Sparkle 6800GT Noen erfaringer?
k.rab
Sjekk ut produsenten:
http://www.sparkle.com.tw/
Kortet virker faktisk ikke noe dårligere enn sine konkurrenter!
En liten konklusjon på en test av kortet:
The Sparkle GeForce 6800 Ultra
Enough intrigue, let’s stay with what we have in front of us, and what we have is an excellent product! This Sparkle card has excellent performance: perhaps not quite the fastest on the planet, but as we’ve already pointed out, this type of power will be throttled back by the CPU anyway. The 6800U has full support for Shader Model 3.0 code and may well deliver a coup when Doom3 finally arrives. Until then Sparkle have bundled a wide variety of games that should keep anyone entertained.
But gaming isn’t everything. This card also has dual DVI outputs, which is a significant addition on a consumer level board. Plus, the new GPU can also perform hardware video compression and accelerate many video effects thanks to its programmable engine. Again, Sparkle have thoughtfully included a high-quality SCART adapter plug for European consumers.
It’s all too easy to get waylaid in high-end product comparisons and lose sight of what really matters. In the end, this Sparkle GeForce 6800 Ultra card is a fantastic product that anyone would be proud to own.
Currently this card retails for £340 (Ex VAT) in the UK, and around $550 once it reaches the US. Previous new generations of graphical technology have retailed for as much as £399 and none have delivered two to three times the performance of the previous generation. For this reason a price tag of £340 actually represents good value in relation to the history of video card releases.
www.dcs-online.biz
We are pleased to present the Sparkle GeForce 6800 Ultra card with our Gold award for excellence.
Fordeler: Ulemper:
1. Performance! 1. Needs at least 400 Watt PSU
2. Shader Model 3.0 2. Won't fit in many SFF systems
3. Dual DVI output 3. Takes up two slots
4. Performance!!! 4. Wife will leave you
92%
Så da er det bare å bestille kortet!
:thumbup:
Hehe, takker for det.
Kommer den 15/2, ser fram til det
Jeg er jo litt skeptisk da, siden jeg aldri har hørt om Sparkle før :p
men det kan jo nesten ikke slå helt feil. Det blir spennede i hvertfall, blir deilig å få skifta ut mitt gamle FX 5200 :!:
