Lampeskjermen Skrevet 21. februar 2007 Del Skrevet 21. februar 2007 Hva med trinkets i feral forms?som feks den bladefist trinketen?fungerer det? 7995119[/snapback] Ja, kan bruke som use hvis det er det du mener, og du får også 26crit rating selvsagt. Lenke til kommentar
Superslask Skrevet 21. februar 2007 Del Skrevet 21. februar 2007 Bladefist's Breadth og Ancient Draenei War Talisman er jo et must, da de gir deilig crit og de stacker. 400 AP ekstra er nice på en finishing move eller to. Lenke til kommentar
Bredoc Skrevet 22. februar 2007 Del Skrevet 22. februar 2007 Idee for nye Druid form. :!: Klippet fra US forum. Copied from the American forums. Full Credit goes to Cyraga "As you Druids would know, if you follow the Restoration or Balance trees, at level 40 you have the option of having a whole new shapeshift to play around with. But looking more carefully at this I realized something, the Feral tree does not have its own shapeshift. Why would Blizzard leave Feral out in the dark? Well I'm not sure personally but here's what I think should happen. Now now, hear me out before you start clicking that Post Message button. At first I thought that since Bear form is upgraded at level 40, why not Cat form if you spec Feral? But then I thought that would be a tad predictable, so then I though of a new animal. Something swift and cunning, yet graceful and can hold something in its hands. And then it came to me. Octopus. Druids at level 40 if they spec Feral should get Octopus form, how cool would that be? But the problem with that is that Octopodes (proper noun) aren't very agile on land. So I thought, What is agile on land? Motorbikes. If you put an Octopus on a motorbike you have everything covered. So I quickly opened up Photoshop and made what I think Octopus On A Motorbike Form (Shapeshift) would look like. New druid form As you can see from this artistic rendition on the Druid's enhanced DPS form, he sits nice and snug on top of his motorbike (which is part of the form and not bought separately). The idea works. You will also notice that since Octopus On A Motorbike Form has as you would expect, 8 tentacles. It is able to hold up to 8 Main hand weapons. Since an octopus has no "main tentacle" there's no need for 1 main and 7 plain swords. Also in this picture you will notice that Octopus On A Motorbike has 8 different enchants on each of his sword so he is ready for any type of fight. The radius of attack, or as I like to call it, the Octopain Radius, is about 10 yards around Octopus On A Motorbike, since his tentacles are as you can see quite long and stretchy. Now I all know how awesome you think my shapeshift idea is but for the sake of it, lets have an example of what Octopus On A Motorbike could do. You're grinding away in contested territory, you're tired, you're not paying much attention to what's going on, you're just grinding away. You hear a strange noise, one that is foreign to WoW. You shake it off as nothing and continue to kill mobs. You hear something again and turn your camera around to see if you can locate the source of the noise. There seems to be nothing there. You turn the camera back around to see a mix of coloured enchants, sea-creature and machinery and you're dead before you could even comprehend what just happened. That is how I envision Octopus On A Motorbike. That is what the Druid needs." Kilde Lenke til kommentar
Gjest Slettet-p4PIYwb6 Skrevet 22. februar 2007 Del Skrevet 22. februar 2007 :!: Det var en god ide ja. Lenke til kommentar
StarGazer Skrevet 22. februar 2007 Del Skrevet 22. februar 2007 Tidig. De fanget nettop en 450kgs blekksprut også! Men, noen som vet om noen linker til noen ok TBC druid pvp videoer=? Lenke til kommentar
Datasmurf Skrevet 22. februar 2007 Del Skrevet 22. februar 2007 Jeg hadde elska en blekksprut på motorsykkelform <3 Lenke til kommentar
Lycantrophe Skrevet 22. februar 2007 Del Skrevet 22. februar 2007 Når sånn +/- er det Bear druids ikke blir tatt ned av en Rogue stunlock uten problemer/cooldowns/tea, da armour og hp blir så høyt at i en stunlock har du ikke nok stuns til å drepe? Rotete spurt, men det får duge. Skylder på klokka. Lenke til kommentar
tmg Skrevet 23. februar 2007 Del Skrevet 23. februar 2007 Du spør når er det rogues stunlock ikke varer lenge nok til å drepe druid i bear? Rogues funker vel dårlig til å stunlocke noe som helst fra 100% til 0% uten PvP spec som gir combo points fort (hemo e.l), jeg har som oftest hvert speccet mer grinding med rogue i low / mid lvls. Men om det funker i low lvls med pvp spec, så blir det vel en stopper i 40, da druids får dire bear form med 450% mer armor eller hva det er. Lenke til kommentar
Lycantrophe Skrevet 23. februar 2007 Del Skrevet 23. februar 2007 Jeg har Backstab/Sealfate akkurat nå, og med litt hell + mye gouge klarte jeg en 41 druid (er 42). Selvsagt mener jeg med stunlock specc, aka hemorrhage eller med litt fantasi, sealfate. Lenke til kommentar
StarGazer Skrevet 23. februar 2007 Del Skrevet 23. februar 2007 Er lvl 53 rogue nå og er hemo speccet. Har tatt noen bear form druids med stunlock, men da brenner jeg av mye cooldowns. Er helst når de kommer ned på en 20% liv at de begynner og tenke på healing, og skifter da til caster form. Da dør de ganske fort igjen. Men som sagt, vanskelig mot druids, siden du trenger stunlock points til expose armor og rupture, samtidig som du trenger de til kidney shot. Vil tro at premed hjelper stort mot druids, men så dypt har jeg ikke speccet ennå! Nref faerie fire btw Lenke til kommentar
Lednar Skrevet 24. februar 2007 Del Skrevet 24. februar 2007 Faerie Fire er fin som den er vil jeg si. Blir den nerfet noe mer nå er den ikke verd 1 point engang. Lenke til kommentar
PSV Skrevet 24. februar 2007 Del Skrevet 24. februar 2007 Nerf, nerf og atter nerf.. faen meg på tide.. Patch notes - 1.10 * When the duration of "Cyclone" ends, area buffs such as "Leader of the Pack", "Tree of Life", and "Moonkin" will now be correctly resumed. * "Bear Form" now grants 25% increased stamina instead of 25% increased health. * "Dire Bear Form" now grants 25% increased stamina instead of 25% increased health. In addition, the armor bonus has been reduced from 450% to 400%. * The multiplier on base weapon damage for "Mangle (Bear)" ability has been changed from 130% to 100%. In addition, the bonus damage has been reduced by the same ratio. * "Savage Fury" no longer affects "Mangle (Bear)". * "Savage Fury" no longer applies to "Maul" or "Swipe". * The critical damage bonus on "Predatory Instincts" reduced from 3/6/9/12/15% to 2/4/6/8/10%. * "Improved Leader of the Pack" can no longer get critical heals. * The armor bonus from "Moonkin Form" has been increased from 360% to 400% (to match Dire Bear Form). * The rage normalization equation has been adjusted to grant more rage. Lenke til kommentar
Superslask Skrevet 24. februar 2007 Del Skrevet 24. februar 2007 Faeri fire er jo ikke så syk mot rogues lenger da de har cloak of shadows. Lenke til kommentar
Stoop kid Skrevet 24. februar 2007 Del Skrevet 24. februar 2007 Bladefist's Breadth og Ancient Draenei War Talisman er jo et must, da de gir deilig crit og de stacker. 400 AP ekstra er nice på en finishing move eller to. 7995307[/snapback] Riktig (for øyeblikket), men dette blir nå forandret i neste patch. Lenke til kommentar
Theoneask Skrevet 24. februar 2007 Del Skrevet 24. februar 2007 (endret) Alle delane av den nerfen er Ikkje rettferdig. * The multiplier on base weapon damage for "Mangle (Bear)" ability has been changed from 130% to 100%. In addition, the bonus damage has been reduced by the same ratio.* "Savage Fury" no longer affects "Mangle (Bear)". * "Savage Fury" no longer applies to "Maul" or "Swipe". * The critical damage bonus on "Predatory Instincts" reduced from 3/6/9/12/15% to 2/4/6/8/10%. * "Improved Leader of the Pack" can no longer get critical heals. Mangle er eit 41 points talent. Skal dei nerfe det sopass masse, kan dei iallefall gjer noken endringar og. Gratulere blizzard, dåke har gjort Savage Fury kun nyttig i cat form. Nok ein nerf til imp lotp, ikkje nødvendig. Mindre crit sjanse, jaja, måtte vel skje det og. Eg berre lurer litt. Kvifor er det kun feral som blir nerfa? Dåke syter jo like masse på alle delane av druids, men det går alltid ut over oss feral! Endret 24. februar 2007 av TheOneAsk Lenke til kommentar
Superslask Skrevet 24. februar 2007 Del Skrevet 24. februar 2007 (endret) Ganske liten nerf om du leser ordentlig etter min mening. Mangle er bare gjort svakere i bearform, der den uten tvil var alt for kraftig. Mangle, maul og swipe spam gjorde at du kunne gjøre mer dps enn i catform. En nerf som hører hjemme. Har ikke mistet critchance, men 5% ekstra critdamage. Ikkenoe å grine over. Nerfen til imp lotp er da absolutt ingenting å grine over. Jeg ville ikke engang kalt det en nerf. Prester har også fått denne på VE'n sin, det derimot, er en nerf. Ser ikke helt grunnen til armor nerf, men om de mener det bringer mer balanse, så tar jeg det da gjerne imot. Ganske lite forandring. Er usikker på om health blir forandret i det hele tatt i bearform. Noen som har regnet på det? 25% stamina er vel 25% health sier min kjappe logikk meg. Endret 24. februar 2007 av Superslask Lenke til kommentar
Lednar Skrevet 24. februar 2007 Del Skrevet 24. februar 2007 (endret) Gief Sunders. Druider skal kunne være Warrior i bear, Rogue i Cat Form. Ikke 100% men vi må da kunne gjøre damage i Bear Form til å holde aggro siden vi ikke har Sunder. Og hvilket rett gir det dem og nerfe oss såpass? Ja, skal ikke nekte for at Mangle i Bear Form skulle bli nerfet. Men da må de da kunne finne på noe som gjør at vi kan holde aggro! Endret 24. februar 2007 av Lednar Lenke til kommentar
ka1ser Skrevet 24. februar 2007 Del Skrevet 24. februar 2007 Vi har Lacerate, nå er jeg ikke helt sikker på om gir like mye aggro som sunder, men den funker fint i alle fall i 5-manns. Lenke til kommentar
Stoop kid Skrevet 24. februar 2007 Del Skrevet 24. februar 2007 (endret) Sunder= Lacerate. Dæven, litt sein. Utfra wowwiki så er lacerate litt mindre effektiv enn sunder. Når DoTen er ferdig ville lacerate ha gjort samme threat som sunder. kilde: http://www.wowwiki.com/Formulas:Aggro Endret 24. februar 2007 av Quicko Lenke til kommentar
Superslask Skrevet 24. februar 2007 Del Skrevet 24. februar 2007 Pluss at elementals (o.l.) er immune mot lacerate. Men at den skal være bedre syns jeg ikke. Lenke til kommentar
