Feilmelding i Quake3
Får denne feilmeldingen i oppstarten av Quak3:
"GLW_StartOpenGL() - could not load OpenGL subsystem"
Noen som vet hva som er feil??
(Her er hele oppstarten:)
Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
D:SpillQuake3baseq3PAK0.PK3 (3539 files)
D:SpillQuake3/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: seaking
IP: 193.217.132.94
Working directory: D:SpillQuake3
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:WINDOWSSystem32opengl32.dll' ): succeeded
...setting mode 10: 2048 1536 FS
...using colorsbits of 32
...calling CDS: failed, bad mode
...trying next higher resolution: failed, bad mode
...restoring display settings
...registered window class
...created window@3,22 (2054x1561)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...74 PFDs found
...hardware acceleration found
...PIXELFORMAT 6 selected
...creating GL context: succeeded
...making context current: succeeded
...WARNING: fullscreen unavailable in this mode
...using colorsbits of 16
...window already present, CreateWindowEx skipped
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
Håper noen kan hjelpe meg, kjører Win XP, har et Abit Silurro GF4 TI 4400 skjermkort, med NVIDIA DetonatorXP Version 29.42 driverene... DirectX 8.1...
Bare glem det...fant det ut selv=)
Kom på at det var noen som hadde satt spillet i en for høy oppløsning, på den pc'n jeg kopierte spillet fra... Fikk en ny config fil, og da var alt greit!
