Quake3
Hver gang jeg prøver å starte Q3 så får jeg denne meldingen:
Q3 1.31 linux-i386 Dec 17 2001
----- FS_Startup -----
Current search path:
/root/.q3a/baseq3
/usr/local/games/quake3/baseq3/pak7.pk3 (4 files)
/usr/local/games/quake3/baseq3/pak6.pk3 (64 files)
/usr/local/games/quake3/baseq3/pak5.pk3 (7 files)
/usr/local/games/quake3/baseq3/pak4.pk3 (272 files)
/usr/local/games/quake3/baseq3/pak3.pk3 (4 files)
/usr/local/games/quake3/baseq3/pak2.pk3 (148 files)
/usr/local/games/quake3/baseq3/pak1.pk3 (26 files)
/usr/local/games/quake3/baseq3/pak0.pk3 (3539 files)
./quake3.x86/baseq3
4064 files in pk3 files
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
...loading opengl32: QGL_Init: Can't load opengl32 from /etc/ld.so.conf or current dir: /usr/local/games/quake3/opengl32: cannot open shared object file: No such file or directory
failed
...loading libMesaVoodooGL.so: QGL_Init: Can't load libMesaVoodooGL.so from /etc/ld.so.conf or current dir: /usr/local/games/quake3/libMesaVoodooGL.so: cannot open shared object file: No such file or directory
failed
...loading libGL.so: Initializing OpenGL display
...setting mode 3: 640 480
Using XFree86-VidModeExtension Version 2.1
XF86DGA Mouse (Version 2.0) initialized
XFree86-VidModeExtension Activated at 640x480
Xlib: extension "GLX" missing on display ":0.0".
Couldn't get a visual
...WARNING: could not set the given mode (3)
----- CL_Shutdown -----
RE_Shutdown( 1 )
Sys_Error: GLimp_Init() - could not load OpenGL subsystem
Det jeg lurer på er hva jeg skal gjøre, har installert nvidia-driverne (både .rmp'enen og manuelt). Har confa X86Config-4 fila slik at driveren er forandret fra "nv" til "nvidia" og har lagt til modulen Load "glx" ...
Jeg har også installert de nyeste Mesa driverne..
Så jeg sier bare wtf ?
Du kan starte med å prøve å legge inn NVIDIA_GLX driverne på nytt
= pakk ut - make install (el.no) osv....
Hadde lignende problem med en eldre maskin med TnT kort ,... :smile:
- du kan kjøre kommandoen lsmod for å se om nvidia
modulen virkelig er lastet. hvis ikke, så vil ikke
q3 funke. Du trenger også mer enn bare GLX modulen, du
må også ha en modul til kjernen, alt dette står på
nvidia sine sider.
lykke til
For det første, så går det iallefall ikke an å installere GLX rpm'en uten å ha instalert kernel-modulen først.. så det vet jeg at jeg har gjort..
For det andre, så står det i Readme filen at jeg skulle fjerne noen linjer i configfila.. det er greit.. men jeg hadde ikke de linjene fra før så..
Quote:
- men vet du at modulen er loadet?
jeg har spilt q3 på slack/RH/debian uten problemer, så
det er trolig noe som ikke er riktig confa på boksen din.
Det ser ut til at du ikke har spesifisert i XF86Config fila at GLX skal lastes.
Bare legg til lijnja:
Load "glx"
Hos meg ligger file i /etc/X11/XF86Config
Sjekk også at du har installert NVIDIA_GLX og NVIDIA_kernel pakkene fra Nvidia med samme versjonsnummer.
PS: Du skal bytte ut
Driver "nv"
med
Driver "nvidia"
Det er først da den bruker den driveren du har lagt inn, men det vet du sikkert hvis du har lest dokumentasjonen.
