"c:\windows\system32\dllcache\" trenger jeg den?
Gjest Slettet-nQdjz0
denne siden står dette:
1. c:\windows\system32\dllcache\
NOTE: DON’T DELETE THIS FOLDER, JUST ALL THE FILES INSIDE! This folder uses a LOT of hard drive space, it holds a backup of every system file that windows uses. Deleting this will cause a SFC error when you replace a system file instead of windows putting back the original file. For people who want to mod there system, this is a good thing.
2. c:\windows\servicepackfiles\i386\
NOTE: DON’T DELETE THIS FOLDER, JUST ALL THE FILES INSIDE! This folder only exists if you installed a service pack on XP, if you did a slipstream it won’t be here either. This folder is the same as the dllcache, but has the new files that were updated by a service pack. If you delete the dllcache, deleting this is just like finishing the job.
5. c:\windows\driver cache\i386\
NOTE: DON’T DELETE THIS FOLDER, JUST ALL THE FILES INSIDE! This is one you may not want to delete, this takes up a bit of space (about 80mb) but windows uses if you ever add or remove windows components and things like printer drivers. If you’re your hardware is already working fine, you don’t need this folder on your hard drive. For example, if you delete this folder, and try to install IIS, windows will ask for the CD or Network share with the files on it, if you don’t need to add or remove windows components often, deleting this will free up some space for you.
Blir det umulig å bytte 3D kort, nettverkskort, lydkort o.l?
Eller står det bare noe som dette:
'Finner ingen drivere, last ned manuellt' eller noe i den duren?
Ingen med erfaringer? :hmm:
Tror den i386-mappen inneholder innebygde drivere, så det går helt greit å laste ned drivere manuelt. Merk at det ikke finnes drivere på nettet for mye maskinvare, av den grunn at driverne er inkludert i Windows/bruker standarddriverne.
Kanskje ikke så lurt å slette med tanke på DVD-ROM da?
Bruker disketten noen drivere?
Endret av Slettet-nQdjz0
I en forstand, ja - men nå har det seg også slik at det i dag er SVÆRT få produsenter av diskettstasjoner, og det eksisterer således omtrent ingen differanse i protokollen disse enhetene kommuniserer med.
Windows bruker med andre ord en enkel driver-fil - "flpydisc.sys" - for å motta og sende kommandoer til den interne disketstasjonen. Når det gjelder eksterne stasjoner, kan det godt forholde seg annerledes. Da må man muligens installere egne drivere.
Endret av aadnk
