Pogram for oversikt over trådløse nettverk, ubuntu
da prøver jeg det :D tusen takk!
usj liker ikke at ubuntu har så få pakker i synaptic package manager eller hva den heter... må jo laste ned diverse ting hele tiden for å legge inn en ting....
freebsd ports har jo 3893939 ganger så mye stuff i pakkesytemet :( eller er det bare jeg som ikke har skjønt at man kan legge til en haug med andre ting ? isåfall hvordan :)
Endret av WaBBiT
hvordan!? :D jeg la inn linux for første gang denne uken :D
EDIT: eh airsnort vil ikke installere? :S
make  all-recursive
make[1]: Entering directory `/home/erik/My Downloads/airsnort-0.2.7e'
Making all in src
make[2]: Entering directory `/home/erik/My Downloads/airsnort-0.2.7e/src'
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -DPACKAGE_DATA_DIR=\""/usr/local/share"\" -DPACKAGE_LOCALE_DIR=\""/usr/local//locale"\" -DXTHREADS -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/X11R6/include -I/usr/include/atk-1.0 -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include      -g -O2 -MT callbacks.o -MD -MP -MF ".deps/callbacks.Tpo" -c -o callbacks.o callbacks.c; \
then mv -f ".deps/callbacks.Tpo" ".deps/callbacks.Po"; else rm -f ".deps/callbacks.Tpo"; exit 1; fi
callbacks.c:9:18: pcap.h: No such file or directory
In file included from callbacks.c:24:
PacketSource.h:32:18: pcap.h: No such file or directory
PacketSource.h:153: error: parse error before "pcap_t"
PacketSource.h:153: warning: no semicolon at end of struct or union
PacketSource.h:154: warning: data definition has no type or storage class
PacketSource.h:163: error: parse error before '}' token
PacketSource.h:163: warning: data definition has no type or storage class
PacketSource.h:173: error: parse error before '*' token
PacketSource.h:174: warning: data definition has no type or storage class
PacketSource.h:175: error: parse error before '*' token
PacketSource.h:176: error: parse error before '*' token
PacketSource.h:176: warning: data definition has no type or storage class
PacketSource.h:177: error: parse error before '*' token
PacketSource.h:178: error: parse error before '*' token
PacketSource.h:179: error: parse error before '*' token
In file included from bssidlist.h:35,
                from display.h:23,
                from callbacks.c:29:
capture.h:25:18: pcap.h: No such file or directory
                from display.h:23,
capture.h:49: error: parse error before "PacketSource"
capture.h:49: warning: no semicolon at end of struct or union
capture.h:51: error: parse error before '}' token
capture.h:51: warning: data definition has no type or storage class
callbacks.c:79: error: `PCAP_ERRBUF_SIZE' undeclared here (not in a function)
callbacks.c: In function `on_Start_clicked':
callbacks.c:368: error: `ca' undeclared (first use in this function)
callbacks.c:368: error: (Each undeclared identifier is reported only once
callbacks.c:368: error: for each function it appears in.)
callbacks.c:378: error: parse error before ')' token
callbacks.c: In function `on_pcap_ok_clicked':
callbacks.c:670: error: `ca' undeclared (first use in this function)
callbacks.c:670: error: parse error before ')' token
callbacks.c: At top level:
callbacks.c:79: error: storage size of `errbuf' isn't known
make[2]: *** [callbacks.o] Error 1
make[2]: Leaving directory `/home/erik/My Downloads/airsnort-0.2.7e/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/erik/My Downloads/airsnort-0.2.7e'
make: *** [all] Error 2
Endret av WaBBiT
det funket nesten ja ! det står "Could not set monitor mode".. hva har jeg gjort galt da? har valgt riktig nettverkskort o.l
mens vi er igang, hvordan kan jeg få batteri monitoren til å vise riktig? den sier at jeg kjører på batteri og har 0% batteri hele tiden... jeg har en toshiba portege 3410CT laptop...
Endret av WaBBiT
har du husket å kjøre den med root-privilegier? sudo airsnort
for å bare få oversikten kan du skrive iwlist scan
lars@aotearoa:~ $ iwlist scan
lo        Interface doesn't support scanning.
eth0      Scan completed :
         Cell 01 - Address: 00:11:2F:E3:1E:B6
                   ESSID:"****"
                   Protocol:ieee 802.11g
                   Mode:Master
                   Channel:1
                   Bit Rate:54Mb/s
                   Extra: Rates (Mb/s): 1 2 5.5 6 9 11 12 18 24 36 48 54
                   Extra: RSSI: -58  dBm
                   Encryption key:on
eth1      Interface doesn't support scanning.
sit0      Interface doesn't support scanning.
når jeg gjør det du gjør så får jeg opp ca det samme som deg, men hvis jeg kjører airsnort med sudo så henger det seg/ slutter å svare elns når jeg velger orinoco, og velger jeg other så må jeg sette monitor mode manuelt?? (hvordan gjør jeg det),
og velger jeg std. wlan-ng så står det bad address i terminalen... :S
Airsnort støtter få kort, og hvis du ikke har et av kortene den støtter får du "wlan-ng: bad address"-feilen.
iwlist viser alt du ba om. men kan ikke knekke noen koder.
jeg får heller ikke airsnort, kismet og fakeAP til å funke. er litt dumt. har lyst til å prøve dem. noen som har peil på hvilken chip det er i intel centrino-pakken? de kreves prism, cisco eller noe sånt, så jeg regner med jeg ikke har det. fins det noen omveier, alternative programmer som støtter flere kort?
