Premiere og sequence error
Slik skal det gjøres:
Make sure that each still-image filename has the correct file extension, and make sure that all filenames in the sequence contain an equal number of digits at the end of the filename (before the filename extension)--for example, file000.bmp, file001.bmp, and so forth.
Choose File > Import.
Locate and select the first numbered file in the sequence, select Numbered Stills, and click Open. When Numbered Stills is on, Adobe Premiere Pro interprets all of the numbered files as a single sequence.
Men hva gjør jeg når "ruten" til "Numbered Stills" ikke er der...? Er utrolig kjipt. Har testet det på andre maskiner og da funker det. Noe tips?
Endret av hanszpett
