Gameport til USB overgang
vr
Det var jo dumt. Men den kan stilles inn "custom" for flere typer joysticks iallfall, det er da noe.
The RM-203 has a 4-mode switch. Mode 1 is used with a type TM-FCS controller. Mode 2 is used with a CH FLIGHTSTICK PRO controller. Mode 3 is used with a 2-4 AXIS 4-BUTTON controller. Mode 4 is used with a 2 AXIS 8-BUTTON controller.
Fra http://www.usb-port.com/rm203.html
(Samme produktet, men Rockfire er glade i å sette på sin egen logo.)
