ahpadt Skrevet 2. februar 2005 Skrevet 2. februar 2005 (endret) Et par av mine til priest: Dis/Holy Discipline 27 Pts Unbreakable Will 5/5 Improved Power Word: Shield 3/3 Improved Power Word: Fortitude 2/2 Mental Agility 5/5 Mental Strength 4/5 Improved Mana Burn 2/2 Meditation 5/5 Inner Focus 1/1 Holy Magic 24 Pts Improved Renew 5/5 Holy Specialization 5/5 Spiritual Healing 5/5 Improved Healing 5/5 Improved Flash Heal 2/2 Improved Prayer of Healing 2/2 Sha/Dis Shadow Magic 31 Pts Spirit Tap 5/5 Shadow Affinity 5/5 Improved Shadow Word: Pain 2/2 Improved Psychic Scream 2/2 Improved Mind Blast 3/5 Mind Flay 1/1 Improved Fade 2/2 Shadow Weaving 5/5 Darkness 5/5 Shadowform 1/1 Discipline 20 Pts Unbreakable Will 5/5 Improved Power Word: Shield 3/3 Improved Power Word: Fortitude 2/2 Mental Agility 5/5 Mental Strength 3/5 Improved Mana Burn 2/2 ..deres tur! Endret 2. februar 2005 av ahpadt
Cirox Skrevet 2. februar 2005 Skrevet 2. februar 2005 God Restoration/Balanced specced druid build: Balance Talents (11 points) Nature's Grasp - 1/1 point While active, any time an enemy strikes the caster, they have a 35% chance to become afflicted by Entangling Roots (Rank 1). Only usable outdoors. 1 charge. Lasts 45 seconds. Improved Nature's Grasp - 4/4 points Increases the chance for your Nature's Grasp to entangle an enemy by 65%. Nature's Reach - 2/2 points Increases the range of your Wrath, Entangling Roots, Faerie Fire (caster form only), Moonfire, and Starfire spells by 20%. Improved Entangling Roots - 3/3 points Gives you a 100% chance to avoid interruption caused by damage while casting Entangling Roots. Omen of Clarity - 1/1 point Imbue the Druid's weapon with natural energy. Each hit has a chance of causing the caster to enter a Clearcasting state. The Clearcasting state reduces the Mana cost of your next damage or healing spell by 100%. The Omen of Clarity enchantment lasts 5 minutes. Feral Combat Talents (0 points) None Restoration Talents (40 points) Improved Mark of the Wild - 5/5 points Increases the effects of your Mark of the Wild spell by 35%. Improved Healing Touch - 5/5 points Reduces the mana cost of your Healing Touch spell by 15%. Nature's Focus - 5/5 points Gives you a 60% chance to avoid interruption caused by damage while casting the Healing Touch or Regrowth spells. Gift of Nature - 1/1 point Increases the effect of your Healing Touch, Rejuvenation, Regrowth, and Tranquility spells by 5%. Reflection - 5/5 points Allows 15% of your Mana regeneration to continue while casting. Improved Rejuvenation - 5/5 points Increases the effect of your Rejuvenation spell by 15%. Nature's Swiftness - 1/1 point When activated, your next Nature spell becomes an instant cast spell. Subtlety - 5/5 points Reduces the threat generated by your healing spells by 20%. Improved Tranquility - 2/2 points Gives you a 80% chance to avoid interruption caused by damage while casting your Tranquility spell. Improved Regrowth - 5/5 points Increases the critical effect chance of your Regrowth spell by 50%. Innervate - 1/1 point Increases the target's Mana regeneration by 400% and allows 100% of the target's Mana regeneration to continue while casting. Lasts 20 seconds. Hvis de gjør noe med Tranquility vel og merke, hvis ikke er dette 2 bortkastede talent points.
