Hvorfor får jeg kun lastet inn noen bilder?
Har denne koden i index.php, og skal bruke den til å laste opp bilder, og inn i databasen:
index.php:
<?php
$conn = mysql_connect("localhost", "dufus", "dufus") OR DIE (mysql_error());
@mysql_select_db ("dufusdb", $conn) OR DIE (mysql_error());
// Do this process if user has browse the file and click the submit button
if ($_FILES) {
$image_types = Array ("image/bmp",
"image/jpeg",
"image/pjpeg",
"image/gif",
"image/x-png");
$userfile = addslashes (fread (fopen ($_FILES["userfile"]["tmp_name"], "r"), filesize ($_FILES["userfile"]["tmp_name"])));
$file_name = $_FILES["userfile"]["name"];
$file_size = $_FILES["userfile"]["size"];
$file_type = $_FILES["userfile"]["type"];
if (in_array (strtolower ($file_type), $image_types)) {
$sql = "INSERT INTO image (image_type, image, image_size, image_name, image_date) ";
$sql.= "VALUES (";
$sql.= "'{$file_type}', '{$userfile}', '{$file_size}', '{$file_name}', NOW())";
@mysql_query ($sql, $conn);
Header("Location:".$_SERVER["PHP_SELF"]);
exit();
// Do this process of user has click a file name to view or remove
if ($_GET) {
$iid = $_GET["iid"];
$act = $_GET["act"];
switch ($act) {
case rem:
$sql = "DELETE FROM image WHERE image_id=$iid";
Header("Location:./index.php");
exit();
break;
default:
print "<img src=\"image.php?iid=$iid\">";
break;
<html>
<head>
<title>Storing Images in DB</title>
</head>
<body>
<form method="post" enctype="multipart/form-data">
Select Image File: <input type="file" name="userfile" size="40"><input type="submit" value="submit">
</form>
<?php
$sql = "SELECT * FROM image ORDER BY image_date DESC";
$result = mysql_query ($sql, $conn);
if (mysql_num_rows($result)>0) {
while ($row = mysql_fetch_array($result, MYSQL_ASSOC)) {
$i++;
$str .= $i.". ";
$str .= "<a href=\"index.php?iid=".$row["image_id"]."\">".$row["image_name"]."</a> ";
$str .= "[".$row["image_date"]."] ";
$str .= "[".$row["image_size"]."] ";
$str .= "[<a href=\"index.php?act=rem&iid=.$row["image_id]."\">Remove</a>]<br>";
print $str;
</body>
</html>
I tillegg har jeg en fil som heter image.php som går så her:
<?php
// database connection
$sql = "SELECT * FROM image WHERE image_id=".$_GET["iid"];
if (mysql_num_rows ($result)>0) {
$row = @mysql_fetch_array ($result);
$image_type = $row["image_type"];
$image = $row["image"];
Header ("Content-type: $image_type");
print $image;
Problemet er at jeg ikke får kjørt alle bildene inn i databasen. Hvis jeg tar bilder med liten filstørrelse går det greit. Hvis jeg tar bilder som kanskje er 1700X1200 eller noe, går det ikke greit. Får ingen feilmelding, men det blir ikke lagret i databasen.
Feilmeldingen jeg får fra img.php er følgende:
arning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in P:\webserver\im2db\image.php on line 11
Noen som kan ta et kjapt blikk og fortelle meg noe? For jeg schønner det ikke.
Grunnen til at du ikke får lagret store bilder, kan være at du har feil "column type" på image feltet. I vanlig Blob kan du bare lagre 64Kb. Bruk Mediumblob. Den svelger 16Mb. Hvis ikke det er problemet, så må du sjekke upload limits i konfigurasjon.
Problem 2:
Prøv å sett inn
print mysql_error();
i linja under mysql_query(), og sett // foran header(). Fortell oss så hva som skjer.
Problem 2:
Prøv å sett inn
Meldingen som kommer er: MySQL server has gone away
I SQL filen har jeg følgende kode for image:
CREATE TABLE image (
image_id int(10) unsigned NOT NULL auto_increment,
image_type varchar(50) NOT NULL default '',
image longblob NOT NULL,
image_size bigint(8) NOT NULL default '0',
image_name varchar(255) NOT NULL default '',
image_date datetime NOT NULL default '0000-00-00 00:00:00',
UNIQUE KEY image_id (image_id)
$sql.= "VALUES (";
//Header("Location:".$_SERVER["PHP_SELF"]);
exit();
Sånn ser koden min ut nå etter at jeg kommenterte ut header, og brukte mysql_error();
