Er det ikke synd denne ikke selges i Norge?
jo den selges over internett
Benefit from increased workspace, brighter colours and sharper contrast on screen thanks to this laptop's widescreen display and Sony X-black technology. An Auto Luminance Sensor monitors ambient lighting conditions and automatically adjusts the brightness of your screen for comfortable viewing and battery saving. Performance is also boosted and battery life extended by the use of the newest Intel® Centrino mobile technology offering you fast wireless networking; Bluetooth technology allows effortless linking with handhelds and mobile phones. This replacement for your desktop comes with a neatly crafted wireless mouse and a dual format double layer DVD writer offering twice the capacity of ordinary DVDs. With plenty of power this laptop is ideal for use at the office, on the move and at home.
Intel® Pentium® M processor 760 2.0 GHz, 533 MHz frontside bus
Supports Enhanced Intel® SpeedStep® technology
Microsoft® Windows® XP Professional with Service Pack 2
80 GB (Serial ATA 5400rpm) hard disk drive
Memory: 1*512 MB DDR SDRAM; maximum 1 GB DDR SDRAM
Widescreen 17" WUXGA (1920 x 1200) X-black LCD screen
Graphics: ATI MOBILITY RADEON X600 with 128 MB VRAM
16-bit CD-quality stereo sound
Double layer DVD±RW drive (up to 24x CD-ROM reading speed / up to 24x CD-R reading speed / up to 24x CD-RW reading speed / up to 8x DVD-ROM reading speed / up to 8x DVD-R reading speed / up to 6x DVD-RW reading speed / up to 8x DVD+R reading speed/ up to 4x DVD+R DL (DL) reading speed / up to 6x DVD+RW reading speed / up to 24x CD-R writing speed / up to 24x CD-RW writing speed / up to 8x DVD-R writing speed / up to 4x DVD-RW writing speed / up to 8x DVD+R writing speed / up to 2.4x DVD+R DL (DL) writing speed/ up to 4x DVD+RW writing speed)
Ethernet network; built-in 56 kbps data / fax modem; Wireless LAN 802.11b/g; Bluetooth® technology
Built-in stereo speakers, touchpad, auto luminance sensor, plug & display
Connections: docking station, i.LINK (IEEE1394) S400, 3 USB 2.0 ports, Memory Stick PRO slot (Standard or Duo), PC Card slot
Wireless switch, volume buttons, magnify button, brightness button, S1 button, mute button
Dimensions (W x H x D): 405.5 x 42.2 - 45.2 x 280.1 mm
Weight with battery: 3.9 kg
sånn rundt 25000kr...
Endret av Vaio
Problemet er vel at det ikke er norsk tastatur når man kjøper denne. Jeg regner med at det følger med engelsk/US tastatur på de som selges på Gardermoen. Man kan jo alltids ta turen til Sverige...da er det kun mindre forskjeller på tastaturet.
Er det noen som vet hva et Nordic Keyboard er?
Problemet er vel at det ikke er norsk tastatur når man kjøper denne. ...
Det er jo ikke noe stort problem. Du lærer jo raskt hvor tastene er. Selv bruker jeg PCer med amerikansk og norsk tastatur om hverandre uten å slite med det. I windows kan du jo uansett skifte mellom tastauroppsett slik at du kan skrive med norske bokstaver. ;)
Sjekk skjerm og oppløsning! Med PCI Express og Sonoma vil Sony Vaio være min drømmemaskin.....men litt dyr da :cry:
http://vaio.sony-europe.com/ShowProduct.do...duct=VGN-A297XP
Har Sony Vaio picturebook. Veier under 1 kilo.
http://www.vaio-link.com/specifications/sp....asp?l=en&m=287
Enig at Sony er bra PC`er men ganske dyre.
Er i Japan na, skal kjope ny "brukt".
Utvalget i Japan er stort, mange PC`er blir bare solgt her og ikke i Europa.
Leste jeg feil eller:
3,9 kg
4,5cm høy
40cm bred
28cm dyp
Vel, den er som en middels dokumentkoffert. Hadde det vært plass til 4 stk. IBM X40 eller Asus S5200 inne i dokumentkofferten med de målene mon tro? Og litt plass til overs ? Ja, det skulle man tro ... (egentlig nesten) Men vekten av kofferter med 4 PC'er inne ville vært nesten en kilo høyere da ... :p
Apple ???? Trodde vi snakket om PC'er her og ikke epler.
Fra spøk til alvor
Det er da enorm forskjell på en MAC og PC. Det blir som å si at man skal kjøpe Playstation i steden for stasjonær pc!
1Samtlige bærbare PC'er fungerer bare ikke med Maya. 256 mb skjerm-minne er et minimum når man jobber med store animasjoner. På en PowerBook går det som en lek, selv om den bare har 128 mb skjerm-minne.
Du kan ikke kjøre FinalCut på noen PC, samme om dem er bærbare eller ikke. Dette er de to hovedargumentene som skulle til for å kaste ut den bærbare PCen og få inn en Mac.
Forøvrig er jo Mac en PC da.. ;)
