Driver versjon 5.1.2535.0
Driver leveradør Microsoft
INF Fil cdrom.inf
Optisk disk egenskaper:
Produsent Lite-On
Enhets type DVD+RW/DVD-RW
Hastighet DVD+RW:8x/4x, DVD-RW:4x/2x, DVD-ROM:12x, CD-RW:40x/24x/40x
Har ikke så mye greie på dette,har ikke brukt dvd brenner før,bare cd brenner.Kjøpte denne for 400 kr?Vil jo helst ha skikkelige dvd plater,så man er sikret mot feil på grunn av de.Det er jo mengder av dvd ute på markedet,og noen av de er sikkert ubrukelig?
Endret av arnulf50
Generelt sett så rangerer jeg DVD-Brenner produsentene jeg har erfaring med slik. Beste på toppen:
1: BenQ/Philips
2: LG
3: NEC
4: Pioneer
5: Plextor
6: Lite-On
7: Samsung
8: AOpen
9: BTC
Etter min mening er det kun de 5 første produsentene som er verdt å vurdere ved innkjøp av ny brenner.
Samme rangering for en del DVD-Plate PRODUSENTER (ikke merke!! her snakker jeg om produsent). Kan ha glemt noen.
1: Taiyo Yuden
2: Maxell
3: TDK
4: Mitsubishi
5: Ricoh
6: Daxon
7: Prodisc
8: CMC Magnetics
9: Ritek
10: Moser Baer India
Resten nedover listen er etter min mening mindre aktuelle og man bør styre unna dem.
OBS! på at jeg kan ha glemt noen merker av god kvalitet... er trøtt så sent på kvelden :p
1: Taiyo Yuden
2: Maxell
3: TDK
4: Mitsubishi
5: Ricoh
6: Daxon
7: Prodisc
8: CMC Magnetics
9: Ritek
Sent på kvelden? Ja den var god!
NÅ er det sent :!:
Burde ikke BeALL vært på lista?
Jeg mener de er bedre enn ustabile CMC Mag også!
Ekte Fujifilm burde vel også være der, men er vel ikke så lett å få tak i...
NÅ er det sent :!:
"EKTE" fujifilm? :p
Så vidt jeg vet produserer ikke fujifilm DVD plater selv.
FUJIFILM03 er produsert av:
1: mest valig: Prodisc.
2: Moser Baer India
3: Ritek (ikke for salg da Fujifilm DYE ble for dyr :().
Jo BeALL er også bra - men de andre 10 som er nevnt her er også bra -BeALL er ikke enkle å få tak i her i landet.
