Ny bios til Xecuter 3 er sluppet
G-M-L
Team Xecuter har endelig sluppet den nye bios'en.
Team Xecuter web site
Finally it's here. The most advanced bios ever written for the Xbox. Nothing comes close - if you think it does you need to have your brain de-bugged.
Here is a breif changelog - you should already know about the XICS (Xecuter Install Command System) and the XASC (Xecuter Advanced Skinning Control) - we added a few other bits and bobs since the first beta build 2666 and a TON of bugs have been fixed thanks to the input of Xecuter's Beta Team. Let's hope xbins stays up long enough - enjoy !
[2913]
- fixed: Fixed a ton of bugs since Build 2666 first announcement (2913 first public release)
- fixed: "Odd" character problem in FTP
- fixed: The "all files are good" issue in ftp, now it will check properly if the file really got there
- fixed: IE FTP Bugs Fixed
- fixed: Qwix DIR listing bugs
- fixed: Threading-issue that sometimes left an idle thread when executing dashboard
- fixed: Total re write of menu loading mech - faster and rock solid stability
- fixed: Cleaned up video init code
- fixed: Corrected LFRAME / D0 pull to 0V timing so it's no longer constant
- fixed: Flubber now displays in 480p (if possible)
- added: Xecuter Install Command System*
- added: Xecuter Advanced Skinning Control**
- added: VGA support for ALL Xbox versions (v1.0 - v1.6+)
- added: USB Support for XICS
- added: FAT 32, FAT 16 (for USB Pendrives)
- added: ISO9660 support for XICS
- added: ZIP support
- added: Micro HTTP Client (Download / Execute Files From Internet)
- added: Video Region Quick Swap (LEFT+X NTSC, LEFT+Y PAL - hold on bootup)
- added: X3 EEprom Emergency Format (A+B+X+Y - hold on bootup)
- added: Pop Up warning if text input becomes truncated
- added: Option to enable / disable boot to DVD Rom (D:default.xbe)
- added: Multi-Layer logo.x support (Currently a bug so disabled)
- added: Multi-Layer flubber.x support (Currently a bug so disabled)
- added: Successful FTP of filenames over 42 characters now possible with auto rename (e.g this.stupid.ass.long.filename.is.way.way.way.too.long.for.this.filesystem.mpg renamed to this.stupid.ass.long.filename.is.way.way.w.mpg (if renamed filename is the same as a one currently
on the hdd it will not overwrite it - but will add a recursive number on the end)
- added: Multiple HTTP download locations now possible
- added: Support for recursive skinserver entries
- added: Scrollbar added to default skin
- added: Clear Cache Dirs/Drives (In Disk Tools / Current Hard Drive Setup Menu)
- added: new script commands for XICS (since 2666) preparedrive, mbr, format, reboot & echo
:thumbup:
