Den lille druid tråden
Questa, grinda og gjorde eit par instancer frå 53-60 som resto druid. Questing går som regel fint, tar litt tid. Skaff deg ein parter å grinde med, aoe ftw, går ganske bra.
Tok 50% av lvl 59 på eit strat ud run so det er egentlig ikkje noke stort problem. Silithus har mange bra quester frå 57 og oppover.
<3 min druid...
btw lit TBC info fra druid forums.
Noen steg i riktig rettning :)
These are the latest changes in the druid talent tree. They are stickied on the US forum, so i decided to post them here since they apparently haven't been posted in a sticky unless im mistaken.
Balance
  • Moonfury scales with gear (!!), confirmed by Lissanna (US).
  • Meleeing in Moonkin form now gives the druid a chance to regen mana equal to a percentage of his AP. Spell crit aura raised to 5% and AP in this form is increased by 150%. In addition for Feral/Balance builds, Predatory Strikes now increase AP of Moonkin Form as well.
  • Insect Swarm - Now in the balance tree, Switches the place of Omen of Clarity which is now in the restoration tree. Still a talent.
  • Improved Wrath and Improved Starfire - The casttime component of these two spells have been merged to Starlight Wrath and takes the place of the old talent "Improved Wrath", 5 ranks total. The starfire stun is now a seperate talent.
  • Improved Starfire - Gives a 5%/10%/15% chance to stun the target with Starfire, 3 ranks. Same location as the old "Improved Starfire"
  • Improved Moonfire - Moved to the old Natural Weapons location (NOTE: Improved Moonfire is NOT a prereq for Insect Swarm). Talent unchanged. Its still unconfirmed if the damage icnreasing part will scale like Moonfury.
  • Focused Starlight - 2 ranks. Takes the place of the old Improved Moonfire talent and will be pre-req for Vengeance. Increases the crit chance of your Wrath and Starfire spells by 2%/4%.
  • Natural Shapeshifter - Moved to Restoration
Feral:
  • Feral Instinct and Thick Hide - Both talents reduced to 3 ranks granting 5%/10%/15% increased Threat while in Bear Form (Stealth improvements assumed to scale as well) and 4%/7%/10% increased armor.
  • Nurturing Instinct - Reduced from 3 to 2 ranks. Effect unchanged at maximum talent rank.
  • Survival of the Fittest - Reduced to 3 ranks but the effect won't scale, so 3% melee crit reduction and 3% increased stat bonuses are now the max for this talent.
  • *** NEW *** Shredding Attacks now reduce the Energy cost of Shred to 9 (!!) energy per rank, aka. fully talented Shred only costs 42 energy now!
Restoration:
  • All +healing talents (Imp. Rejuvenation, Gift of Nature) are SUPPOSED to scale with +healing gear, but they apparently don't at the moment. Ill report back later with an update on this issue.
  • New talent, Naturalist, replaces Improved Healing Touch, 5 ranks. Decreases the casttime of Healing Touch by 0.1 second per rank, and increases all melee damage done by 2% per rank. So basically its Improved Healing Touch and Natural Weapons merged. Location is unchanged.
  • Natural Shapeshifter - Moved from Balance, talent unchanged. Takes the place of Improved Enrage.
  • New talent, Intensity, replaces Reflection, 3 ranks. Allows 5%/10%/15% of your mana regeneration to continue while casting, and causes your Enrage ability to instantly generate 4/7/10 rage. Basically Imp. Enrage and Reflection merged.
  • Omen of Clarity - Takes the place of Insect Swarm. Talent unchanged.
  • Natural Perfection - Changed to "Your critical strike chance with all spells is increased by 1/2/3% and melee and ranged critical strikes against you cause 4/7/10% less damage."
  • Tree of Life movement speed reduction changed from 50% to 20%, so you know move at 80% speed.
Ability Changes:
  • Pounce now stuns for 3 seconds base ( http://www.thottbot.com/beta?sp=27006 ), 4 seconds with talents. Damage has been upped significantly and scales with AP. In addition it appears its currently possible to use Pounce from ALL directions and not just behind the enemy, and has a 10 (!!) yard range. Huge buffs overall if they make it live.
  • Swipe and Rake now scales with AP. Ill get more info on the formulaes as soon as i can.
Other changes:
  • Armor Formula is changed. New formula looks like this:
    armor / ( armor + Opponent level * 100 + 2450 ). Thanks to Coedan (Imbalanced) for providing the numbers to let me figure this out. New armor cap are 28350 for level 70 mobs/players and 29250 for level 73 mobs, assuming the cap still exist in TBC.
  • Windfury and other weaponprocs working in forms ( http://i73.photobucket.com/albums/i236/xAr...06194100ut4.jpg )
  • Ability to drink potions while shapeshifted
  • Shapeshifting mana cost reduced for higher levels to more easily accomodate more shifting, currently 894 mana untalented at level 67.
  • Mangle now also increases the damage done by Shred by 30% (PvE and PvP buff!!).
Downranking:
Gear:
  • Most weapons now have Feral AP
  • Tier 4 will be a token/exchange system where it is possible to get Resto, Balance or Feral gear depending on liking. There is no word on wether or not Feral gear will be divided into Cat/Bear gear, but the general assumption is that we won't be so fortunate.
  • Tier 4 melee set have very poor armor rating (aka. not a good tanking set)
  • Your new Warden eh... Mace? http://i73.photobucket.com/albums/i236/xAr...06184643kx5.jpg
Check out the talents yourself on:
http://www.wowhead.com/?talent-bc=0 (fast, good for slow connections or people who just can't wait. Recommended unless recent changes has been introduced)
http://www.worldofwarcraft.com/info/classe...id/talents.html (use if some changes don't show up on the wowhead talent calculator)
Endret av AssKicR
Er classofficer i guildet mitt, og har begynt å se på muligheten for å ha en moonkin eller feral i raids. Tenker da mest på buffen fra de to. Hva er best?
Og har en godt gearet moonkin noen god dps?
Sitter å leser litt her, men hadde vært interresant om noen har erfaringer om dette.
En annen ting jeg lurer litt på er om insect swarm er litt imba? Da tenker jeg 5 druids i raidet, alle holder oppe insect swarm hele tiden. Dette gjør at bossen har 10% mindre sjangse for å hitte. Imba?
Vi har moonkin og feral druid i raida våre. Synts dette funker bra. Plasser moonkin med mages og warlock, feral med fury warrior og rogue. Som oftast 1 feral og 1 moonkin, resten er i hovudsak resto.
Ein godt geara moonkin kan gjer bra dps ja, berre søk på google video etter moonkin so finner du nok bevis på det. Klart ikkje betre ein mage og warlock, men skal vel ikkje tvinge alle til å heale heller;)
Hmm, har ikkje tenkt på det på den måten, men skal vere einig i at det kan bli litt imba ja.. Er ikkje den spellen som varer lengst so måtte jo passe på å ta på ny.
står sikkert et eller annet sted i den tråden her men.
Lurer egentlig hvordan det er og queste som resto druid fra 55 til 60, om dette kommer til og bli vanskelig eller om det går greit?
7215498[/snapback]
Og mulig det står, men kan gjerne dele min erfaring med druid.
Jeg og en kamerat bestemte oss for å ta en hardcore sesjon med horde. Han valgte warrior og jeg druid. Vi levlet oss til 60 på tre uker og jeg valgte restoration på lvl55-ish.
Solo med restoration tar lang tid, men fordelen er at du har 0 downtime. Nå som Innervate er core ability så dør du rett og slett aldri :D
så om du ikke er prippen på tid og dps, så går det glatt med restoration.
Og forresten, vetke om det har blitt nevnt eller diskutert, men jeg har mainhealet alt fra SFK til UBRS som druid. Går så fint atte :love:
7215498[/snapback]
7228226[/snapback]
Er vel kjekt å ha med en resurrecter ettersom din har lang cooldown da?
7215498[/snapback]
7228226[/snapback]
7228810[/snapback]
Såklart er det kjekt, men på det tidspunktet var det brutalt lite healers på servern. Og druid-ressen er best midt i combat, imo :)
Og de første ubrs-kjørene hadde nok en shaman eller to. De var bare langt fra heal-specced. :hrm:
  • 2 uker senere...
tree of utter shite
7303724[/snapback]
Fjerner man speed penalty blir dette den beste versjonen av druid healing man får. Idag er man bare en prest med treigere spells, med de nye talentsa kan man bli en ny form for healing class.
Tree of life FTW. Fjern speed penalty og den blir brukandes overalt, ikke bare på stasjonære bosser.
