Den store UI tråden. Lurer du på noe? Spør her!
Har ikke spillt wow på 2 dager nå jeg :S jeg er avhengig av masse mods, og jeg gidder ikke laste ned en og en selv. venter på noen bra collections/packs. hater dagene etter patch :S ikke bare at ingen mods (eller UI's da) fungerer, men det er masse andre bugs og servershotdowns :,(
EDIT: Det er bra at det ikke går ann å slite ut Interface mappa :p
Endret av Morgh
5840754[/snapback]
Discord Action Bars, fungerer som normalt, men det er en fil i DAB som ikke virker, som heter DAB_AutoCastHooks, om man sletter den, fungerer DAB som normalt.
Fra WowWiki om DaB:
# To address the keybinding problem until the mod is updated:
1. Delete, or rename, the 'Interface\AddOns\DiscordActionBars\DAB_AutoCastHooks.lua' file.
2. Edit the file 'Interface\AddOns\DiscordActionBars\DAB_Initialization.lua'.
1. Find this line: "DAB_Set_Keybindings();"
2. Change it to: "--DAB_Set_Keybindings();".
3. Update your keybindings then type '/script SaveBindings(1)' in-game to save them.
* Note: Removal of DAB_AutoCastHooks.lua will allow the mod to function but there are some (non-blocking) errors that popup related to loading keybindings. Once new keybindings are manually set for the current session, most if not all of the functions work until the next UI reload (you WILL have to rebind your keys if you logout or reload your UI).
# Another fix for the keybindings problem that fixes it so that you do not have to enter in a /command to save your keybindings can be found on the Discord Mod forums, courtesy of Sarris. This fix requires some coding experience, but hopefully a new version of DAB will be released soon or someone can host a fixed version for download. The link to the fix is here, and it has been proven to work for most DAB v3.1 users (make sure you have the latest DAB Library from DiscordMods.com): Discord Forums.
* Patched Files (copy them into the DiscordActionBars folder):
o Mirror 1:
1. DAB_Main.lua
2. DAB_Initialization.lua
o Mirror 2:
1. DAB_Main.lua
# Unaddressed/Unconfirmed Issues:
* Inability to read a button's action by name (only by number) when editing the button's action.
* Conditional statements set to buttons are not working.
* Mousewheel paging not working.
Hva heter den addonen som Eks : Som hviser hvis jeg miner et sted, så på Mapet mitt da vil det være merket hvor jeg minet, sånn at neste gang jeg kommer dit vil alle stedene som jeg har minet i det området, være avbildet på mapet
Endret av andiss
Jeg har brukt et ganske tweaket ui lenge nå. Så etter patchen tenkte jeg å disable nesten alt og bruke standard ui. Men det er en ting jeg bare ikke takler. Og det er den stygge framen (artworken) rundt actionbarene. Finnes det et addon som bare fjerner den og lar alt stå? Jeg snakker da altså om de ørnene og hele framen rundt Bags actionbar mini-menu osv :)
Jeg kan ikke fordra de originale wow fontsa og moden jeg brukte til å forandre disse er out of date og enda ikke opdatert, noen som har et alternativ?
5843583[/snapback]
Ja sliter også der. Installerte det for noen uker siden som du sikkert vet, og jeg ble vant til den og lærte å elske den. Og så plutselig var den vekke.
/mock Blizztard
Endret av Edmund Blackadder
5846210[/snapback]
Discord Action Bars. :)
kvar gong eg bytter kanal kommer det opp 3 ganger etter kvarandre, f.eks:
Joined channel: General
er det noken som har vore borti dette som veit ka som skal til for å fikse det?
