Trenger hjelp med ndiswrapper
Jeg får ikke koblet til routeren.
-->iwconfig
wlan0 IEEE 802.11g ESSID:"(korrekt essid)"
Mode:Ad-Hoc Frequency:2.462GHz Cell: 02:0E:35:00:41:87
Bit Rate:54Mb/s
RTS thr:1600 B Fragment thr:2304 B
Encryption key:xxxxxxxxxx (riktig kode)
Security mode:restricted
Power Management:off
Link Quality:15/100 Signal level:24/154 Noise level:0/154
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
-->ifconfig wlan0
wlan0 Link encap:Ethernet HWaddr 00:0E:35:60:57:D3
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Memory:faffc000-faffcfff
-->ifconfig wlan0 up
-->ifconfig wlan0
inet6 addr: fe80::20e:35ff:fe60:57d3/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
-->dhclient wlan0
Internet Systems Consortium DHCP Client V3.0.1
Copyright 2004 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/products/DHCP
eth1: unknown hardware address type 776
eth2: unknown hardware address type 24
/sbin/dhclient-script: configuration for wlan0 not found.
Listening on LPF/wlan0/00:0e:35:60:57:d3
Sending on LPF/wlan0/00:0e:35:60:57:d3
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 15
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 16
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
Hva er galt?
Har en Dell truemobile router som står i gateway-mode. Det funker fint i windows.
Har hatt samme problemet selv.. Måtte definere ip-adresse etc selv og da fungerte det.
Har lest noe om at det er no med ndiswrapper og dhcp.
Til opplysning til andre som søker på tråden med samme problem:
Byttet ndiswrapper 1.0 med 0.8, og da virket det.
