Ronnie Skrevet 9. februar 2005 Del Skrevet 9. februar 2005 (endret) ATI har sluppet nye drivere Cat 5.2, grabb dem her. ATI Her er "release notes" for de nye driverne. New Features This section provides information on new features introduced in the latest release of the CATALYST™ Software Suite. The CATALYST™ Software Suite 5.2 introduces 3D setting options to the CATALYST™ CONTROL CENTER system tray. The shortcut allows the user to easily adjust their 3D settings without having to load the CATALYST™ CONTROL CENTER. The 3D setting submenu will be found in the Adapter menu of the system tray. When a user selects the 3D submenu option, the following options will be made available: Anti-Aliasing. Application managed options include, 2X, 4X, 6X, and Enable Temporal Anti-Aliasing Anisotropic filtering. Application managed options include, 2X, 4X, 8X, and 16X. CATALYST™ A.I. (For RADEON™ 9700 and above). Options include: Disabled Standard Advanced Mipmap detail level. Options include; High performance, Performance, Quality, and High quality. TRUFORM™. Options include; Application pref, or Always Off. Wait for vertical refresh. Options include; Always off, Off unless application specifies, On unless application specifies, and Always on Direct3D Setting. Options include; Enable geometry instancing, Support DXT texture formats, and Alternate pixel center OpenGL Settings. Options include; Triple buffering, and Force 24-bit Z-buffer depth This feature is supported on ATI RADEON™ 9500 series or higher product line. Performance Improvements As with most CATALYST™ releases performance has increased in various situations. The following performance gains are noticed: Efficiency improvements in vertex processing have produced performance enhancements in key applications such as Far Cry and 3DMark05 on RADEON™ X850, X800 and X700 series products Far Cry "Regulator" and "Volcano" scores are up as much as 20% on RADEON™ X800 PRO at 1600x1200 resolution 3DMark05 gains range from 1-3% on RADEON™ X800 series products to as much as 9% on some RADEON™ X700 configurations Issues Resolved in CATALYST™ Display Driver Version 5.2 The following section provides a summary of the issues that have been resolved in the latest version of CATALYST™. These include: 4x4 Evolution2: Attempting to play the game under Windows XP with an ATI RADEON™ X300/X600 series installed no longer results in the operating system failing to respond when the screen is set to 1600x1200 32bpp and OpenGL Renderer is enabled 4x4 Evolution 2: Display corruption is no longer noticed when having the display set to 1600x1200 32bpp along with the texture detail set to high and split screen rendering enabled Serious Sam: Playing the game under Windows XP results in the display flashing when TRUFORM is enabled Sims 2: Playing the game Veronaville under Windows XP while having the desktop set to 1024x768 32bpp along with AA set to 6X no longer results in corruption being noticed in the fields Selecting the option; Enable Video Mode, results in the CATALYST™ CONTROL CENTER not being able to return to the default setting for the Enable Video Mode option Switching language support for the CATALYST™ CONTROL CENTER no longer results in the slider bar for the engine clock being enabled when the option found in OVERDRIVE™ is locked Navigating to View->Define a Custom View and deselecting all options found in the 3D option of the Edit Custom View tab, no longer results in the Standard Settings option remaining selected Intermittent failure of the VPU Recover report not being sent is now resolved Double-clicking the slider bar found in CATALYST™ A.I. no longer results in the Disable CATALYST™ A.I. option becoming de-selected Disabling 3D preview no longer results in the preview continuing to run on a secondary display device Having the 3D preview running on the secondary display adapter and attempting change display modes, no longer results in the primary display device displaying a black screen and error messages appearing English is no longer the default language when installing the CATALYST™ CONTROL CENTER under Windows XP Japanese version The CATALYST™ CONTROL CENTER Version number is now displayed correctly in all localized languages The Display Manager Notification dialog box is now displayed in the correct localized language The OpenGL driver is no longer disabled after boot up when both AGP Read and PCI Read are disabled Endret 9. februar 2005 av Ronnie Lenke til kommentar
*Magnus* Skrevet 9. februar 2005 Del Skrevet 9. februar 2005 så det nettopp selv på ati sia... laster ned Lenke til kommentar
