Den store priest tråden
Hvis du bare skal gå i groups til 60 foreslår jeg at du begynner med Disciplin.
Unbreakable Will 5/5
Improved Shield 3/3
Improved Power Word: Fortitude 2/2
Deretter kan du bygge opp i holy
Improved Renew 5/5
Spiritual Healing 5/5
Subtlety 5/5
Inspiration 5/5
Improved Flash Heal 5/5
Improved Prayer of Healing 2/2
Så kan du sette resten av poengene i Disciplin treet
Mental Agility 5/5
Mental Strength 5/5
Meditation 5/5
Inner Focus 1/1
Discipline Talents (26 points)
# Unbreakable Will - 5/5 points
Increases your chance to resist Stun, Fear, and Silence effects by 15%.
# Improved Power Word: Shield - 3/3 points
Reduces the duration of your Power Word: Shield's Weakened Soul effect by 15 seconds.
# Improved Power Word: Fortitude - 2/2 points
Increases the effect of your Power Word: Fortitude and Prayer of Fortitude spells by 30%.
# Mental Agility - 5/5 points
Reduces the mana cost of your instant cast spells by 10%.
# Mental Strength - 5/5 points
Increases your maximum Mana by 10%.
# Inner Focus - 1/1 point
When activated, reduces the Mana cost of your next spell by 100% and increases its critical effect chance by 25% if it is capable of a critical effect.
# Meditation - 5/5 points
Allows 15% of your Mana regeneration to continue while casting.
Holy Talents (25 points)
# Improved Renew - 5/5 points
Increases the amount healed by your Renew spell by 15%.
# Holy Specialization - 5/5 points
Increases the critical effect chance of your Holy spells by 5%.
# Spiritual Healing - 5/5 points
Increases the amount healed by your healing spells by 10%.
# Subtlety - 5/5 points
Reduces the threat generated by your healing spells by 20%.
# Inspiration - 5/5 points
Increases your target's armor value from items by 25% for 15 seconds after getting a critical effect from your Flash Heal, Heal, Greater Heal, or Prayer of Healing spell.
Discipline Talents (31 points)
# Martyrdom - 2/2 points
Gives you a 100% chance to gain the Focused Casting effect that lasts for 6 seconds after being the victim of a critical strike. The Focused Casting effect prevents you from losing casting time when taking damage.
# Improved Mana Burn - 2/2 points
Reduces the casting time of your Mana Burn spell by 0.5 seconds.
# Divine Spirit - 1/1 point
Holy power infuses the target, increasing their Spirit by 23 for 30 minutes.
Level 42: 29 Spirit
Level 54: 35 Spirit
Holy Talents (20 points)
Øverste er med Divine Spirit og nederste er uten.
Endret av ahpadt
Ville satt poenga i noe anna enn inspiration, +5% crit chance for holy spells er feks mye bedre.
5408543[/snapback]
Om du er main tank healer, så vil jeg absolutt tro at Inspiration er god, spesielt i kombinasjon med +5% crit.
Jeg for min del har gått for Holy Specialization (+5% crit) og inspiration.
Subtlety er noe piss imo. Hvor ofte har fått aggro i en bossfight før, ahpadt? Aldri skjedd meg i hvert fall, og det er ingen som ligger over meg på healing-listene.
5408655[/snapback]
Subtlety er absolutt ikke piss, jeg føler det er utrolig viktig for meg, vet ikke hvor du er vant til å heale, men i BWL når det myldrer av stygge goblins etc. som kaster granater etter deg er det ganske greit å ha mest mulig reduced threath.
Boss fights er det kanskje ikke like viktig når warrior har såppas god aggro, men veldig viktig når det er mye mobs som springer rundt, priest skal jo kunne heale uten å få aggro med en gang, fade har jo en 30 sec cooldown...
Dette er mine erfaringer, men andre folk har vell andre erfaringer.
Endret av kjexter
5408655[/snapback]
Jeg har fått aggro 1 gang, p åNefarian.. grilla et par da. :blush:
Det er jævlig kjekt om du er horde, men om du er alliance så kan du sikkert putte de poengene i litt snacks i Discipline.
5408655[/snapback]
5408756[/snapback]
Jeg prøvde å respecce til mindre poeng i subtlety, men når alle andre priestene i guilden har 5/5 i Subtlety følte jeg det var bestandig jeg som ble grillet :p mens de sprang rundt å ikke fikk aggro, men, har 5/5 igjen nå, kansje prøve en gang senere igjen...
Endret av kjexter
  • 2 uker senere...
Kommer litt ant hvordan du spiller. Spiller du mye alene, eller i grupper som lar deg få finishing blow, er Spirit Tap genialt. Selv har jeg Blackout, men synes ikke den proccer så ofte. Mind Flay og MB og Pain er er must.
For å si det sånn, skaff imp Shield og Fortune, resten hiver du i shadow :thumbup:
Noen her som har prøvd en Smite build? Har tenkt på dette litt, og det er faktisk utrolig mye kraft en kan få i Smite (tror jeg). Tenker da på en build som denne.
Jeg vil da kunne få denne crit sjangsen:
Gear
+ 2% crit - Eyes of the Beast
+ 2% crit - 5/8 Prophecy
+ 2% crit - Benediction
+ 1% crit - Dragonslayer's Signet
Talent
+ 5% crit - Force of Will - rank 5/5
+ 5% crit - Holy Specialization - rank 5/5
+ 5% crit - Base crit chance (?)
+ 3% crit - 300 Intellect
= 25% crit
I tillegg til dette vil jeg også kunne få en damage boost.
Talent
+ 5% dmg - Force of Will - rank 5/5
+10% dmg - Improved Smite - rank 5/5
= 15% dmg
Så da blir damagen (+ gear)
Normal: 438-489
Crit: 657-733 (26% sjangse ca)
Ville ikke dette være nok til å kunne soloe greit, men med også å kunne ha en stabil bwl healing build?
Endret av Zevz0r
Gear
Talent
= 17% crit
I tillegg til dette vil jeg også kunne få en damage boost. (Gearet mitt gir lite så det bryr jeg meg ikke om)
Talent
= 15% dmg
5491944[/snapback]
For min del brukte jeg mye smite på starten, men ettersom jeg gikk opp i lvls gikk jeg mer og mer fra det. Liker ikke det skillet så mye, men når du er Holy så funker det nok ja.
Som Holy lvl 60:::
Disc:
Improved PWS - 3
Improved PWF - 2
Mental Agility - 5
Improved Inner Fire - 1
Mental Strenght - 5
Meditation - 5
Holy:
Improwed Renew - 5
Inspiration - 5
Improwed Flash Heal - 2
Improwed Prayer Of Healing - 2
Spirit Of Redemption - 1
Som Shadow lvl 60:::
Disc:
Improwed PWS - 3
Improwed PWF - 2
Mental Agility - 5
Improwed Inner Fire - 3
Shadow:
Blackout - 5
Shadow Focus - 3/5 (Se Improved Fade)
Improved Shadow Word Pain - 2
Improved Mind Blast - 5
Mind Flay - 1
Improved Pshycic Scream - 2
Improved Fade - 2/0 (Se Shadow Focus)
Silence - 1
Shadow Weaving - 5
Vampiric Embrace - 1
Darkness - 5
Shadow Form - 1
Prøvd en god del forskjellig builds... Syns disse er de som gjør best nytte for seg, stor trives! :thumbup::thumbup::thumbup:
Aerie - Night Elf, Priest, 60 - Balnazzar
Discipline: 26 points
Improved PW:Shield 3/3
Improved PW:Fortitude 2/2
Mental Agility 5/5
Mental Strengt 5/5
Meditation 5/5
Inner Focus 1/1
Holy: 14 points
Improved renew 5/5
Subtlety 4/5
Shadow: 11 points
Spirit Tap 5/5
Blackout 3/5
Improved SW:Pain 2/2
Mind Flay 1/1
Kjører denne builden nå, men snuser litt på å bytte. Holder litt øye med priest-build tråden i klasseforumet til guildet mitt for å se hva de andre sysler med. Stiller meg litt avventende og ser hva som skjer i 1.10 også da.
