PIII v.s P4
Zink
Siden temaet PIII har vært oppe i det siste, så fant jeg fram en gammel test fra tomshardware som viser hvorfor PIII duger ennå for svært mange:
med en kommentar:
> Ouch! Clock for clock Pentium 4 gets beaten by Pentium III in all but the Quake 3 and the MPEG4 benchmarks! If the Pentium III at 1.13 GHz were available and Intel would have launched Pentium 4 at 1.3 GHz, the difference between the two would have been hardly noticeable. <
For å fyre opp litt:
If you’re building a new computer and the decision comes down to Athlon or Pentium III E, the choice is as close to 50/50 as possible thus leaving it up to you. On the one hand, the Athlon is the faster (clock for clock) and based on much more sophisticated architecture. And on the other hand the Pentium III E has much better motherboard support (even with the BX) and runs considerably cooler.
[ Denne Melding var redigert av: Zink på 2002-06-18 21:29 ]
