Spybot finner sikkerhetshull
Jeg vet at dette sikkerhetshullet er omtalt i Jan Eriks guide mot spyware, men problemet mitt er at det kommer tilbake selv om jeg fjerner det! Det ser sånn ut:
Hvordan fjerner jeg det for godt?
Endret av Joakim83
Dette med DSO Exploit er en kjent bug i Spybot.
Så jeg trenger ikke å slette den?
Se her:
http://www.pchell.com/support/dsoexploit.shtml
If you use Spybot Search and Destroy or another spyware removal tool, it may find an item called DSO Exploit. This exploit is a bug in Internet Explorer that under certain circumstances would allow untrusted software to run on the computer. In other words, its a hole in Internet Explorer that hackers could use to gain access to your system.
However, if you are running the latest version of Internet Explorer and have all your Windows Updates installed, the bug has been patched and is not a threat to your computer system. Even though Spybot may still show it as a threat.
